Hot Rods 57 Pontiac Drag Car Build
Discussion in 'The Hokey Ass Message Board' started by Todd553, Oct 21, 2017.
  1. Todd553
    Todd553
    I machined the flywheel rather than the crank. I noticed the flywheel that came with the B&M looked like it had been turned on a lathe. Makes sense because it also came from a 389. This is my 59 motor with 55 bell housing.
  2. Todd553
    Todd553
    This is the motor. Going to change the valve covers. Stroker with a 4.25 crank, solid lifters. Should have it fired this weekend. IMG_2489.jpg IMG_2488.jpg
  3. chevy57dude
    chevy57dude
    Fresh engine pix are the best! It's the anticipation, you know good stuff will happen soon.
  4. chevy57dude
    chevy57dude
    Dual Quads! You've been holding that card close to your vest!
  5. flamedabone
    flamedabone
    NICE work so far. I noticed you sneaked a '65 and up dual quad on that little 389. Did you use '65 and up heads too or did you modify the intake?
    What valve covers are you going to run?
    -Abone.
    kidcampbell71, loudbang and Todd553 like this.
  6. Todd553
    Todd553
    I used ported 62 heads and port matched the intake. Not sure what valve covers. Need to clear the rockers so a little limited I think. I hate the idea of using spacers. Want to stay with factory style painted valve covers.
  7. bostonhemi
    bostonhemi
    Looking forward to see that fired up.
    What are the advantages to having a stroker motor?
    kidcampbell71 and loudbang like this.
  8. Torque, big time...As if the Pontiac didn't have enough already. LOL
  9. 56sedandelivery
    56sedandelivery
    That's a dual spreadbore intake is't it; you're not going to run Quadrajets are you? I've seen those intakes before, but never one with Quadrajets; they always had adapters for Holleys or AFB's. You're really developing quite a following here "Chief". Everyone loves your car, and what you're doing with it. Keep posting! I am Butch/56sedandelivery.
  10. Lone Star Mopar
    Lone Star Mopar
  11. saltflats
    saltflats
    from Missouri
    I was thinking the same thing.
    Looked like two Q jets or maybe some AVS ?
  12. 55chieftain
    55chieftain
    Great work Todd. Raiv valve cover gaskets are 1/4 thick and can double them up, don't remember felpro number off hand. I left mine sit overnight with rtv between the two and work great , if that would be enough height. I run a 3/4 " spacer also for stud girdle and roller rockers. Bill
    So 453 now? May need to go back to 3.42 with the extra cubic inches. I only run 3.73 with a 28" slick. Or maybe find a 3:64 gear
    Deuces and loudbang like this.
  13. Todd553
    Todd553
    Thanks Bill, and thanks for the cross member. What RPM are you turning through the lights with the 3.73? Thanks again.
  14. 55chieftain
    55chieftain
    6200, about 121 mph. 469, studded mains and eagle h beam rods. You've already got what a 4.06 first gear to help off the line, granted it won't last long till 2nd. But plenty of quick Pontiacs with high gear ratios, lower gears really don't make them faster especially with a 4.25 crank. If it was a 389/400 id say yes to the 4.33 for racing.
    Todd553, Deuces and loudbang like this.
  15. Todd553
    Todd553
    Motor is finally done. Made a few adjustments along the way. Ended up with 462 inch motor. I have attached a video from the Dyno session. Thanks to Calvin Hill for all his efforts.
  16. Runnin shine
    Runnin shine
    That just warmed my heart on a 15 degree day, thanks!
    kidcampbell71, doug j and Deuces like this.
  17. TFoch
    TFoch
    Great looking Pontiac! I like the path you've taken.
    kidcampbell71 and Deuces like this.
  18. Sounds good and healthy!
    GREAT that you are running a real Pontiac.
    kidcampbell71 and Runnin shine like this.
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    Nice music. Gotta love big engines.
    Deuces likes this.
  20. mad mikey
    mad mikey
    SWEET. She has a great roar.:D
    Deuces likes this.
  21. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Oh Baby, that's going to make that '57 fly!
    Are you using 31 spline axles, or something else?
    KK
  22. Todd553
    Todd553
    Forgot to post the Dyno sheet. I was very happy with the results. Made 557 horsepower. Haas_dynosheet-1.jpg
    GuyW, jimmy six, Jeff Norwell and 7 others like this.
  23. zeph4057k
    zeph4057k
    Runnin shine likes this.
  24. zeph4057k
    zeph4057k
    what a nice car !!!!!!!!
    Deuces likes this.
  25. HOLY.....WOW! You built that right.Those are big numbers!
    Deuces and Doctorterry like this.
  26. zeph4057k
    zeph4057k
    heres my Pontiac I restored....it's gone now... :( $3500 in chrome work back in 1995...... IMG_2554.JPG
  27. olscrounger
    olscrounger
    The one above looks like the one I had in High School in 1959-60. Mine was a Star Chief all silver and pretty fast for the time-beat most of the local cars. Have an old picture somewhere.
    kidcampbell71 likes this.
  28. Mike Colemire
    Mike Colemire
    This is a cool build.
  29. 550Coupe
    550Coupe
    Really like what you've done with the car. Just awesome.
    Deuces likes this.
  30. olscrounger
    olscrounger
    Your 57 is top notch!! Love it!!
