Projects my attempt at a '54 Merc
Discussion in 'Traditional Customs' started by grower54, Dec 26, 2016.
  1. grower54
    grower54
    just couldn't find a happy angle where there was no binding or tightness in the u-joints IMG_3661.JPG
  2. grower54
    grower54
    should have just done this in the first place. Borgeson box works perfectly. Costly mistake. Oh well, thats hotrodding! IMG_3667.JPG
  3. grower54
    grower54
    stripped off the old paint, filled come trim holes, bought some smoothies with some temporary tires. IMG_3701.JPG
    biggeorge likes this.
  4. grower54
    grower54
    never did like the mercury hood scoop/bump. cut the centre section of a '54 Lincoln hood out and grafted it into the Merc hood. IMG_3702.JPG
    Stogy, AlkyWagon, FlatJan and 4 others like this.
  5. Knghtcadi
    Knghtcadi
    Did you get the whole kit ? I have a rack someone fabbed onto my 54 and it's just not right. I wanted to do the borgeson box too but didn't think it would work since I have a 302 in mine but I'm still looking for options
  6. grower54
    grower54
    the box has the proper bracket to bolt right to the existing holes in the frame. I bought a non power steering centre link off e-bay. The factory 5.0L headers that i have on there right now needed to be bashed in pretty good to clear the box, but Headman has a header that will fit. They are on my list of things......
    Do the box conversion. So much more solid.
  7. Knghtcadi
    Knghtcadi
    What's the difference with the center link ? I don't have one but my main problem is that my oil pan is behind the cross member I don't know if I'll have room or not. I don't know what to do
    razoo lew likes this.
  8. grower54
    grower54
    Stogy and biggeorge like this.
  9. grower54
    grower54
    Stogy, DIYGUY and biggeorge like this.
  10. grower54
    grower54
    how did you mount a 302 with a rear sump in the same place as your rear steer rack and pinion? the centre link should go where the rack is. IMG_3734.JPG
  11. grower54
    grower54
    IMG_3731.JPG getting the brakes mocked up. Lines bent. Love this copper/nickel stuff . Bends very nice. IMG_3731.JPG
  12. The 39 guy
    The 39 guy
    Wow you are making good progress! I will have to show Don your hood modification. We have been working on the fake scoop and other problems on his hood for many weeks now. He is block sanding it (again) as I write this.
  13. Knghtcadi
    Knghtcadi
    Like I said it is a mess steering set up wise , the rack is mounted to the bottom of the cross member so it hangs down and tie rods are at a bad angle so I need to figure out how to go back to somewhat stock
  14. grower54
    grower54
    Knghtcadi, in order to get my 5.0L to fit, I bought a package from Jegs that had the proper front sump oil pan and pickup and a timing cover with the corrected dipstick location. You may need a different water pump as well. To use a steering box you will need the idler arm and mounting bracket on the p***enger side frame rail, the manual centre link, inner and outer tie rods and a pitman arm. Might be a bit of an expensive job if you need everything.
  15. Knghtcadi
    Knghtcadi
    Yeah it probably will be a bit costly but I still need it no matter what , the car has no turning radius and it needs a new rack anyway so it's just better to convert it. Plus I can't lower it anymore with this setup , I have the Aerostar springs in it but it needs to be lower so I'll just start collecting the parts. Thanks a lot
  16. grower54
    grower54
    started playing with the gas tank today.
    '69 mustang fits nicely, and added capacity to boot. IMG_3743.JPG IMG_3744.JPG IMG_3745.JPG
  17. Great car Mike.
    Most people would have walked away if they saw the start with only a pile of parts.
    Groeten uit Nederland, Hennie
  18. grower54
    grower54
    Bedankt Hennie.
  19. grower54
    grower54
    took the body off AGAIN.
    Hopefully for the last time. Just ****oning up the last of the little details. IMG_E3737.JPG IMG_3740.JPG IMG_3746.JPG IMG_3747.JPG IMG_3748.JPG
  20. grower54
    grower54
    Stogy likes this.
  21. grower54
    grower54
  22. 48fordnut
    48fordnut
    Great work. Thanks for saving one.
  23. ratrod40428
    ratrod40428
  24. FlatJan
    FlatJan
  25. grower54
    grower54
    thanks guys! Now this build is getting to the fun part. Bolting her back together and seeing some progress!
    ratrod40428 likes this.
  26. grower54
    grower54
    hey ratrod, if you are willing to make the 3500 kilometre trek to the great frozen north, it's all yours! S2vPCmmxQr+uOOsZn4l4ww.jpg
  27. ratrod40428
    ratrod40428
    I wonder what that shipping bill would be [emoji15]
  28. grower54
    grower54
    chryslerfan55 and biggeorge like this.
  29. grower54
    grower54
  30. grower54
    grower54
    cleaned up the cluster and got a 12v-6v converter. Also squeezed in a volt meter where the amp meter used to be. yNZ5V3K3S2uBQZ5+QgZJUw.jpg
