Hot Rods What update's or repairs to your hot rod will you do over the winter?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 24, 2017.
  1. Replace the front end in my 53 Chev. and install the 3:70 P case third member.
  2. I was referring to the young lady, you brat![emoji12]
    pat59, ladyhrp, 3W JOHN and 3 others like this.
  3. David Gersic
    David Gersic
    from DeKalb, IL
    Planning to learn / do some engine turning. Got a few places I think it might look good. If not, buy some parts to replace what I screwed up by trying to turn it.
    Get the transmission working correctly.
    New seats. I found some I like, they’re in my shed. Need to figure out how to make them fit, and what else I’ll have to change to do it.
    I’d like to get the radio out of the glove box door, put the box back in, and fix the door.
  4. Gammz
    Gammz
    from Lincoln Ne
    Update the ignition system, lose some weight.... the car ya smart ***'s, bucket seat(s), 456 gears, try out hands at body work and get some new paint on, the kids got a list two cabinet doors long of things to do.....
    ladyhrp, HOTRODPRIMER and 3W JOHN like this.
  5. choptop40
    choptop40
  6. j3harleys
    j3harleys
    The deuce doesn't need anything, So looks like its going to be AOD, AC, and sport coupe interior in the Fairlane
    ladyhrp, 3W JOHN and HOTRODPRIMER like this.
  7. dana barlow
    dana barlow
    from Miami Fla.
    What I will do is mostly polish,change oil/filter/plugs/clean carbs=all 4 of them. But what I need too do,there's no $$$ for,needs to be bored an new pistons an rings in my Y-block .needs better tires on front too,but that stuff an't happening .less the latto hits big 4 me.
    pat59, ladyhrp, 3W JOHN and 1 other person like this.
  8. 28 Ford PU
    28 Ford PU
    from Upstate NY
    We need a thumbs down ****on. Just kidding!
  9. Thommyknocker
    Thommyknocker
    from Colorado
    Swapping out the cracked poncho motor, then rebuilding the transmission, then I'd like to swap rear end gears
    [​IMG][​IMG]
    Full Kustom, drunk mobile posting
  10. classicdreamer
    classicdreamer
    from nyc
    Reroute the exhaust on the 38. Switch from manual valves to electric.
    Continue to learn to tig weld
    Treat the OT daily driven Honda to its once a year car wash
  11. topher5150
    topher5150
    is it me or does the engine in the middle look half the size of the one on the right
    pat59, chryslerfan55, ladyhrp and 2 others like this.
  12. RMONTY
    RMONTY
    Good luck with your surgery. I had a bicep tenodedis and a rotator cuff debridement in May and am still going to PT twice a week. I was able to throw a ball for the first time in 8 months last week. Good stuff!!
  13. southcross2631
    southcross2631
  14. 41 C28
    41 C28
    Repaint my roadster, do away with the flames, put hood sides back on and different hub caps. 136.JPG
  15. robracer1
    robracer1
    Well whatever breaks next, then whatever breaks next, then whatever breaks next and so on!
  16. LOST ANGEL
    LOST ANGEL
  17. joe.didio
    joe.didio
    Back on the truck (55 F100) and car (29 Sport Coupe) once the new shop is complete. Working on the inside, building the work bench. DSC02222.JPG
    Jet96, TagMan, RMONTY and 5 others like this.
  18. jetnow1
    jetnow1
    from CT
    Finally got my garage built, now need to get the 50 truck here to start working on it, but had to have emergency surgery for a hernia last week so I will be busy playing catch up with work.
  19. bobss396
    bobss396
    It gets real cold in NY for a few months. I have a kero heater if I need to do something. Current plans are not to do too much. Get all my trim together, identify all the clips and so on. Some needs to be straightened, all needs to be polished. My machine shop needs a good cleaning. I do drive the car as long as there is no slush and the salt is washed off the roads.
  20. LM14
    LM14
    from Iowa
    Put the 4 bar under my ‘62 short bed unibody. Also get the big window section put in. Get to work on the ‘32 ch***is so it’s ready for the body in the spring.
  21. wicarnut
    wicarnut
    My Mercury needs some paint work on front from road rash, we seem to have lots of **** on roads here. Have not met a fellow Carnut in my retirement home area (northern Wi.) that does painting as a sideline, just legit shops, men making a living. I'm thinking I'll have to prep and paint it myself as the shop rates and prices quoted are more than I want to pay, figure my time is 0$ (retired) (have proper tools) will paint in driveway, the material's cost is high today, but thinking I can do and redo, sooner or later I'll get it right, not a show car, it's a driver that I take to shows. Have had car 4 years now 18000 miles, got mechanicals squared away. Day dreaming on attempting some kustom paint work just to see how well I can do as a challenge. Many many moons ago, did body, paint work so I have some experience. You asked, that's my plan at the moment, subject to change.
  22. WTF really
    WTF really
    After a lot of good advice from y'all extremely informative and helpful hambers I'm going to be searching and collecting parts for my AV8 build.
  23. 08racer
    08racer
    from Gilbert AZ
    Im going to get the odometer working again on mine ;)
    Since winter is our time to drive them in AZ.
  24. Blue One
    Blue One
    from Alberta
    o_O Why would you have to fix the brakes so many times ? :confused: :D
  25. HOTRODPRIMER
    HOTRODPRIMER
    Larry,I hope he means breaks instead of brakes. HRP
  26. davidvillajr
    davidvillajr
    Install wiper motor - nice to have when it rains.
    Fix and or replace the interior fan switch - defroster/moving air would be nice.
    If I have money (yeah, right) maybe one of those Vintage Air deals - AC next summer would be the bee's knees.
    Tires, tie-rod ends, weatherstripping, frenching headlights, thinner driveshaft, maybe rear end...
    Yeah, it's a list. Money and time.
    dv
  27. 3W JOHN
    3W JOHN
    thanks for reminding me i have to get a new bottle of rain x.
  28. davidvillajr
    davidvillajr
    Grandpa always told me to be helpful whenever I can.
  29. 34Larry
    34Larry
    Well
    I leave here right after Christmas for Mesa/Apache Junction and so my time comes before then and then resumes just after April first.
    Considering lakester exhausts, really want a rear rolled pan fabbed for me as I don't have the machine tools to do so, and I'd like to have the black dherry shot on it. Tall order but if I get some of it done, I'll be satisfied.
  30. HOTRODPRIMER
    HOTRODPRIMER
    I need a new bottle myself! HRP
    3W JOHN likes this.
