Projects Voyage of the "Dawn Treader"
Discussion in 'Traditional Hot Rods' started by InstantT, Oct 17, 2016.
  1. InstantT
    InstantT
    from SoCal
    Popping rivets out of the frame. This is about half of all the dirt that came with the rivets.
    Sent from my LGLS992 using The H.A.M.B. mobile app
    32SEDAN and chryslerfan55 like this.
  2. catdad49
    catdad49
    You should name this "Cherry Mary", what a great car to start with. I painted the engine in my t bucket straight out of the can (with a brush) and drove it for many years without a problem. Keep up the great work, this looks to be one of those "casual hot rods".
    InstantT likes this.
  3. InstantT
    InstantT
    from SoCal
    Evel Jeke is cleaning up the Bronco rear while I'm drilling holes for the spring hangers.
  4. InstantT
    InstantT
    from SoCal
    "Casual hotrod". That's probably the best compliment I've ever received.
    catdad49 likes this.
  5. InstantT
    InstantT
    from SoCal
    Outback, 32SEDAN, BigO and 3 others like this.
  6. InstantT
    InstantT
    from SoCal
  7. Great build ya got there. Double points for the AC/DC reference!
  8. joel
    joel
    Back here we have dirt AND rust; which, I suppose ,is why we just take them apart first. Keep it up; you're making good progress.
    chryslerfan55 and InstantT like this.
  9. Dan Hay
    Dan Hay
    I just finished a build similar to this, check out the link in my sig. My car was way rough, yours is pretty cherry!
  10. InstantT
    InstantT
    from SoCal
  11. InstantT
    InstantT
    from SoCal
    I remember seeing your thread when I got this one a year ago. I thought, "Dang. He stole my shorty pipe plan!"
    Outback and Dan Hay like this.
  12. InstantT
    InstantT
    from SoCal
    Shock mounts needed some mods to fit under the floor.
    Front spring hangers are going well. Rear hangers don't seem to want to be part of this car. I'll update that part tonight hopefully ( son wnts to play "zombies" instead of making hot rods)
  13. InstantT
    InstantT
    from SoCal
    Solved the rear spring hangers. Problem was that I had walked off the front hole slightly and that threw everything off.
    But I think I was getting tired of drilling holes and having Dodge city dirt in my mouth, so I must have been rushing it. I would tell my guys at work, "Take time now and save time later."
    I should listen to my own advice.
    Outback, catdad49 and chryslerfan55 like this.
  14. InstantT
    InstantT
    from SoCal
    My "hour a day" plan has not worked out so hot. I think this kit took me 3 weeks, but I've only got about 4 hours in it elapsed time. Working late means I'm doing a lot of stuff by myself. Here we go!
    Outback and catdad49 like this.
  15. InstantT
    InstantT
    from SoCal
    P***enger side spring went in like silk. Driver side seems to bind and hang crooked. I think I'll loosen the front hanger once the weight is back on it and hopefully it settles out.
  16. InstantT
    InstantT
    from SoCal
    The axle is just resting on there right now. The urethane were bushings were a pain even with the prelube that's supplied.
    Ride height is everything, and I think this thing is gonna be way too low fr what I'm after. We'll see. I still have to set up the axle and weld the pads on.
    joel likes this.
  17. InstantT
    InstantT
    from SoCal
  18. InstantT
    InstantT
    from SoCal
    Been busy with work, but I did pick up a pair of these beauties today from a good buddy.
  19. InstantT
    InstantT
    from SoCal
    Outback and chryslerfan55 like this.
  20. belair
    belair
    Any progress is progress. Keep at it.
  21. InstantT
    InstantT
    from SoCal
    Outback, Woogeroo, 32SEDAN and 4 others like this.
  22. InstantT
    InstantT
    from SoCal
    This kit turned out ALOT higher than I thought, which is great because I want a nice rake to it.
    Once the engine weight settles the front, I can adjust the rear dwn a bit to where I need it.
    sko_ford likes this.
  23. 40ragtopdown
    40ragtopdown
    Those springs will settle give them 3 or 4 weeks of driving and see how much they settlle .car looks great.
  24. InstantT
    InstantT
    from SoCal
    I have heard that. I jump on the bumper everyday because 3 or 4 weeks of driving is going to take 3 or 4 years to get to at this rate[emoji12]
    Outback and quickrack-alan like this.
  25. 42merc
    42merc
    The TCI parabolic two leaf springs will never settle enough to satisfy any Hot Rodder.
    It will require 3" blocks to become just acceptable.
    On my coupe I had a spring shop de-arch the TCI springs 1- 3/4" , then with 2" blocks they were OK - barely. Plus, with or without blocks the supplied shocks are fully extended.
    504640 likes this.
  26. Harland grunder
    Harland grunder
    Now that is patina
  27. InstantT
    InstantT
    from SoCal
    I'm a hot rodder, and I want a stinkbug.
    The stance right now is close to right.
    I'll either drop the rear 1" or put 8.20s on the rear instead of the 7.60s.
    This one nailed the stance as far as I'm concerned. Some love it, some hate it.
  28. InstantT
    InstantT
    from SoCal
    I lost a little steam on this thing and I'll tell my sad story here:
    The fenton tripower came from my grandpa's speed shop. It had a matched set of rochesters from a j2 olds setup. I removed the carbs and boxed them up years ago to repair some things on the manifold.
    Fast forward to 3 years ago and I was packing up my garage to move to a rental while we waited for our new house to close (which was not a sure thing yet).
    My wife was having a yard sale to get rid of stuff and I started throwing stuff out there. Old tools extension cords etc.
    I also tossed a box full of single barrel holleys and denso smog carbs out there.
    It was a stressful time and our house sold fast leaving us nowhere to go. I'm racking my brain looking for the rochesters and now I think the densos were on top of them in that box.
    So I sold a j2 set of carbs for 20 bucks with a bunch of trash carbs.
    I don't even want to think of how much money I'm going to have to pay to replace them. And they won't be gramps' carbs. This ****s.
    I suppose this car is aptly named.
    Thanks for listening.
    32SEDAN likes this.
  29. 42merc
    42merc
    No offense intended.
    It is your car.
  30. InstantT
    InstantT
    from SoCal
    None taken.
    Everyone in my club keeps saying the same thing. I keep tellin them "Trust me, I see the whole car in my head".
    Hopefully I can make believers out of everyone.
    Either that or when it's ready I roll it out of the garage, stand back, and realize I screwed it all up.
    Your avatar is *****in! What rear tires are you running?
