History Mystery rearend
Discussion in 'The Hokey Ass Message Board' started by 283john, Oct 26, 2017.
  1. 283john
    283john
    Anybody know what this is? I've looked up every combination of terms I can think of online. I can tell it is mechanical braked and looks to be a 2 speed set-up. A guy posted it. Not my pic. rear end.jpg
  2. sliceddeuce
    sliceddeuce
  3. RMR&C
    RMR&C
    from NW Montana
    Could be almost anything from the 20's-30's....need more pics or info.
  4. squirrel
    it could not be a Chevy or a Ford.
    Neat rear, never seen anything like it.
    283john likes this.
  5. jeepsterhemi
    jeepsterhemi
    From a mid-duty truck...you can see the two speed...
    283john likes this.
  6. 64 DODGE 440
    64 DODGE 440
    from so cal
    Interesting cast housing and nice fill plug out the back. It would look good under the rear of an early speedster build.
  7. Ebbsspeed
    Ebbsspeed
    I don't know what it is, but like the taper of that driveshaft tube, and the casting ribs on the housing. Looks like a real weighty unit.
    283john likes this.
  8. 283john
    283john
    Yeah. I really like the look of the integral gussets.
  9. 283john
    283john
  10. warhorseracing
    warhorseracing
    from cameron wv
    What are the wheel bolt hole diameter and number of studs?
  11. SEEKONK JIM
    SEEKONK JIM
    IT LOOKS LIKE AN OLD CARDASHIAN REAR END........
    Clay Belt and alphabet soup like this.
  12. 283john
    283john
    Don't know. Waiting to find out more. Guy on Facebook car page posted those two pics asking what it was. Didn't provide any other info.
  13. squirrel
    it's probably clickbait, if it was on fb
    283john likes this.
  14. 283john
    283john
    the guy finally posted a pic of the truck that the rearend is from, if anybody is interested.
  15. squirrel
    It looks a bit older than I was guessing. I don't have time right now to try to figure it out :)
  16. 283john
    283john
    the headlight/frame/spring configuration looks like some early 20's Brockway trucks I have found online...?
  17. conestogaman
    conestogaman
  18. International,,,maybe,,,
  19. eberhama
    eberhama
    That seems really early to be a 2 speed truck axle, although I know Ruckstell was around then. Could it be a kind of primitive version of what would now be a transaxle?
  20. plym_46
    plym_46
    from central NY
    Most of the early two speeds provided a higher than stock gear set. More like the tow/ haul switch on modern pickups, rather than a gear fot low rpm cruising. The Ruckstons mentioned above were fitted to Ford TT trucks. If the standard rear gear set was a 4 some to 1, the under driven set provided by the two speed would likely provide 5 something to one to enable the truck to have enough grunt to get a load moving or for operating in hilly country, and give the operator the option of splitting gears to maintain momentum at lower speeds. The top speed of those rigs was not much over 50.
    Be neat to have but probably need some gear changes to provide the more relaxed running at cruise like an Over drive would provide. Although you could put a low 3 final gear and the use the two speeds lower range to provide the scoot from stop.
