Hot Rods Building the Black Rat '40
Discussion in 'The Hokey Ass Message Board' started by blackrat40, Oct 22, 2017.
  1. blackrat40
    blackrat40
    How about we go back and work on the dash some more for a little variety?
    Yellow??? Why Yellow? I used to rebuild, and sell, engines. My brand was "Yellow Jacket Engines".
    I always painted them yellow with black valve covers. My new dash is a memory of the engines.
    Thinking about putting A/C ducts in the ashtray holes since I no longer smoke.
    Time to install the dash.
    Got to have some black too like the Yellow Jacket engines! HotRod1224 012.jpg
    Now let's put in the stock gauge set and radio grill trim.
    YES!! No "fancy schmancy" after market gauges for me! I love the stock '40 Ford gauges.
    I have a stock '40 AM tube radio I need to have repaired. Thinking about a Lincoln Zypher V-12
    bezel. What do you guys think?
    catdad49, LOU WELLS, patmanta and 3 others like this.
  2. blackrat40
    blackrat40
    Time to try to get the transmission mounted. I took the '39 trans. off, the dummy setup, and replaced it with the '49
    Ford 1/2 ton trans. I am using for the initial build up. I'm using a piece of 1-1/2"x 1" DOM tubing which sits on the
    lower lip of the stock frame X member. I machined the holes for the rubber biscuit mounts, on my mini-mill, and will use standard Ford shoulder bolts through the open driveshaft rear mount on the pickup trans. I have stacked washers for clearance, in the pictures, but am planning to try rotating the mount 180 deg. to avoid using the washers.
    It may not work out because of interference with the speedo connection(which I plan on using with the stock '40 Ford speedometer) Stay tuned! New driveshaft is now in place.
    HotRod1224 001.jpg HotRod1224 003.jpg HotRod1224 004.jpg HotRod1224 006.jpg HotRod1224 007.jpg
  3. blackrat40
    blackrat40
    Getting ready to put the 324 (bored to 4", now 346.+) Olds engine together. Here's the freshly reground .010, .010
    crank, new 371 std. pistons, bearings and new reground Schneider cam. The rotating ***embly was balanced by Wayne Calvert at Calvert Automotive in Denton, Texas.
    Fresh clean block with new cam bearings and freeze plugs on the stand.
    Note '57 Cushman Eagle scooter in the "Q" on stand behind the engine. PB110044.JPG
    Other end of block.
    Stogy, catdad49, LOU WELLS and 3 others like this.
  4. Kan Kustom
    Kan Kustom
  5. blackrat40
    blackrat40
    Time to prepare the #10 '56 heads. I was able to get a full NOS set of valves springs and hardened retainers.
    Also scored a nice set of Gotha adjustable rocker arms to replace the hydraulic non-adjustable ones, and NOS shafts.
    A fresh valve job by Cain's Automotive machine shop in Plano, TX.
    Resurfaced the heads with a clean up cut on the exhaust ports.
    I lucked out and found a very nice set of Gotha adjustable rocker arms!
    New rocker arm set, with NOS shafts, compared to stock set.
    Now I need to find out what tubular push rods to use with Chevy solid lifters.
  6. Paul
    Paul
    Editor
    Nice :)
  7. 40ragtopdown
    40ragtopdown
    That's going to be one bad *** 40 coupe.
  8. blackrat40
    blackrat40
    I have a '56 slant pan(?) Hydramatic transmission, that I'm not going to use, if anybody needs one.
    Stogy and loudbang like this.
  9. blackrat40
    blackrat40
    That Hydramatic trans. is from the '56 Olds engine I'm building. Has bell housing and torque converter too.
  10. J. A. Miller
    J. A. Miller
    from Central NY
    Looking good!
    What do you have for dimpled valve covers?
  11. blackrat40
    blackrat40
    I have this extra Oldsmobile green set which are in great condition.
    Stogy, catdad49 and loudbang like this.
  12. Paul
    Paul
    Editor
    Those covers may need spacers to clear the Gotha rockers.
    edit: (but you knew that)
    Stogy likes this.
  13. Paul
    Paul
    Editor
    Is that a chrome plated starter switchover down there? Cool
    I like the CT engine mounts too.
    Stogy likes this.
  14. blackrat40
    blackrat40
    Actually I have a pair of finned Edelbrock covers I plan to use. May need spacers for these too. Where to get some?
    BTW Paul, I know you're knowledgeable about Rocket engines.
    Do you know what tubular push rods to use with Chevy solid lifters?
  15. Paul
    Paul
    Editor
    too many variables, best to ***emble and measure, then order to fit.
    nice covers, I like to see the same name on valve covers and intake, it just seems right.
    I get my push rods from Smith Brothers Push Rods
  16. vtwhead
    vtwhead
    ^^^^^^X2
    Also, what did you put in this hole here
    Suppose to a special bolt with a small hole to allow oiling of the chain. Often overlooked unless you have done these Olds engines before:rolleyes:
  17. blackrat40
    blackrat40
    Good eye Paul. Yep it's a chrome starter change over. I modified the solenoid position, on the stock starter, and
    mounted it upside down to get extra clearance to the headers. SidePipes2 003.jpg SidePipes2 008.jpg
    Kind of a hokey link, to the starter gear engage lever, but it works!
  18. blackrat40
    blackrat40
    Yeah I'm aware of that special bolt with the oiling hole. Actually I think I posted a notice about that, on one of the Olds Rocket threads on here, recommending that you should collect and preserve that piece as well as the plug in the rear of the oil gallery that oils the distributor gear, which also has an oiling hole. The machine shop that does the vatting, cam bearings and freeze plugs are likely to send it back with solid plugs if they don't know. Obviously you already know this Paul but I'm restating it for inexperienced guys to see again.
    Stogy, 50fish, catdad49 and 2 others like this.
  19. blackrat40
    blackrat40
    I planned to post more pictures tonight but all of a sudden none of my pictures will open!
    Anybody know what might be wrong? Windows 10 HP Laptop
    Stogy and catdad49 like this.
  20. catdad49
    catdad49
    Love the build, keep em comin'.
  21. blackrat40
    blackrat40
    I figured out the picture viewing/posting problem.
    Here's my new clutch...NOS Wilcap aluminum flywheel and Long style Hays clutch. Clutch1.jpg
  22. blackrat40
    blackrat40
    I need to buy a ready to install black headliner for the '40 Ford coupe. Any recommendations? HotRod1224 005.jpg
  23. blackrat40
    blackrat40
    SidePipes 001.jpg SidePipes2 002.jpg I'm planning to run side pipes, with builtin gl*** packs, under the running boards with the option
    of running with running boards on or off.
    Queen of the shop.
  24. vtwhead
    vtwhead
  25. neilswheels
    neilswheels
    from England
    Interesting build.
    Stogy likes this.
  26. blackrat40
    blackrat40
  27. Fedcospeed
    Fedcospeed
    Gets me thinking Walt. Looks like my water pump is coming off in the future.****ski,i cant remember:mad:
    Stogy, vtwhead and loudbang like this.
  28. vtwhead
    vtwhead
    Jim, you would not be the first to overlook it. Usually the machine shop overlooks it and plugs it and then it is easy to ****on it up. Just one of those "gotcha deals":rolleyes::rolleyes:
  29. blackrat40
    blackrat40
    At the beginning of this thread I mentioned that I was going to set out to recreate the '40 coupe
    that I built in high school in '61 with a 303 Olds in it with 3-2's and an Engle cam. I originally
    had a Weiand manifold with 3 97's. I decided I would try to find a Weiand intake with 3 97's.
    I found one advertised on ebay in Ohio. I jumped on it and could not believe what I received.
    When it arrived I was astonished to find that it was my original 3-2 setup that I had in 1961!
    When I unboxed it, and saw the red base in the center carb, naw...couldn't be! I was able to for
    sure identify it from an easy-out I broke off in the linkage! It traveled from Texas in '61 who
    knows where and returned to me 56 years later! What are the odds? I have since gone to 3
    2G Rochesters on an Edelbrock because the old 97's always leaked pretty bad.Also to a 324 Olds.
  30. J. A. Miller
    J. A. Miller
    from Central NY
    kidcampbell71 and blackrat40 like this.
