Technical DRIVESHAFT
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 29, 2017.
  1. squirrel
    I used to just grab one from my large collection, and take it to my buddy, and an hour and $20 later it would be done.
    Lately it's been harder to find donor drive shafts, and I've even had a couple made with new parts. One I ordered from a catalog, Strange made it, for about three bills, works good (that did not include the transmission yoke).
    One thing that ****s about living in a small town, after Ray closed his shop, I have to go 75 miles away to get this kind of work done.
    3W JOHN and HOTRODPRIMER like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    The local salvage yard near me always had a shelf in back with several hundred driveshafts. I was able to find one in the correct length every time I needed one. sometimes just had to change yokes. I guess I was just lucky
  3. HOTRODPRIMER
    HOTRODPRIMER
    Like you Jim,I have been building hot rods a long time and over the years I have ac***ulated a lot of spare parts,when I striped everything I wanted from the donor cars L loaded the parts I didn't want in the car,I always kept the driveshafts. HRP
    3W JOHN and Moriarity like this.
  4. Blue One
    Blue One
    from Alberta
    My donor car was a 73 V8 Maverick. I started out planning to use the 302 and the C4 and the rear end too.
    All that's left of that plan is the C4 and the Maverick driveshaft shortened to fit. :cool:
  5. 28 Ford PU
    28 Ford PU
    from Upstate NY
    If it's tweaked it should show up when balancing.
  6. squirrel
    Give the shaft a thorough hand job, feeling for dents, before deciding to re use a driveshaft.
  7. Blue One
    Blue One
    from Alberta
    That just sounds wrong ;) :D
  8. 49ratfink
    49ratfink
    by then it is too late.
  9. Rocky
    Rocky
    Classified Editor
    I used to hit the junkyard to find the right length shaft but with front-drive cars these days, it's getting harder and harder to find them. The last 2 cars I've taken measurements and end yokes from bent shafts [thanks, forklift driver] to Inland Truck Parts. They have a driveshaft department and make me a driveshaft for about $175 with my ends and new u-joints.
  10. zzford
    zzford
    I've been shafted more times than I can count.
  11. I go out to the shed and get one to chop up. Either they can shorten or weld on a new tube to lengthen.
  12. squirrel
    I was trying to think of a way to phrase it, that didn't sound *****, and couldn't. So I gave up and made it plain, what you have to do.
  13. 28 Ford PU
    28 Ford PU
    from Upstate NY
    That's because you didn't give it the old hand job first. I bet squirrel gets right down to the nuts!!!
    bchrismer, TagMan, 3W JOHN and 2 others like this.
  14. Blue One
    Blue One
    from Alberta
    :D:D:D:D
  15. tfeverfred
    tfeverfred
    I had one made for my previous T Bucket. I used an old, family owned business that I found by accident. If they're still around, they'll get my business again.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Fred,I had a driveshaft made for a A-100 Dodge Van after I installed a 340 in it and ended up with a 18" driveshaft. HRP
    Blue One and 3W JOHN like this.
  17. DDDenny
    Boy did this thread take a hard left turn.
    Blue One, 3W JOHN and HOTRODPRIMER like this.
  18. RMONTY
    RMONTY
    And they say size matters....
  19. I had one from a 91 f150 shortened a few months ago in Wichita at a large driveline shop. The cost was $40 plus tax. It was too long for my lathe. :)
  20. drptop70ss
    drptop70ss
    from NY
    I have a stock of many driveshafts on the shelf from chevelles, monte carlos, and other 60s-70s, so I shorten my own. Draw a line down the center to mark the joint phase, grind the welds off the rear yoke and knock the yoke out, cut the shaft, tap the yoke back in keeping the joints phased. I then install in the car and mount a piece of steel rod or something to the 3rd member as a reference to the shaft. I set it as close to the shaft as possible. I then rotate the shaft and tap it until the clearance between the shaft and the reference is the same for the full revolution. Never had to balance one, they run smooth. Originally I tried using a dial indicator to check runout but a lot of times there shaft surface is not smooth and it screws with the reading, so the manual reference works fine.
    Pictures below are from the one in my 47 caddy, used a piece of 3/8" fuel line as a quick reference. You can see in the one picture how close I get it to the shaft. Rotate, tap until clearance is all the way around, tack weld, check again, and weld. Only cost is the new joints.
    tb33anda3rd, ceege, pitman and 3 others like this.
  21. jackalope
    jackalope
    I use scavenged shafts from other vehicles and then cut and machine the mating ends and weld them back. Work great.
  22. Beanscoot
    Beanscoot
    Like others have done, I dig through the pile at the junkyard until I find the right one.
    It's important to find out the price before spending a couple hours digging, though. Last time I needed one I went to one yard that said the price was $25 to $75, depending on which one I chose. So I asked how much for a Ford style, 57" long, and the guy still wouldn't give me an answer, but said he would after I dug it out.
    I went somewhere else where they were all $25.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Sometimes you end up with a Chevy drive shaft and a Ford rear axle,thankfully the make ******* universal joints. HRP
  24. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
  25. squirrel
    sometimes you end up finding out that they are the same ujoint (****er 1310 series ujoint was used on many Fords and many Chevys). I needed a new driveshaft for the Edsel, I found one for a Chevy truck that needed to be shortened a few inches, the yokes were the right ones already, at both ends.
    Donuts & Peelouts likes this.
  26. BAAD32
    BAAD32
    Yamagrant likes this.
  27. rab71
    rab71
    The last drive shaft I needed made was less than two feet long. I had the yoke and U-joints. Called local shop for quote and they wanted over $200!!! I built it myself using some thick wall tube I had in the garage. Works perfect.
  28. jackalope
    jackalope
    If you plan to make your own and it’s a hodgepodge of parts and oddball components, having a Ujoint chart with measurements is your friend and then the ******* ujoints can be ordered accordingly.
    It’s ideal to have one size ujoint and not use the ******* ujoint but if you have to then this is what you do.
  29. pitman
    pitman
    In more recalled detail, used to cut about 1 in. ahead of the rear yoke weld, which gave a 'tear strip' hoop, once surgery began, by cutting - 1/8th in deep, all the way around at the center of the weld. In a '60's steel drive shaft, then split the hoop, clamp on a vice grip to one tail end and peel the hoop off, breaking the weld as you go. File or grind the yoke inside flange clean then hammer it into your newly cut tube.
    HOTRODPRIMER likes this.
  30. jackalope
    jackalope
    Gotta always remember to draw reference lines to ensure ujoints at both ends remain in perfect alignment
