Hot Rods Chevy 283 --What trans should I use??
Discussion in 'The Hokey Ass Message Board' started by Nos1partstore, Oct 30, 2017.
  1. squirrel
    And a 200-4R will almost bolt in where a TH350 was, if you want to get really modern. Just make sure you can move the crossmember back a ways.
    belair likes this.
  2. True, but we still don't know how the car will be driven,.. whether it could use an o/d. or not worth the effort.
    I know one thing , I'd rather have a 2.74 low in a hot rod, rather than a 1.82.
    Turboglide is technically a 3 speed, although it doesn't act like one.
  3. bushwacker 57
    bushwacker 57
    Flatomatic had a Adapter Chev to C4 trans 3 speed light weight takes up less room and strong.
  4. oldsman41
    oldsman41
    if you want a road car get a 200-4r. had one behind a 283 with 4barrel carb and headers small cam it loved the od.
  5. squirrel
    which is why Chevy went to all that trouble to make a 2.21 low gear 3 speed manual trans for the 56 Corvette. Wait...what? :)
  6. C4, 2.46 low gear.
    T200C , 2.74 low, no adapter, lock up clutch.
  7. The C-4 is lighter and doesn't have an integral bell. Not that it really makes any difference.
    I guess the TH 200 has become popular in small block drag race classes as a replacement for the power glide. I haven't run one but I have read about them a little bit. Seems that they have a lot of advantage for the small displacement motors with a narrow power band.
    If I had to run an AOD in a chevy powered rod and it was not a high horse/torque motor I would just run a stock 200R. I am not sure that I will ever have to run an AOD but I like the 200 better than the 700 and I have run both.
  8. Bandit Billy
    Bandit Billy
    14 posts. It took 14 posts before someone suggested a manual transmission in a hot rod.
  9. :D the OP specifically asked about a slush box option.
    XXL__ likes this.
  10. Both 200's are plenty strong enough for a Model A with a 283, Strombergs.
    Not sure how they would look with a TV cable attached.
    swade41 likes this.
  11. squirrel
    yup, that technology clash. We know a Powerglide linkage would be a****** to connect to Strombergs
  12. Tim O'Kelley
    Tim O'Kelley
    from texas
    T5 with S10 output shaft and tail housing-mech speedo-WC gears. Light weight,OD and shifter in perfect location.
    gimpyshotrods likes this.
  13. oldsman41
    oldsman41
    the guy doesnt want 3 peddles
  14. DDDenny
    I'm kind of proud of the fact that I know nearly NOTHING about those 200's but I do know one thing, I bought a new 82 S-10 pickup with the lockup converter and I HATED it for around town driving.
  15. dan31
    dan31
    2004r can be built into a great small block******* but their not cheap when done right. You can get a coan built turbo 350 ,manual valve ,reverse pattern with trans brake for 1395.00. That's half of what a built 2004r will cost.
  16. steinauge
    steinauge
    from 1960
    If it was mine I would run a 3 speed manual.Likely thats because I have 2 or 3 complete setups in the shed.
  17. What does a 200 4R or 700 R4 weigh? How about a 3 speed with OD?
  18. 56sedandelivery
    56sedandelivery
    3 speed manual trans........with overdrive, the old Muncie 319 trans. I have 2, and one's for sale, cheap. You can't can't beat them like they're an Army mule however. I also like the idea of of an old Hydro. The OP said "flexplate", so I'd have to go along with an aluminum Powerglide, with an aggressive, street style converter. That's probably the best route for the OP. I am Butch/56sedandelivery.
  19. gimpyshotrods
    gimpyshotrods
    Camaro T5, with an S10 tail.
  20. flatheadfever
    flatheadfever
    3 speed manual and column shift
  21. 56sedandelivery,
    How much and what's the condition?
  22. primed34
    primed34
    I've had a TH350 behind my 283 in my '34 coupe for over 30 years. With a 3.42 gear it hums right along.
  23. mkubacak
    mkubacak
    Manual. Three speed, four speed, or five speed, I don't care just put a manual in it. Unless you have a condition that prevents the use of a manual transmission, quit being a wuss and shift your own gears.
  24. Nah, you can build a 200 4R for way under a grand that will hold up to a 283 in a Model A, and much more...
    Urban legend.
    Hnstray likes this.
  25. gimpyshotrods
    gimpyshotrods
    Truth.
    Hnstray likes this.
  26. Any trans that you have to shift via a clutch!!
  27. Blues4U
    Blues4U
    from So Cal
    This is correct. In a 29 roadster, <2300 #'s, an aluminum 'Glide with a loose converter behind a 283 will work just fine, especially with 3.23 or greater rear end gears. OD is really not needed, it's 283, it will run fwy speeds just fine with tall gears.
  28. Blues4U
    Blues4U
    from So Cal
    What trans shift's via the clutch?
  29. gimpyshotrods
    gimpyshotrods
    No idea.
  30. Roothawg
    Roothawg
    Mine cost me right at $1600 with the upgraded internals. I checked with 5 different******* shops. They were all within $50 of each other.
