Projects 1927 T hot rod
Discussion in 'Traditional Hot Rods' started by royalflushcustoms, Nov 2, 2017.
  1. royalflushcustoms
    royalflushcustoms
    Just picked this up Sunday. Want to do a traditional 50s style hot rod racer. Want to chop and channel it with a 346 cadillac flathead. I'd like to run wide 5 hubs as well. Kind of new for me to learn so I'll be looking for advice along the way. IMG_20171029_130617_894.jpg 00l0l_lf5ErMA5Ob1_600x450.jpg 01717_DumYEPmeki_600x450.jpg 00m0m_kWzbS5PypON_600x450.jpg 00i0i_awAMR4sdJCU_600x450.jpg 00X0X_6W2kOsC2W8z_600x450.jpg
  2. AndersF
    AndersF
    Model T coupes are cool but narrow.
    Plan carefully with shop and channel couse you run
    out of space for pedals and headroom fast.
    This one was built in 55 and refined over the years.
    Known as Buzz bomb if you want to google it.
    Tim and royalflushcustoms like this.
  3. fiftyv8
    fiftyv8
    from CO & WA
    royalflushcustoms likes this.
  4. AndersF
    AndersF
    Hope that this one works better.
    dana barlow, ROCKER77, Jet96 and 2 others like this.
  5. Piedmont
    Piedmont
    As AndersF said you will run out of room quickly. I chopped but did not channel and have almost no head room.The pedal thing is an issue as well.Im still working thru that.
    chris13mel likes this.
  6. 302GMC
    302GMC
    from Idaho
    346'' Cad in a Model T ... kinda like carrying a Mosler safe in a wheelbarrow.
  7. choptop40
    choptop40
    Flathead caddy gets my vote....I have flathead parts. By the way....
  8. evintho
    evintho
    I've seen many 'T's' in that condition....body only. The fact that you've got doors and a decklid makes it quite a score! I love the Caddy flatty idea! As stated, these cars are small. Chop and channel carefully. Measure twenty times, cut once!
    juan motime likes this.
  9. A Boner
    A Boner
    While you are dreaming of the chop and channel, fix the CANCER. If you run out of ambition, at least the next guy with a dream won't end up with a cut up rust bucket.
  10. fiftyv8
    fiftyv8
    from CO & WA
  11. lostone
    lostone
    from kansas
    Nice score! I too like the caddy engine. Good luck with your build!
  12. Squablow
    Squablow
    I like the plan. I look forward to seeing it come together. I love the one AndersF posted above.
  13. tfeverfred
    tfeverfred
    Bring it on!
  14. royalflushcustoms
    royalflushcustoms
    Yea I've been doing a little test fitting with myself in it. I can definitely see how space is a premium.
  15. Mr48chev
    I've always liked the 27 roadster body on 32 rails look, what about a 27 coupe on 32 rails? With a mild chop?
    I love the look of the purple coupe that AndersF posted and think I still have the magazine it was featured in but even at a shrunken 5 10 I'd have a hard time stuffing myself into that one.
  16. royalflushcustoms
    royalflushcustoms
    Haha. I've been intrigued by them for a while and really wanted to do one myself. Figure now's a good time.
  17. royalflushcustoms
    royalflushcustoms
    Oh really?
  18. royalflushcustoms
    royalflushcustoms
    Once I saw it had the doors I was sold on it. I'll fix the rust and channel then see where I fit with a chop.
  19. royalflushcustoms
    royalflushcustoms
    That wasn't mentioned but I just ***umed it an obvious step. I don't lose ambition very often.
    chop job and elcamino59 like this.
  20. royalflushcustoms
    royalflushcustoms
    Thanks
  21. royalflushcustoms
    royalflushcustoms
    Thanks. I'm pumped. That is a pretty sweet car.
  22. patmanta
    patmanta
    from Woburn, MA
    I LIKE THIS PLAN.
    32 frame or an AA frame maybe would be my suggestion.
  23. fiftyv8
    fiftyv8
    from CO & WA
    This ch***is has been built to take my 1926 T pickup.
    https://www.youtube.com/edit?o=U&video_id=5GQ8Ujaq7MY
    Not exactly the same for a coupe, but it is a 32 Ford style ch***is which helps provide you with more room in between the ch***is rail.
    The height of the rails also helps in hiding some of the ugly stuff that can hang down and be seen from the side, which ain't always pretty.
    It will be running a 346 Cadillac flathead so it will give you some idea of what you are in for...
  24. I always wanted a T-Coupe then I got started on this thing.
    20161110_105940.jpg What a learning curve. One thing I'll share is that it's way easier to get in from the P*** side and this is *******. I'll bet it's the same with a Coupe only worse. Fun stuff for sure.
    The Wizzard
  25. fiftyv8
    fiftyv8
    from CO & WA
    Thankfully, coupes have wider doors which helps, but if steering and seating position is not worked out, access can/could be a problem.
  26. AndersF
    AndersF
    For me the 32-style frame looks wrong on a coupe.
    Works alot better stylewise on rodsters if you dont plan to use fenders.
    I cheated to gain some extra room on my build.
    I did a z under the toeboard and only channeled around 2 inch.
    My lakepipes will hide most of the frame.
    This give me enough space left for my three pedals.
    Then i put in some bars 7 inch from top to plan my seat before i chop.
    As it look now i have to lower my seat a tad more or settled on 5-6 inch chop.
    Here is a link to my build and Sinister cutoms build.
    https://www.jalopyjournal.com/forum/threads/27-coupe-build.994975/
    https://www.jalopyjournal.com/forum/threads/no-quarter-27-t-coupe-project.303632/
  27. fiftyv8
    fiftyv8
    from CO & WA
    A good looking build Anders, a lot of thought has obviously gone into it.
    Well done.
    royalflushcustoms and AndersF like this.
  28. Clarktm
    Clarktm
    I built a 26 "T" and called up Eric at Riley automotive (Colorado) and he built me a 2 X 4 frame with model A horns. It has a 4" Z in the front and a 8" Z in the back. The top of the frame sits just under the original floor steel cross members. I used a Kugel under dash 90 degree set up for the pedal ***embly. It has a corvette master cyclinder that you fill through the cowl vent. It has a remote clutch reservoir mounted up in the overhead and the tubing runs down the piller in front of the drivers door. That set up is nice because it keeps the firewall clean. I'm running a T-5 and a 56 chevy rearend. Tried to send a couple of pictures but couldn't figure out how to attach them.
    biggeorge and royalflushcustoms like this.
  29. royalflushcustoms
    royalflushcustoms
    Thanks. I think I'm going to go with a model A frame. I can get one around here pretty easy. Might have lead on one with a ***le.
    pitman likes this.
  30. royalflushcustoms
    royalflushcustoms
    I couldn't view the video. Do you have the ***le for the video I can just search it. I do like the look of 32 frames but I want to channel so I think it would be a waste to cover a 32 style frame.
