Hot Rods 1948 Willys Overland Gasser build and a question
Discussion in 'The Hokey Ass Message Board' started by INJUNTOM, Nov 2, 2017.
  1. INJUNTOM
    INJUNTOM
    Doing dad's Willys as a G***er, and want to put the big cl*** decals in the windows - I see a few on ebay (S/S, B/G, SS/AA, A/FX), checking to see what would be accurate for this thing. Front wheels have been pushed forward a few inches. 455 Pontiac, Doug nash tunnel ram.
  2. wbrw32
    wbrw32
    I'm popping the corn,,,hehehehe
    kiwijeff, OL 55, X38 and 1 other person like this.
  3. Larry T
    Larry T
    Front wheels pushed forward changes cl***es to Altered.
    loudbang and Special Ed like this.
  4. INJUNTOM
    INJUNTOM
    So, A/Something? I saw that FX is factory experimental, so leaves that out I guess.
  5. Chili Phil
    Chili Phil
    I'm sure there's a cl*** designation for this, but damned if I know what it'd be. Just choose letters that look good to you. Then make up a story about what the letters mean. Yeah,,that's the ticket...
    kiwijeff and Special Ed like this.
  6. oldolds
    oldolds
    If I remember correctly. Cl***es for Gas and altered are determined by weight per cubic inch formula. Then if it is supercharged, ect. The cl*** breakdowns seemed to change every few years. There are old rule books online. Search and learn what works for your car.
  7. Fordors
    Fordors
    I’m not so sure the Gas cl*** permitted moving the front axle forward, but regardless I guess the car can be built to resemble a Gas cl*** car. I’m not a fan of the front wheels, but then again I’m not signing the checks.
    Gas Coupe and Sedan permitted (not mandatory) a 10% engine setback while an Altered could have the engine set back a full 25% of the wheelbase.That measurement was taken from a king pin to the forward most spark plug. As said above cl*** designation was set by lbs/cubic inches, so maybe B/G might not be too far off.
  8. rusty1
    rusty1
    ...keep us posted on this project,..looks interesting,...here's a nice one that showed up at the Meltdown Drags this last Summer..
    41 coupe and loudbang like this.
  9. Larry T
    Larry T
    I just picked up a 1966 rulebook and (***uming the car weighs somewhere around 3000 lbs) it would work out to B/A (6.00 - 7.99 lbs/cubic inch) with the 455 in it. That's with a stretched wheelbase which would keep it out of the Gas cl***es.
    X38 and Special Ed like this.
  10. INJUNTOM
    INJUNTOM
    As far as the wheelbase, it's only a couple inches and may not be noticeable, especially with the flat fenders, but we thought it looked cool enough
  11. Larry T
    Larry T
    If you're after accurate, the rulebook states stock wheelbase and I never saw a tech crew without a tape measure.
    If you just want something close, the sky's the limit.
  12. Dean Lowe
    Dean Lowe
    OK, I'll say it. Slam it down in the weeds and build a cool cruiser out of it. Everything does NOT have to be a "g***er".
    kiwijeff, loudbang, hotroddon and 2 others like this.
  13. DDDenny
    I couldn't sleep either Dean.
    hotroddon and Dean Lowe like this.
  14. southcross2631
    southcross2631
    With the front wheels moved forward, you would have been in the altered cl***es. The altered wheelbase Mopars ran in altered before they got their own cl***es. Down in Miami , the Southeast Chrysler Plymouth sponsored car usually ran B/altered in weekend cl*** eliminations.
    We ran a model a coupe with the front end stretched a few inches and ran C/altered.
    INJUNTOM and loudbang like this.
  15. Fordors
    Fordors
    You guys worry too much. They are building a car that to them will represent a Gas cl*** car, nobody beats up another guy with a well known altered wheelbase car often described as a “g***er”.
    A stretched Model A as an altered BITD? Sounds cool, but I think you left some on the table with that combination. If the wheelbase had been shortened rather than lengthened more weight would be on the rear wheels with the allowed 25% setback.
    My recollection of Willys back then was there were slightly different ch***is that varied in w/b by two inches and many guys used that to their advantage.
    One last thing. When Don Long built the “Ultimate “ g***er, with the build featured in Hot Rod Magazine (about 50 yrs. ago) the wheelbase measured as built at the factory. Long moved the body back a few inches in a unique interpretation of the rules. IIRC that was not mentioned in the article, but perfectly obvious when you looked at the photos.
  16. squirrel
    uh....use white shoe polish.
    INJUNTOM, loudbang, Dean Lowe and 2 others like this.
  17. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Just build it the way you want and enjoy. If you want lettering in the rear window then put something like 2/K [ To Kool ] and have fun . Otherwise the so called experts on here will pick it apart , you will get upset and stop posting and I will miss out on following some one build something cool and different! Life is to short---- Enjoy it !! Larry
  18. Larry T
    Larry T
  19. DDDenny
    Anything but a woodpecker decal!
    INJUNTOM, 18n57 and Dean Lowe like this.
  20. Dean Lowe
    Dean Lowe
    Yes, those are only for '34 coupes. ;)
    kiwijeff likes this.
  21. hotroddon
    hotroddon
    I weep for the future historians of Hot Rodding and Drag Racing........
    Special Ed, Larry T, X38 and 2 others like this.
  22. DDDenny
    It will be slim pickn's for them I predict based on the current mateial.
    Try as they may the 60's and 70's will never be duplicated.
    Larry T likes this.
  23. II FUNNY
    II FUNNY
    Personally I think Jeeps make better four wheel drives than race cars, but you ain’t the first to build one...[​IMG]
    My advice would be to put the axle back in the stock location and get different front wheels if you think you need to build a “G***ER” there are far too many half thought out cars running around and it’s not getting better...
  24. INJUNTOM
    INJUNTOM
    Wouldn't be my first pick either, but I grew up in this thing the first 10 years of my life, looks pretty crusty now after sitting outdoors for 40 years. He p***ed away a few months ago and my stepmom and I would like to see it roll again. Not too much into 4x4 myself...actually never was but grew up flying up hills in this thing with white knuckles. It was a beast with 327 small journal, Muncie 4 speed and 5.38 gears. Our favorite thing was to sit on top of a hill and watch everyone try to come up and not able to. There was never anything that could keep up with it.
