Technical Why Chrysler urged drag racers not to do a neutral drop
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Nov 3, 2017.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I'll bet that was one heck of a explosion! HRP
    Jet96, jchav62, dana barlow and 5 others like this.
  2. Now, that's some carnage!
  3. F.O.G
    F.O.G
    from Pacific,Mo
    It'll buff out!
    XXL__, 3W JOHN and HOTRODPRIMER like this.
  4. Bandit Billy
    Bandit Billy
    Looks like that torque flight took flight.
  5. Looks like they filled it with liquid nitrogen and dropped it.
  6. jcmarz
    jcmarz
    from Chino, Ca
    No worries, it's just some spare parts that's not needed!
    Sent from my SM-J700T1 using The H.A.M.B. mobile app
  7. It isn't just automatics, I saw a Mustang with a small block, explode about 25 ft from the starting line after beating all comers all afternoon. I was grateful that he had a scattershield or he would have been severely injured. There was shrapnel everywhere. I am guessing that he got things too hot after multiple runs without a lot of cool down time.
    A friend of mine owned a transmission shop, and one occasion, a guy got a 727 so hot that it blew up just like the picture above. The converter had to be separated from the flex plate by cutting it apart.
    Seeing just one explosion makes one want to take better care of the equipment.
    Bob
  8. Happydaze
    Happydaze
    Quick way of dropping the trans fluid.
    Chris
  9. chevy57dude
    chevy57dude
    ''Looks like we found the weak link in the drivetrain''.
    Wouldn't want to be the next car to stage in that lane!
  10. When I was a lad I had a 318 & 727 push button auto in a Chrysler Royal, while coming down a hill I wanted to slow a bit, so I decided to punch the 2nd button- except I punched the Reverse instead. The car came to a screeching halt, engine stalled, car skidded off to side of the road. Being 17 years old, I first looked for a clean pair of undies, then I got out, looked under the car, to see the carnage. Nothing to see here-not even a drop of trans fluid. So I got back in, put it back in neutral, fired it up, and gingerly put it in drive. Hit the loud pedal, expecting noises or no movement, but it moved normally, as if nothing had happened. Trans was fine , never missed a beat. Them Mopar trans's sure are hard to break!
  11. mgtstumpy
    mgtstumpy
    A couple more, OUCH!
  12. low budget
    low budget
    from Central Ky
    Clean up in lane two please.
    bobss396, j-jock, 3W JOHN and 3 others like this.
  13. tommyd
    tommyd
    from South Indy
    Back around 1970 when I was 12 years old I was standing next to my brothers car in the water box pouring bleach under his slicks. The Max Wedge that had just warmed his tires was doing neutral drops and the same thing happened to him. It sounded and looked like a bomb went off!
    slowmotion, 3W JOHN and HOTRODPRIMER like this.
  14. low budget
    low budget
    from Central Ky
    Honestly had never heard of a neutral drop so I looked it up, I honestly didnt think professionals would even dream of doing something like that, I used to get one goin backward in reverse then drop it in low and nail it but I thought that was ok:D (NOT:p)......It did some how seem safer than tacking one up dead still in neutral then dropping:eek::D
  15. low budget
    low budget
    from Central Ky
    The transmission and frontends were always a weak link for me back in my Dart and Duster days
    3W JOHN, HOTRODPRIMER and town sedan like this.
  16. BamaMav
    BamaMav
    from Berry, AL
    I did something similar to 36roadster one time;, had a 68 Chevy, 327 powerglide. Going home from my GF's house, late night, had forgotten to buy gas before I went to her house, back then most stores closed up by 9PM, this was around 11PM. I knew of one automated station where you fed bills into the pump and it let you have that much gas, no more, no less. I was trying to make it to that station, I'd put it up in neutral and coast down the long hills then back in drive to the next one. Going down one long hill, bumped it up, but went too far, hit reverse instead of neutral. Those big L 60 15's let out a deadly scream , the big Chevy lurched like it was going to stop, then total quiet. I just knew I had blew it! Pulled it back down to neutral, hit the starter, she fired right up, pulled it into drive, and it pulled right away. Never seemed to have hurt the engine or transmission.
    3W JOHN, HOTRODPRIMER and low budget like this.
  17. town sedan
    town sedan
    '63 Dart with a 170 & a pushbutton tranny. Punk ass high school kid. Hard rear tires. Neutral drops where fun, surprised a few back then with how quickly it could leave the line. They'd still walk away from me by the time I'd be punching up second gear. And yes, while no external carnage, I did destroy the guts of that poor slush box. Punk ass high school kid.
    -Dave
  18. 56don
    56don
    I ain't cleaning that up!
    I had a clutch blow once at somewhere between 8 and 10 grand depending upon how accurate the electric tach was. Luckily I had a scattershield on it because there wasn't much more than dust in the bellhousing when I pulled it.
    mgtstumpy, 3W JOHN and HOTRODPRIMER like this.
  19. greybeard360
    greybeard360
    On a TF they will do that if you do a burnout in low gear and let the tires hook up. If the rear end let's go while you are in low.... Same results.
    Sent from my Moto G Play using The H.A.M.B. mobile app
  20. squirrel
    finally, someone who knows how Torqueflites work! :)
    A neutral drop can rip the back of the case out, or at least damage the roller clutch. But it won't make the drum explode immediately...to do that requires you to rev the engine over 5000 rpm with a non functioning roller clutch.
  21. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for sharing your knowledge on the subject. HRP
    3W JOHN likes this.
  22. sunbeam
    sunbeam
    That's why the clutch-flite.
  23. zzford
    zzford
    Fortunately, the complete loss of tire traction save the day.
  24. ironrodder
    ironrodder
    Most times you see a 727 explode like the pix show it's because the rear end broke. With the reverse valve body all the pressure on first gear would unseat the spag and push it into the high RPM planetary. Instant hand grenade. At least that's what Chrysler engineers said when it happen to us. Len Silvers was one of the first to find out at National Trails Raceway in 1965. Everyone thought it a fluke, then more guys saw it happen that year. Ray Daily broke one at Mt. Vernon in 1970 so bad the convertor sawed it's way across the brake pedal into the kick panel and was found on top the valve cover. Big fire. Guys on the starting line got Ray out and saved the car. Not a pretty site when it happens.
  25. HOTRODPRIMER
    HOTRODPRIMER
    I did the same thing with my dads 62 Ford,I pushed my luck also. HRP
    low budget and 3W JOHN like this.
  26. Saxxon
    Saxxon
    And folks still argue the need for a transmission shield or blanket
    Bugsy48, 3W JOHN and HOTRODPRIMER like this.
  27. 49ratfink
    49ratfink
    they should make adapters for turbo 400's so that stuff doesn't happen:)
  28. HOTRODPRIMER
    HOTRODPRIMER
    I would think Big Daddy Don Garlits accident where he lost part of his foot would be reason enough for any sane person. HRP
    3W JOHN likes this.
  29. DDDenny
    They did (sorta), Clutchturbos and Clutchflites.
    HOTRODPRIMER likes this.
  30. bchctybob
    bchctybob
    I was just reading an old magazine the other day talking about how the MOPAR small block racers needed help to get their cars off the line with out doing "neutral slams". Chrysler engineers came up with the Clutch-flite in the picture below. I had never seen that version, it's pretty clever. They shifted further development to one of the big race trans companies (B&M?).
    My Austin was the victim of a trans explosion though not as bad as the OP, note the floor and the hole in the driver's door. That may be why it was retired many years ago.
