Hot Rods The No Frame Model A Modified
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Sep 22, 2017.
  1. vtwhead
    vtwhead
    great engineering and fab work here. What an inspiration.
  2. dentisaurus
    dentisaurus
    from Boston
    Lot more space in the foot well than I would have thought. Very neat solution
  3. rottenleonard
    rottenleonard
    Thanks!
    That it the beauty of the space frame construction, to get this low with a channel job you loose all of your leg room.
    pitman likes this.
  4. rottenleonard
    rottenleonard
    Also the powdercoaters called yesterday, wheels were done.
    brEad, Stogy, AHotRod and 1 other person like this.
  5. flt-blk
    flt-blk
    from IL
    looking good,
    Is the gas pedal going on top of the clutch linkage somehow?
  6. This car is awesome! Lots of skill here!
    kidcampbell71 likes this.
  7. AHotRod
    AHotRod
    I Love the build, design and creativity.
  8. jerseyboy
    jerseyboy
    You got fab skills man! Cool solutions too.
  9. Looks like the first "bird cage" model A. Those IIItalians got nuthin on you.
  10. MMM1693
    MMM1693
    Just one hell of job ! Great work all around!
  11. rottenleonard
    rottenleonard
    Over it anyhow
    20171031_163429.jpg 20171101_091655.jpg 20171103_082221.jpg 20171103_082235.jpg
  12. gnichols
    gnichols
    from Tampa, FL
    Hate to ask... but is their any doubt in your mind that that old flattie will hold up as a stressed member? Gary
  13. rottenleonard
    rottenleonard
    Really not too worried if you look at something like an 8N ford tractor which has a B motor, the engine is the frame, we did A LOT, of stupid stuff in those and we broke lots of other things like wheels and axles but never a block. v75.jpg
    Kreepea_1, Jet96, ol'stinky and 3 others like this.
  14. very cool and innovative
    reminds me of European sports cars
    Stogy and AHotRod like this.
  15. gnichols
    gnichols
    from Tampa, FL
    I see, said the blind man. I'd still get in line for a ride some day if I could. Gary
    Stogy likes this.
  16. fiftyv8
    fiftyv8
    from CO & WA
    I'm on board with this project, but after following progress, have just started to wonder how difficult it might be to remove a ****** or engine should the need arise.
    Have you been making build decisions that will help make that easy???
    brEad likes this.
  17. gnichols
    gnichols
    from Tampa, FL
    ^ My guess is that it would be easier! Gary
  18. rottenleonard
    rottenleonard
    I have been pretty careful to make everything removable, granted the engine will have to come out in order to remove the transmission. I don't believe that will be that big of a job in the grand scheme of things. But when we blow it apart for powder coat I guess we will find out haha.
    brEad, Stogy and AHotRod like this.
  19. rottenleonard
    rottenleonard
    I worked on the exhaust, intake, and front spring hangers yesterday. 20171101_105321.jpg 20171101_111052.jpg 20171103_083532.jpg 20171103_094609.jpg 20171103_162108.jpg 20171103_162054.jpg 20171103_161823.jpg 20171103_162118.jpg
    brEad, Stogy, Blues4U and 1 other person like this.
  20. rottenleonard
    rottenleonard
  21. rottenleonard
    rottenleonard
    I also machined up another pair of Harley wheels for Model A spindles, if anybody would like a set they are ready to go. $700 for the pair 20171102_140450.jpg
  22. captainjunk#2
    captainjunk#2
    that s a pretty awesome build ,
  23. rottenleonard
    rottenleonard
    I knocked the topps off thr king pins, required a little filler and lathe work
    Then reworked the brake brackets a little
    Getting the coolig system to flow without an air lock was going to require a little modification
    20171113_154629.jpg stock upper water neck
    Cut off and milled flat
    Bored a hole in the front for 1.5" tube and tig'd it together with silicone bronze.
    That should let the air out and the water past.
    Stogy, AHotRod, Thor1 and 2 others like this.
  24. 2NDCHANCE
    2NDCHANCE
    awesome fab work, you won't want to re-sell that car very quickly. Great job. gary
  25. rottenleonard
    rottenleonard
    I got back on the no frame model A last week, first order of business was gusseting the front subframe and also tieing it back into the bottom of the block at two more points.
    Trying to reuse as many Model A Parts as possible this spring spacer needed to be repurposed as a spring locator. So I spun up a sleeve and Tig welded it in. 20180327_113459.jpg
    While the car was together my guess at ride height was about an inch and a half too low. The solution was to section out the front spring Mount to bring it up so I have just a little drop front to rear.
  26. brett4christ
    brett4christ
    MAD Skills! Love the execution!
  27. BJR
    BJR
    This is sooooooo far beyond my limited skill set, it is just a pleasure to see it being created. Please keep posting to the finish. Brian
  28. Nostrebor
    Nostrebor
    I'm here to critique this build...
    I've got nothin.:D
    Well ok, I do suddenly want to sell off all of my stuff and build one of these. I'm not really happy about that. Otherwise, the build is off the charts! Please continue.
    49ratfink, Thor1 and Stogy like this.
  29. 49ratfink
    49ratfink
