Projects Turning a Chevrolet hood into a one piece hood
Discussion in 'The Hokey Ass Message Board' started by the metalsurgeon, Nov 5, 2017.
  1. the metalsurgeon
    the metalsurgeon
    from Denver
    Painted hood to media blast.Made a smooth transition nose piece to take away the peak. DSCN6181.JPG DSCN6180.JPG DSCN6179.JPG DSCN0345.JPG DSCN0351.JPG DSCN0352.JPG DSCN0364.JPG
    Fern 54, j-jock, mgtstumpy and 4 others like this.
  2. Moselli
    Moselli
    Quite obvious why you are known as the Metalsurgeon...
    Outstanding work!
    the metalsurgeon and Hnstray like this.
  3. blucar
    blucar
    "Back in the day" like when I was a teenager, we made a lot of '40-42 Chevy hoods into one piece units by simply brazing up the seam between the two halves using a Oxy-Acet torch, br*** rod and flux. A little grinding the weld and some lead filler completed the job.
    Of course very few people know how to gas weld body metal anymore..
    dana barlow likes this.
  4. the metalsurgeon
    the metalsurgeon
    from Denver
    I gas weld,and still wouldn't choose that method,looks like a cheap short cut in my opinion.
    Our objective is to make the transition into a one piece as if it was pressed in the factory that way.
  5. the metalsurgeon
    the metalsurgeon
    from Denver
  6. john worden
    john worden
    from iowa
    Are you going to weld between the tack welds?
  7. the metalsurgeon
    the metalsurgeon
    from Denver
    yes
  8. the metalsurgeon
    the metalsurgeon
    from Denver
  9. The37Kid
    The37Kid
    Very nice, always good to see you post photos of projects like this.
    Bob
  10. the metalsurgeon
    the metalsurgeon
    from Denver
    thanks Bob for following
  11. the metalsurgeon
    the metalsurgeon
    from Denver
  12. Hdonlybob
    Hdonlybob
    Awesome work...and real talent.
    I took the crease out of a '49 Chevy hood by welding the seam together directly and had all sorts of problems....it did finally turn out OK after hours of filling and blocking, but nothing like yours will....
    Very nice job....
  13. 56 Dodge Pickup
    56 Dodge Pickup
    Man that's some impressive metal work! Thank you for sharing! Hobo Jim
  14. dentisaurus
    dentisaurus
    from Boston
    very impressive!
  15. Johnboy34
    Johnboy34
    from Seattle,Wa
    Is that tig welded or mig?
  16. cretin
    cretin
    That is Tig
  17. the metalsurgeon
    the metalsurgeon
    from Denver
    thanks guys for checking out the project.Tacking with Mig,followed by Tig.
    thanks again.
    Ready for delivery
    DSCN0525.JPG DSCN0533.JPG DSCN0530.JPG DSCN0501.JPG DSCN0496.JPG DSCN0533.JPG DSCN0526.JPG DSCN0527.JPG
  18. cretin
    cretin
  19. the metalsurgeon
    the metalsurgeon
    from Denver
    thank you
  20. lostone
    lostone
    from kansas
    That's the nice thing about old cars, they actually had some good heavy metal you can pick and file. Not like the beer can thick metal today.
    Nice work BTW.
  21. the metalsurgeon
    the metalsurgeon
    from Denver
    yeah i agree.... new cars are made from KitKat tinfoil....thanks for following
  22. That's some sick metal work. What year Chevy is the hood off of looks like early 40's
    Sent from my SM-N910V using The H.A.M.B. mobile app
  23. The37Kid
    The37Kid
    If it isn't a trade secret is the filler piece cut to fit with snips or a cutoff wheel?
    Bob
  24. Johnboy34
    Johnboy34
    from Seattle,Wa
    Wow! Nice work, I'm in awe....
  25. dana barlow
    dana barlow
    from Miami Fla.
    Work looks good,but I'm not seeing the under hood added bracing that is needed,stock back brace is not enough,if you'd like no cracks to show up=make at lest two more running across/side to side,between nose and stock rear brace. Played that game in the 50s n early 60s.
  26. the metalsurgeon
    the metalsurgeon
    from Denver
    Added bracing is not necessary or needed,just like no bracing other than the rear in the original.
    You're welcome to check on the progress of the hood when painted,send me your email address and ill send you progress reports with photos.
  27. the metalsurgeon
    the metalsurgeon
    from Denver
    Bob, i used a bandsaw ,cut off wheel would work too.
  28. bchctybob
    bchctybob
    How many hours do you have in it and what machines did you use?
    Beautiful job, not sure I have the patience to attempt that these days.
  29. blackout78666
    blackout78666
    Very nice work. Not to hijack your thread but on my sons ( 15 at the time) car we built together he wanted to " do something cool to the hood" while not as involved as yours I taught him to form some 1/4 steel rod and tack it in the seam for a little peak. He got the hang of it and is quite proud of his "non stock" hood
