Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. rusty rocket
    rusty rocket
    The page above is very helpful. Thanks.
  2. Fabber McGee
    Fabber McGee
    s-l1600.jpg I just looked on ebay. There are a couple cast intakes for your engine, but they are high. Also, one for a 25 inch Chrysler that the fellow built himself. Looks like a good option.
    brEad, kiwijeff, Stogy and 1 other person like this.
  3. rusty rocket
    rusty rocket
    Damn I could build something like that!!!!!!!
    brEad, biggeorge and kiwijeff like this.
  4. Fabber McGee
    Fabber McGee
    I sure can't see why not. You could likely do it for less than the 500 bucks he's asking and do a little smoother job too. His carbs need rebuilt, I just don't see a lot of value there, hasn't even been tried out.
  5. rusty rocket
    rusty rocket
    I have a 49 and 51 Ford decklid laying down at my pops, I grabbed the 49 and took the skin off. I was thinking that it would have the crown to fill in the sides of the idLdo. IMG_2323.JPG IMG_2324.JPG IMG_2325.JPG IMG_2327.JPG
  6. rusty rocket
    rusty rocket
    It works. Will have to do some hammer dolly work for sure! IMG_2329.JPG IMG_2330.JPG IMG_2331.JPG IMG_2332.JPG
  7. Fabber McGee
    Fabber McGee
    yeah man, that slipped right in there.
  8. rusty rocket
    rusty rocket
    You know I blinked and it was in there. NOT!!!!!!! It wasnt to bad though even for the worlds worst sheetmetal man.
    brad2v, kidcampbell71 and Stogy like this.
  9. rusty rocket
    rusty rocket
    Pops donated a nice set of Guide Cycleray headlamps for the idLdo. Also brought home my other shoebox trunk lid to fill in the other side of the body. IMG_2335.JPG IMG_2336.JPG IMG_2337.JPG
  10. Jet96
    Jet96
    from WY
    I like that you are incorporating the body lines fron various pieces to give almost a factory look. Very cool!
    brad2v likes this.
  11. brooksinc1976
    brooksinc1976
    from P-Town
    kiwijeff likes this.
  12. rusty rocket
    rusty rocket
    Thanks, When I started clamping things together I could see that if I moved the fenders forward the body lines would start in the cowl. It really did work out well.
    markin59 likes this.
  13. rusty rocket
    rusty rocket
    Welded in most of the side panel until I ran out of gas. Looks like ****! Going to have to do a ton of work trying to get it straight. IMG_2338.JPG IMG_2339.JPG
  14. oldn_rusty
    oldn_rusty
    Hey, Rusty.... For those of us that are novices and beginners, this is a terrific template of how to fabricate. Thanks for the primer. And its such a cool ride. Can't wait to see the peddle arrangement.
  15. rusty rocket
    rusty rocket
    Oh boy dont let me take the lead here. I'm doing everything *** backwards. I have good friends that are fabricators and I've seen how to do things correctly but when I get in my home shop I seem to forget all the right ways to do a job. As far as the pedal set up I've had that stuck in the back of my head but dont have a clue of how it will all go down. I guess it will depend on what parts are scrounged.
    Stogy likes this.
  16. rusty rocket
    rusty rocket
    Had to prop things up today to see what its going to look like. IMG_2343.JPG
    chriseakin, sko_ford, brEad and 19 others like this.
  17. plym_46
    plym_46
    from central NY
    Check out this fellows offerings
    http://www.manifoldsbymoose.com
    Couple 1 1/2 SU's would be neat.
    Kinda exemplifies the iD'ldo feeling.
    On the engine block drivers side front just under the head is a flat raised cast spot, the engine number is stamped there. Should start with a T. But, engine swaps were almost always the cure for a worn out unit so it could be something else. The engine number will confirm what it is. With some subtle mods my Plymouth 230 is making 127 rear wheel HP at 3300. Factory pulled flywheel HP at 3600. Nice project like the Mopar power plant idea. Truck trans will likely be a non synchro 4 speed, but low will be a granny gear. The truck engine bell housing bolts through the frame so you might need some frame stretchers to make it fit.
  18. rusty rocket
    rusty rocket
    Thanks for the Info. Looks like I should look for a car top loader trans.
    Atwater Mike likes this.
  19. plym_46
    plym_46
    from central NY
    Floor shift Mopar cars ended in 39, any thing later is a selector style. With something that light you will likely only need 2nd and 3rd so the truck trans might not be an issue. What you want to keep in mind is engine, bell housing and trans are going to be 750 + lbs or probably 65% of finished total weight. Your front suspension, steering and wheels are going to need to be good and stout.
    Atwater Mike and brad2v like this.
  20. rusty rocket
    rusty rocket
    That will not be a problem, I will be using 40 ford I beam and wish bones. I,m doing this as cheap as possible so I guess what trans comes along will be the one used, car or truck.
  21. rusty rocket
    rusty rocket
    Picked up my 40 front end today. Was thinking about a spring over axle but I dig the way it looks with the spring ahead. Plus it will save me money not buying spring over perches. IMG_2353.JPG IMG_2354.JPG IMG_2355.JPG IMG_2356.JPG
    brEad, brad2v, Tim_with_a_T and 7 others like this.
  22. You could, and you should. ;)
  23. rusty rocket
    rusty rocket
    Havent had much time to play but I did make a bottom spring retainer for the front end and I still have to clean up the top perch. I had some flathead head bolts with a F cast in them so I'm going to use them to hold everything together. IMG_2359.JPG IMG_2360.JPG IMG_2361.JPG
  24. bobbytnm
    bobbytnm
    Great project!!
  25. Stogy
    Stogy
    Great things in the details...fun to watch things coming together @rusty rocket
  26. rusty rocket
    rusty rocket
    I made a prototype tie rod mount for the frame. I just cant seem to do things simple, I still have to ream the bung out to 7 degrees. IMG_2362.JPG IMG_2363.JPG IMG_2364.JPG IMG_2365.JPG
    sko_ford, Jet96, brad2v and 5 others like this.
  27. rusty rocket
    rusty rocket
    Milled up three more mounts. Little over the top for the car but what the hell. IMG_2366.jpg IMG_2367.jpg
    chriseakin, sko_ford, brEad and 11 others like this.
  28. Blues4U
    Blues4U
    from So Cal
    Such nice workmanship!
    brad2v likes this.
  29. vtwhead
    vtwhead
    as they say, it's all in the details! Nice mounts.
    58Darlene likes this.
  30. rusty rocket
    rusty rocket
    Made one tie rod/ wishbone bung today after work. Going to weld the model A tie rod into the bung and then weld the bung to the wishbone. Should be fine for the weight of the car. Now to mill three more. IMG_2370.JPG IMG_2371.JPG IMG_2372.JPG
    brEad, brad2v, Stogy and 3 others like this.
