Technical Flathead: Crack in Lifter Valley?
Discussion in 'The Hokey Ass Message Board' started by Shaun1162, Nov 5, 2017.
  1. Shaun1162
    Shaun1162
    I picked up this 8BA block at an estate sale a while back for $100. It had just come back from the machine shop after being cleaned up and having new cam bearings installed. The block is marked “v. Good” but then I noticed this crack in the lifter valley...
    Recommend repair? Or is this something that you forget about and run anyways?
    I appreciate any advice from the flathead experts out there
  2. Deuces
    Deuces
    That can be drilled and plugged...
    Maybe...????
  3. RMR&C
    RMR&C
    from NW Montana
    I'd have the block magnafluxed and see what turns up. If that is the only crack and it's not near anything vital, I'd run it.
    j-jock, Shaun1162 and Hnstray like this.
  4. flathead4d
    flathead4d
    Post your pictures over on the fordbarn.com web site. Someone there will know exactly what can be done.
    leon bee likes this.
  5. sunbeam
    sunbeam
    Drill both ends for the crack to keep it from growing It doesn't look like the holes will hit water or oil.
    j-jock likes this.
  6. mohead1
    mohead1
    Agree, small holes on each end, dremel a groove between the two, clean and clean again, blow w air, fill with metalized epoxy
    Sent from my SM-G900V using Tapatalk
    flatheadpete likes this.
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    I would take it to a shop. Like RMR said, have them magnaflux the block. Let them determine if it can be pinned or machined for you.
  8. Shaun1162
    Shaun1162
    I believe it was magnafluxed. They've marked this one crack in the valley, and those two typical cracks between the water jacket and bolt hole, that's all I can see. I'm guessing the shop didn't see a major problem, or they wouldn't have changed the cam bearings, but who knows?
  9. RMR&C
    RMR&C
    from NW Montana
    That's a weird place for a crack. Maybe a weak spot in the casting? Is it close to a cam bearing?
    Visible from the bottom side?
    Shaun1162 likes this.
  10. Shaun1162
    Shaun1162
    It’s a couple inches away from the center cam bearing, but it is not visible from the bottom. I was thinking casting as well?
    RMR&C likes this.
  11. warhorseracing
    warhorseracing
    from cameron wv
    Did you talk with the shop? That would be my first step. Ask them their opinion if they are reputable.
  12. Shaun1162
    Shaun1162
    That’s the problem, not too sure what shop it came from. They mentioned it had just come back from the shop the day prior to the auction, but there was no mention of which shop.
  13. RMR&C
    RMR&C
    from NW Montana
    I'd run it.
  14. Shaun1162
    Shaun1162
    I was hoping someone would say that
    cactus1, hotcoupe and biggeorge like this.
  15. flatheadtommy
    flatheadtommy
    This is the cl***ic case of making a mountain out of a molehill , remember these flatheads are the most forgiving engine ever made. example, when Andy Granitelli ran Indy with his Grancor Spl. there was a rule that you could use so much oil and that was it, when he used up that said amount his pit crew filled the crankcase with soapy water to finish the race. google it and you will get the full story. Now you know where I stand and I say run it !
  16. Saw an exact same crack in the same spot in the valley allow water into an 8BA for a milkshake. Get it pinned and loc***e seal the water jackets to seal it up good.
  17. 19Fordy
    19Fordy
    Any reason why it couldn't be welded?
  18. mohead1
    mohead1
    Braised wud be the way....or like i previously said, drill, light grind, epoxy
    biggeorge likes this.
  19. patterg2003
    patterg2003
    Someone may have marked those indications for a closer look. If you took it to a shop that does mag particle they could tell you whether they are relevant or non relevant in a couple minutes. Relevant being cracked & non relevant is surface. If the block has been cleaned then you could buy a liquid penetrant inspection kit and follow the instructions to do it yourself. If the dye test has a slight color bleed into the developer then it is surface. If it is a crack then it will be a strong color bleed into the developer.
  20. Nobey
    Nobey
    Do a water pressure test on it, if it weeps have it repaired before you ***emble it.
  21. Beanscoot
    Beanscoot
    Start phoning around all the local auto machine shops to ask if they just sent out that block. There aren't too many machine shops or flatheads these days.
    An old logger I worked for told me in the old days the rebuilders wouldn't take a flathead back as a core if it had any cracks whatsoever. Over time they had to be a bit less picky as they couldn't get any perfect cores.
    He said the shops would accept a crack leading to a stud, but not one between a valve seat and cylinder.
