Hot Rods How to store Car over winter outside?
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Nov 12, 2017.
  1. fordstandard
    fordstandard
    What is the way to -
    1) properly cover
    allowing car to breathe sitting outside over winter in N.E area of the U.S?
    2) What surface to park it on ?
  2. Keep driving her. Not trying to be a smart *** but keep driving her as long as you can .I have had cars stored under tarps for the winter and like the rest of the crew have said it traps moisture. I had just painted a 62 Buick about 10 years ago and had one old car in the shop a ready so I tarped it down and weighted it down with cinder blocks. We get a lot of wind up here on the mountian top during the winter and the tarp kept coming loose on almost every end. When spring time rolled around and I took the tarp off the paint was beat and scratched to hell. I would try a least keeping it under a car port that way you could run her every week or check in to one of those inflatable bubble storage bags you can park your car in that. As long as it doesn't snow I will keep on driving mine. Took it in to town the other day when it was in the 30s.Boy I am glad that old girl has a good heater in it. Good luck with yours .Bruce.
  3. BJR
    BJR
    There is NO WAY to keep mice out of the engine compartment and your wiring on a car stored outside. Also very hard to keep the mice out of the inside of the car if it has any amount of rust on the body. Try to find indoor storage and make some 5 gallon water bucket/antifreeze traps for the mice.
    chryslerfan55 and CapeCodBob like this.
  4. Park over moisture barrier, on blocks to keep tires round, screens over exhaust/intake, leave windows cracked for venting and a way for the rodents to get out. Turn over 1/month if possible.
    Bruce Fischer and chryslerfan55 like this.
  5. 19Fordy
    19Fordy
    If possible, rent a storage unit for the winter and still follow advice above.
  6. Bruce is right. From my experience, you have to store your car or Rod inside. Or if not, at least start and drive it as much as possible. Basically treat it as you would your daily driver. If you store a car out side, with no maintenance, it will turn into yard art. If I have a future project car, that's stored outside the best thing to do is nothing,{ just let it breath} and let it to the open air. But the longer it sits outside, the more work I will need to do to it later. Like said, put it in a storage container, a friends shop, etc. Mother Nature is not a nice lady, when it comes to our old cars,:( {sorry}, but true. Ron...
  7. I also try to Start them once a Month.
    Just my 3.5 cents
    Live Learn & Die A fool
  8. 19Fordy
    19Fordy
    Ever look at the frame of a vehicle that has been stored outside for long periods of time?
    It's like a sponge absorbing moisture.
  9. lothiandon1940
    lothiandon1940
    To the OP: Don't know who your insurer is but, mine requires that my junk has to be kept inside in a secure place when not in use. Just something to think about aside from the usual and many issues with outside storage. Better check your coverage.
  10. i.rant
    i.rant
    ^^^^^^^^^ This.
    lothiandon1940 likes this.
  11. David Gersic
    David Gersic
    from DeKalb, IL
    A good breathable car cover, no tarps. Tarps trap and hold in moisture.
    Special Ed, bobwop and Bruce Fischer like this.
  12. FritzJr
    FritzJr
    Most important thing in the north east is to have a water proof surface under the car. Heavy plastic and/or plywood works well. Parking over bare ground will rot out the underside.
  13. jazz1
    jazz1
    Don't tarp it. I use portable wigwam. Vapour barrier is a must on the floor to keep moisture out over the winter
    I also made a false front to protect entrance from prevailing north wind IMG_1322.JPG
  14. 19Fordy Now that's a GOOD idea if you dont have a place to store it a least its out of the weather.Bruce.
  15. Change the oil, check the prestone , Drive it up to the front of the garage , throw it in park and lock the doors.
    chryslerfan55, jazz1 and pat59 like this.
  16. bigdog
    bigdog
    If it has to stay outside I wouldn't put a cover on it. Any cover or tarp is going to move on the car when the wind blows and it will scuff the paint-ask me how I know. You also want to start and run until completely warm once a month or so, if it's covered up then that becomes a pain in the ***.
  17. bchctybob
    bchctybob
    Now that looks like a great idea, who makes/sells those wigwams?
  18. GR5
    GR5
    Hello,
    If you have access to power I’d look into an outdoor Car Capsule.
    http://carcapsule.com/outdoor-carcapsule/
    I️ use their indoor version and it is fantastic. Never had any issues. I️ was speaking with the manufacturer and they think the hum of the fan keeps rodents away.
    Mike
  19. What is the surface it will be sitting on ? Gravel is the worst. Do not use a conventional tarp, use a breathable cover. Be sure to not allow it to just sit during the winter months. Start it and move it around. Treat the fuel for storage as well as using a battery tender.
    chryslerfan55 and Bruce Fischer like this.
  20. oldsman41
    oldsman41
    i really dont like storing cars outdoors. can you afford one of those portable garages they sell at menards or harbor frt i think 199.00. im lucky enough around where i live there are places will store indoor heated for 75.oo a month, if you live where the ***es down the street loves to ***** about storing cars on the property, thats an option here.
  21. patterg2003
    patterg2003
    I have my car in a car bag inside a heavy duty portable garage that I put a floor in. If you put a car in a car bag it has to have all the fluids removed otherwise battery and moisture is enclosed with metal. If one looks at the cost of car bag and a decent portable then there must be somewhere the car could be stored inside. We have a couple local places that make winter storage available as their businesses are summer. They will take in campers, boats, RVs and cars. I know that it costs about $150 a winter for my friend to store his 36 ft camper inside at an old ice rink. The local agricultural club has large buildings and take in winter storage as well for about $150 for a camper for the winter. Both call when they want to empty the building for their summer use. Ask around. There may be a seasonal business with space for your car.
  22. gene-koning
    gene-koning
    My car sits outside year around. In the winter, you need a moisture barrier between the car and the ground. Gr*** is the worst. Any kind of cover on the car will kill the paint in a year. If you can afford it, inside storage would be better, and your car insurance may require it to keep the coverage. Gene
  23. Mr48chev
    Jazz1 showed exactly what I was thinking of in his post #13. One that has a vapor barrier below the car and a real sturdy portable carport that fits somewhat close to the car but doesn't let anything touch the car and is designed to shed snow, water and wind. You don't need room to work inside you just need enough room around the car to get out of the car when you back it in. From experience the bigger portable car ports either get blown away or don't shed snow and collapse.
    The round top ones aren't cheap but look a lot sturdier than the other ones. https://www.tractorsupply.com/tsc/p...oundtop-instant-garage-sandstone?cm_vc=IOPDP1
  24. blowby
    blowby
    from Nicasio Ca
    Interior Desiccants
  25. AldeanFan
    AldeanFan
    Best thing i did was buy an enclosed trailer.
    Now I have a safe dry place to store a car, and a trailer available whenever I need.
    I take the wheels off one side to discourage theft.
  26. Clay Belt
    Clay Belt
    Live in Florida
    49ratfink likes this.
  27. bobss396
    bobss396
    Mine stays indoors, but I drive it quite often no matter how cold. I was out Saturday with it, 22 and windy. Being outside, it would be a mouse and squirrel duplex.
    chryslerfan55 and Clay Belt like this.
  28. Hot Rods Ta Hell
    Hot Rods Ta Hell
    We need details of the car and your living situation.
    Everyone is answering as if you have a finshed (painted) driving car and reside in a single family home with property to build a portable shelter.
    Is the car running/driving/painted? Or a project car?
    Do you have room to build an on site shelter, or are you in a HOA district or condo? Do you have a carport or a garage (full of stuff that can be cleaned out to make room for the car) as an option?
  29. AldeanFan
    AldeanFan
    Put the word out to your friends that you're looking for storage.
    Only once did I have to park a car outside for the winter, there's always someone with an empty garage who'd like a few extra bucks in their pocket.
    The year I did park my ot convertible outside, I didn't do anything special.
    It was parked on gravel,
    I didn't cover it or put anything special in it.
    I did start it up and drive it to the end of the driveway and back a few times once a month. That kept everything moving freely. I don't drive the old cars after they start salting the roads until after a few good rains in April, but with winters here I normally drive them till November so it's only 5 months I'm off the road.
  30. jazz1
    jazz1
    IMG_2678.JPG IMG_1324.JPG The round type of wigwams do shed the snow however you have to shovel it away from sides as it builds up and puts pressure on walls. My first cover lasted 4 years. New cover was $200 so cheap storage IMO
    With poly on floor I occasionally sandblast in there during warmer weather
