Technical what tire to run on the back of 32 ford highboy in 15 inch?
Discussion in 'The Hokey Ass Message Board' started by bodymanmp, Nov 12, 2017.
  1. bodymanmp
    bodymanmp
    what is the best tire to use in 15 inch on the back of 32 ford highboy?
  2. DDDenny
    Big ones!
  3. HOTRODPRIMER
    HOTRODPRIMER
    It really depends on the look your going for,personally I prefer the tall skinny tires unlike Denny,he likes the 6o's style steamrollers! :D HRP
    lothiandon1940 likes this.
  4. robracer1
    robracer1
    285/70/15 if your rim is wide enough. DSC02873.JPG
    Texas Webb and verno30 like this.
  5. Mr48chev
    Skinny or wide they have to be tall enough to fill out the wheel well opening right. From experience that wasn't all good steam roller wide tires on hot rods love to hydroplane on wet roads at all the wrong time if you plan on driving further from the garage than you can beat a rain storm home from
    It gets a bit hairy running 70 or better on a strange section of highway after a rain storm and hitting that one low spot where water doesn't drain off well with wide tires. Had a guy describe my spin out spin by spin on the CB while I was spinning and going into the bar ditch and then driving out one time. Truck spun out three different times with those tires on it.
    Best thing I can suggest is start collecting inspiration photos of highboys with tires you like the looks of and go from there when the same size tire keeps popping up looking just right.
  6. Mr48chev
    Man that 285 70 is a beast of a tire but doesn't have that race only super wide look to it.
  7. KoolKat-57
    KoolKat-57
    from Dublin, OH
    KK
    Texas Webb and dana barlow like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. Kiwi 4d
    Kiwi 4d
    Well we really need more info here as you know there are 100s to choose from.
    Coupe, Roadster , pickup???
    What is your desired outcome ?
    If it were my roadster it would be like Moriarty says.
    Moriarity likes this.
  10. wheelguy
    wheelguy
    BF GOODRICH 285 / 70/ 15 > cost about $225.00 EACH.
  11. ROBERT JAM
    ROBERT JAM
    Bias or radial?
  12. nonipshere
    nonipshere
    8.20 x15 bias for that true hot rod nostalgia look.
    lothiandon1940 and Moriarity like this.
  13. lothiandon1940 and akoutlaw like this.
  14. PONTNAK123
    PONTNAK123
  15. A Boner
    A Boner
    It's hard to find a radial tire taller than 29" that isn't real wide. And 29" tall is a little on the short side for a 32 hiboy.....30-31" tall is definitely better. Any recommendations that are actually in stock as of late 2017? If your hot rod has a tall tire in the back, better hope they are not wearing out, because chances are they are no longer being made in load range C or D, usually just E, which is a little too stiff......do some checking!
    Forgot to mention.....plenty of these tires have horrendous looking sidewalls too.
  16. verno30
    verno30
    I'll also vote for "it depends on the desired look."
    I've used 8.20-15's and 285/70-15's.
  17. lucky ink
    lucky ink
    I'm runnin 31 10.50 15s Little noisy but do the trick.
  18. deucemac
    deucemac
    Firestone 14x31 double diamonds from Coker!
  19. It's Hard to find the width and height you want that isnt mud tread 4x4 stuff.
    Like the 31x10.50 stuff.
  20. lothianwilly71
    lothianwilly71
  21. lothiandon1940
    lothiandon1940
    P235/75 R15 when I'm running the steelies. 20171112_180732.jpg 20160905_120745.jpg 20170611_070856 (1).jpg
  22. lothiandon1940
    lothiandon1940
    285/70 R15 with the Americans. Jalopyrama 7..my roadster.jpg 01152013_0004.jpg 08262015_0001.jpg
  23. lothiandon1940
    lothiandon1940
    Yeah, I know..........................radials.:rolleyes:
