Features Custom cast tail light housings for '50 Pontiac lights
Discussion in 'Traditional Hot Rods' started by fourspd2quad, May 21, 2017.
  1. brigrat
    brigrat
    from Wa.St.
    Factory location for '36 Ford....................................
  2. TagMan
    TagMan
    Below the trunk lid for my '36 Ford.
  3. fourspd2quad
    fourspd2quad
    I am honored that you would say that. Thank you so much!
  4. fourspd2quad
    fourspd2quad
    I guess the split is 50-50. I have designs in the works for both cases, should have parts in a few days.:)
  5. fourspd2quad
    fourspd2quad
    Here is the tail light bucket that will allow any of my bezels to mount to a tail light stand. They are being shown here mounted to a model A stand but will mount the same for '36 stands and other flush mount setups. The buckets are cast also.
    IMG_3570.JPG IMG_3579.JPG IMG_3580.JPG IMG_3581.JPG IMG_3582.JPG IMG_3583.JPG
    catdad49, JUNK ROD, robracer1 and 3 others like this.
  6. brigrat
    brigrat
    from Wa.St.
    Now I am afraid if I buy a couple you'll come out next week with something cooler, there's no end that I can see!
    brEad likes this.
  7. brady1929
    brady1929
    Very cool!
    Saxman likes this.
  8. fourspd2quad
    fourspd2quad
    Thanks Big D. The bezels are meant to mimic the '36 Desotos. They are not a replacement and work with standard '50 pontiac tail lights. They are a larger diameter than the factory desotos.
  9. TagMan
    TagMan
    They look nice !
  10. fourspd2quad
    fourspd2quad
    Hi gang please check out my latest designs that I put in an auction for Tiger in the main forum.
    Thanks!
    tb33anda3rd likes this.
  11. fourspd2quad
    fourspd2quad
  12. fourspd2quad
    fourspd2quad
    My latest short housing design for model A thru '36. They measure only 3.25 front to back.
    dwollam, David Gersic and brEad like this.
  13. fourspd2quad
    fourspd2quad
    dwollam and David Gersic like this.
  14. fourspd2quad
    fourspd2quad
    The mounting surface on these bullets are designed after the '37 ford tail light so they will mount on the stock '37 stands and the Socal stands. They will also mount on modified model a stands.
  15. Corvette Fever
    Corvette Fever
    from Michigan
    Your work is absolutely beautiful......makes me wish I had a car they would work on[emoji41][emoji41][emoji41]
  16. scott51
    scott51
    **** that's cool, are you running some kind of sand casting simulation before you do the 3D print?
  17. fourspd2quad
    fourspd2quad
    No I learned by trial and error. I my career in the corporate world I used mold flow ****ysis software for injection molded part design and I know it is used in die casting. Those are similar processes where the plastic/metal is injected under extreme pressure to force it into thin sections of the mold cavity. Sand casting is a gravity feed process where thin sections are prone to not filling due to lack of pressure to force the molten metal into thin sections before it freezes and shuts off which is referred to as a miss run. Areas of a part that tend to be thin need to the feed gates to be nearby so they can get that hot metal before it cools.
  18. fourspd2quad
    fourspd2quad
    Fellas this is my new "Desoto 2" style bezel design with just a "bit" of at***ude.:mad::mad:.......Grrrrrr......
    catdad49, dwollam, 55Deso and 6 others like this.
  19. waxhead
    waxhead
    from West Oz
    And here they are fitted to my pickup. Arrived today, great quality and fit well. :)
    catdad49, ROUXGAROUX, brEad and 2 others like this.
  20. fourspd2quad
    fourspd2quad
    They really look great Scott! Thanks for posting the pics.
  21. Mika123
    Mika123
  22. willys36
    willys36
  23. fourspd2quad
    fourspd2quad
    Thanks Mika for the pics! I've got some professionally polished ones now.
    catdad49 and robracer1 like this.
  24. fourspd2quad
    fourspd2quad
    Here's my latest housing design for the Pontiac lights.
    catdad49, chop job, brEad and 2 others like this.
  25. brigrat
    brigrat
    from Wa.St.
    You make it all look so easy ......................................................
  26. fourspd2quad
    fourspd2quad
    It isn't but thanks Brigrat!
