Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. Wow is all I can say. I live to close not to come up and see this flatty run on the strip...
  2. roseville carl
    roseville carl
    Well well well..................
  3. loudbang
    IT IS ALIVE :) Sounds Real Good.
    1947knuck likes this.
  4. greaser
    greaser
    Sounds pretty strong Carl. How many wake ups till you carry the front wheels thru 60 feet?
  5. roseville carl
    roseville carl
    189 but whose counting......... course there will be some test n tune as soon as we can make it!!!!
    greaser and loudbang like this.
  6. 64 DODGE 440
    64 DODGE 440
    from so cal
    Yeah Buddy! Sounds good.
  7. Great stuff Carl
    You're going to find that your new injector is going to make this thing a whole lot faster! Faster equals more fun! LOL
    When you get to tuning it - if you need any help, let me know. Did you do a leakdown on the spool valve - to set the leakdown - or just manually getting it going. How many lb spring do you have in your idle poppet?
  8. roseville carl
    roseville carl
    Na Dale i didn't do a leak down, 5-6 spring on Idle poppet, .120 main jet, .011 nozzles
    and she shure sounds great need to get some seat time and TnT
  9. Tell you what Carl - I will get out my fuel injector formulas and do some calculations on nozzles, main jet, etc.. One thing that is a problem is that we have no idea as to what your pump flows. Which version is it - is marked on body as to the size. That may give me enough for a ball-park estimate as to where to start. Also, I can't remember if that is a Hilborn or an Enderle pump??? Having a 'leakdown' gauge setup to set the spool valve is a good idea - otherwise you're really guessing as to how much is going through at idle.
    It seems to me that four .011 nozzles will be way too small. On the FlatCad on gas, we ran eight .026 nozzles and about a .108 pill at 15 lbs of boost (372 cubic inches - 570 HP).
  10. roseville carl
    roseville carl
    oops 4- .022 nozzles, Hillborn 1/2 851 pump, 304 CI
  11. roseville carl
    roseville carl
  12. roseville carl
    roseville carl
    Pump is out for calibration should have it back tomorrow or monday Dale..........
    j-jock and loudbang like this.
  13. roseville carl
    roseville carl
    Well somedays ya cant find the fitting you are looking for so..... what to do?
    remove everything that doesn't like what ya need,
    And presto grigeo...... a fitting emerges.....
    beats the hell out of the mickey mouse adapter I had on it...............
    Countn'Carbs, j-jock and loudbang like this.
  14. blowby
    blowby
    from Nicasio Ca
    Wow, nice. Did you cut the threads with that die laying there or a bit?
  15. roseville carl
    roseville carl
  16. roseville carl
    roseville carl
    Hummmm I like it........
    loudbang, greaser and 64 DODGE 440 like this.
  17. roseville carl
    roseville carl
    Got the info back on the pump flow Dale
    2000 rpm 7psi 1.02 gpm
    4000 rpm 29psi 2.68 gpm
    6000 rpm 62psi 4.09 gpm
    8000 rpm 100psi 5.18 gpm
  18. Gonna burn a lot of fuel when you spin that flattie up to 8000....................................
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    Just don't forget the dust pan Carl. So when ya gonna spill some nitro in the tank?
  20. roseville carl
    roseville carl
    one thing at a time Tom, one thing at a time............
    loudbang and 64 DODGE 440 like this.
  21. 64 DODGE 440
    64 DODGE 440
    from so cal
    Everything in moderation and lots of it. ;)
  22. roseville carl
    roseville carl
    Oh Oh........ time to hide the vodka bottles................... Details latr
  23. 48fordnut
    48fordnut
    Sure starts easy.
  24. roseville carl
    roseville carl
  25. Hey Carl - over the Holidays I've been working on a software application to help with MFI tuning - and ***ociated conversions back/forth to EFI (which is for my own usage). Now there are a lot of simple applications out on the WEB, but they don't have all the stuff I want/need.
    So - I decided to take all the math and write my own application. It is in the early stages, but I think it can help you even as is . . . as it has calculations for things like air density changes -- to automagically calculate the approximate main pill changes to account for how the air changes. Anyway - will package up a version over the weekend and get it to you. This is written for a Microsoft Windows application world - hopefully you have a PC that is running Windows 7 or better? Let me know . . .
    B&S
  26. roseville carl
    roseville carl
    Windows 10 Dale.......
    grapeboy and loudbang like this.
  27. roseville carl
    roseville carl
  28. roseville carl
    roseville carl
    Well well thanks to Dale Hayes and his info we are well on our way to burnin corn squeesins.......
    loudbang, greaser and grapeboy like this.
  29. cowboyinachair
    cowboyinachair
    from colorado
    damn that sounds good
    loudbang and greaser like this.
  30. roseville carl
    roseville carl
    Yea Cowboy too bad my camera battery went dead or the video would have been longer, she really lites my fire now....got a grin from ear to ear........more video later.....
