Projects 40 Coupe build
Discussion in 'The Hokey Ass Message Board' started by 1940Coupe, Oct 27, 2017.
  1. 1940Coupe
    1940Coupe
    Thought I'd share the build of my recent purchase.
    Bought from a great bloke in Iowa in June. Shipped back to the UK and collected in July.
    Parked up for over 50yrs with virtually zero rust and a rebuilt Flathead. Plans for it include, 4 bar setup with 9" axle, IFS, coil overs all round, tuned up flathead(edelbrock heads,dual 97's,stainless exhaust ), with Chevy T5,new steel wheels
    Hopefully have it up and running asap
  2. bangngears
    bangngears
    from ofallon mo
    Ifs with a flathead? Some how that just aint right. IMO
  3. 1940Coupe
    1940Coupe
    I know it’s not going to be to everybody’s taste but i want something that will drive decent and keep up in modern day traffic
    arkiehotrods and LOU WELLS like this.
  4. Nailhead Jason
    Nailhead Jason
    It will be a nice ride, I don't get the IFS. but to each his own. Straight Axle cars to me drive and steer better than the IFS cars. just need to drop the axle and add a sway bar. I dig the worn paint. looks just like the paint on my 39.
  5. 1940Coupe
    1940Coupe
    I know a lot of people won’t agree but hey ho. All I’ve done with the paint is machine polish it.
  6. bangngears
    bangngears
    from ofallon mo
    I have had both under a 40 and to me the straight axle was as good as the ifs. Just need to add or remove spring leafs to get desired ride.
  7. 1940Coupe
    1940Coupe
    Must admit the 38’ I had a drive in before buying this one drove pretty decent. Brakes were **** and it needed another gear.
    Could be worse and it could have a 350 Chevy install
    38nailhead and arkiehotrods like this.
  8. 2935ford
    2935ford
    Your car.......so, your way! :)
    rockable, LOU WELLS and arkiehotrods like this.
  9. 1940Coupe
    1940Coupe
    Pretty much my thoughts. Nobody sees the underneath. It’ll still look original apart from the bigger tyres
  10. 40FORDPU
    40FORDPU
    Congratulations..nice car!
    lothiandon1940 and arkiehotrods like this.
  11. dwollam
    dwollam
    I love the Standard '40's!
    Dave
  12. buzz4041
    buzz4041
    from Texas
    Nice one have fun with it
    arkiehotrods likes this.
  13. Kan Kustom
    Kan Kustom
    Another 40 build to watch. Just keeps getting better around here.
  14. arkiehotrods
    arkiehotrods
  15. i.rant
    i.rant
    Welcome to the 40 owners fraternity. :)
    tomkelly88 and lothiandon1940 like this.
  16. The 39 guy
    The 39 guy
    I will be following your build. I hope you keep us entertained with frequent posts.
    i.rant likes this.
  17. 1940Coupe
    1940Coupe
    I’ll do my best.
    Engine/gearbox in for final time hopefully. Clutch all connected up and working. New shoes and brake hardware in the 9”.
    About to start and finish the brake lines.
    Plan is to have the ch***is all plumbed and to have the rebuilt engine up and running before I put the body back on.
    lothiandon1940 and The 39 guy like this.
  18. 1940Coupe
    1940Coupe
    Things moving along again.
    Brake lines are nearly done. Propshaft installed.
    It'll be time to put the body back on soon image.jpeg image.jpeg image.jpeg image.jpeg
  19. 1940Coupe
    1940Coupe
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg Went along to the Cl***ic Car Show at the Birmingham NEC on Saturday and saw a lovely 39/40 coupe in original condition.
    Unusual as it had 39 lights/dash
  20. The 39 guy
    The 39 guy
    That show sure attracted a lot of people! The coupe in your pictures appears to be a 39 with a 40 trunk lid. What is really interesting is the windshield. The 39 windshield was a tip out type.
    39 Deluxe with crank open and close windshield.
    The convertibles and woodies had this divided windshield arrangement.
    The car you photographed appears to have been customized quite a bit as many 39 -40 Fords have. This one appears to have been well done. One of those modifications you don't always pick up on right away. It should be a good modification to have in a climate that has a lot of rainy days.
  21. 1940Coupe
    1940Coupe
    Trial fit
    For some reason the pics are back to front 2315F401-B30D-4C18-B72D-EA969BFF6D26.jpeg 3577C9A1-2F9A-42FB-9A41-D08F2B66AF72.jpeg
    2CF2E009-A0F6-4876-9AB3-DFB4C2B5551C.jpeg 5CE27F67-0DC0-4CE0-BF24-5663352CDE35.jpeg 3D003BAD-2B4D-48D6-A75D-E4277220FA24.jpeg
  22. redroaddog
    redroaddog
  23. Sheep Dip
    Sheep Dip
    from Central Ca
    This will be a real nice driver for you, when completed drive the wheels off it.
    Mines been on the road right at 1 year now and I've put 9800 mi on it. Weather permitting it's my daily driver.
    47ragtop likes this.
  24. 1940Coupe
    1940Coupe
    I plan to use it as much as possible. Protecting the underside and fender arches as well as I can
  25. 1940Coupe
    1940Coupe
    Couple of hours with a wire wheel and wire brush and it’s probably better than when it left the factory.
    Should be good for another 70+ years
    12FCB13A-5197-47CB-894E-92CFE355BCF1.jpeg 687577D9-7350-48A8-9AB5-2C13A7026854.jpeg 974DC217-F5B4-49CB-BD91-17CFF62C2477.jpeg
  26. 1940Coupe
    1940Coupe
    Seems to be going a bit slow at the moment. Little jobs seem to take ages.
    Been doing the interior and getting things ready for bolting the body back down.
    Dynomatted the whole of the interior and then 6mm closed cell foam on floor and doors
    Having the exhaust made this weekend so first start is getting close
    chevydriver, brEad, catdad49 and 6 others like this.
  27. gdaddy
    gdaddy
    from nw fl.
    looks good , keep at it .
  28. fiveof10
    fiveof10
    Super car, great job, you are really going to enjoy driving it,
  29. 1940Coupe
    1940Coupe
    Exhaust all finished. 2" Stainless System with no mufflers
    Just got to pull the motor again to install a full flow oil setup then it'll all get bolted back down for good hopefully
  30. Sheep Dip
    Sheep Dip
    from Central Ca
    Hey 40 Coupe looking at your frame/exhaust pic's made me think of something that might help you in case you experience a problem I had.
    I'm running the same 7" dual diaphragm brake booster and fought my brakes dragging for a bit before I finally figured out what was going on.
    I put all the proper clearances between pedal rod to booster and booster to M/C and good strong return spring on my pedal, everything would be fine while everything was cold so to speak, then when operating temps escalated the brakes would start dragging. Had a hunch, touched the booster and it was hot....real hot!
    My exhaust runs thru wrapped fenderwell headers and then out board under my running boards so that was not the problem (so to speak) heat source, it was solely the engine compartment heat escaping under the car.
    Long story short and a lot of head scratching..... a lot of heat is generated under the hood and escapes under and thru the frame, It was heating up my booster up which worked perfect when cold, then it would heat up making the diaphragms more "Pliable" so the normal engine vacuum was slightly applying the brakes.
    I basically doubled the recommended normal clearance on the diaphragm to M/C clearance and the problem went away.
    Just my experience, thought it could possibly save you some grief.
    catdad49 and Ravenwood like this.
