Projects 1955 Chevy Southeast Gassers Build
Discussion in 'Traditional Hot Rods' started by Zak Hall, Oct 29, 2017.
  1. Mike Colemire
    Mike Colemire
  2. Higgy's Henry
    Higgy's Henry
    You guys don't need touques!! You'll have it done before it gets cold at this pace!!! Killin' it!!
  3. Zak Hall
    Zak Hall
    We're trying to get it done! Missed you at Shady Side bud
    Higgy's Henry and loudbang like this.
  4. Zak Hall
    Zak Hall
    IMG_0991.JPG IMG_0992.JPG IMG_0993.JPG IMG_0994.JPG IMG_0995.JPG Well it's naked now! Down to bare metal, and other than a few spots around the windshield and needing front lower quarter patches it's a solid old car.
    Vic Walter, EVL401, Outback and 10 others like this.
  5. Zak Hall
    Zak Hall
    IMG_0984.JPG IMG_0986.JPG IMG_0983.JPG A few before pictures of our hillbilly body stand setup. Also, if you can't hold your racecar up with one hand, it's too heavy!
  6. Butch M
    Butch M
    going to be a good one
    loudbang and Zak Hall like this.
  7. jim snow
    jim snow
    Wow! That body is incredible. Thanks for the photos.Snowman
  8. thirtytwo
    thirtytwo
    What's the reasoning with a 200 lb weight break for injection?
  9. southcross2631
    southcross2631
    To get more people to run the more traditional looking stack injection over modern intakes and carbs.
    Stacks are a little more difficult to tune until you get a handle on it. Then it becomes easier than carbs.
    AHotRod, hendelec, mad mikey and 2 others like this.
  10. catdad49
    catdad49
    Great work so far, you guys will be testing before spring. I'm in for this, Carp.
    Zak Hall and loudbang like this.
  11. Rex_A_Lott
    Rex_A_Lott
    Thanks for taking the time to post pics and comment. Looking forward to following your progress.
    loudbang, Zak Hall and Hang'emHigh like this.
  12. loudbang
    This one going to have Green windows? :rolleyes:
  13. Zak Hall
    Zak Hall
    We have enough green to do them I think, so maybe!
    catdad49 and loudbang like this.
  14. Zak Hall
    Zak Hall
    IMG_0680.JPG I think we've decided to name the 55 Home Grown also, but paint it green and do the lettering like dads altered he built and raced.
  15. loudbang
    No wonder you do so good, it's in your genes LOL
  16. You guys are more patient than me - If me, l woulda had the rear wheel wells cut out already even just to set the tire in place when you had the nose setting on it - incredible body!!! - looking forward to reading this one - Thanks!
    hendelec, loudbang and Zak Hall like this.
  17. Zak Hall
    Zak Hall
    IMG_1086.JPG IMG_1089.JPG IMG_1090.JPG Got the rust cleaned off the chromoly rollcage and got it all painted black to keep that from ever happening again. It took a solid day of hand sanding to clean it. Lol. Now we can start moving bars around, and finish weld the cage.
  18. Hang'emHigh
    Hang'emHigh
    Great to see you and your Dad knocking out this project together!
    swade41, hendelec, loudbang and 2 others like this.
  19. mad mikey
    mad mikey
    Ahh Yes, another g***er build with you guys. I will be watching this one for sure. Thanks Zak, and your dad for taking us along . You guys are going to have a busy winter. LOL. Mike.
    loudbang, Hang'emHigh and Zak Hall like this.
  20. Zak Hall
    Zak Hall
    We're working on it! Lot of stuff to do. Ordered his axles, spool, rear wheels, and ladder bars/brackets. Getting ready to stick his rear end in it.
  21. southcross2631
    southcross2631
    Better shoot some something on that body before you have flash rust all over it. Epoxy primer would be good. Setting on that cold bare concrete, it will attract moisture.
    Project is looking good. Wish I had someone to work on my g***er project with. Not my old man though, he was an a--hole when it came to hot rods and race cars. Consider yourself very lucky.
    8bbl427, 48fordnut, hendelec and 5 others like this.
  22. Zak Hall
    Zak Hall
    Yeah were gonna put some epoxy primer on the body soon. Where we got it dustless blasted, the water solution has some rust inhibitor in it so we've got a little time.
    Hang'emHigh, loudbang and mad mikey like this.
  23. rd martin
    rd martin
    from indiana
    bad ***! were watching!
  24. southcross2631
    southcross2631
    I had a truck Dustless Blasted. The rust inhibitor works pretty good. I like the Dustless Blasting process.
  25. Zak Hall
    Zak Hall
    It definitely beats sanding, grinding, and wire brushing.
    loudbang and hendelec like this.
  26. Zak Hall
    Zak Hall
    IMG_1177.JPG IMG_1178.JPG Dads stuff came from strange today. 40 spline gun drilled axles, spool, and 5/8 studs
  27. Higgy's Henry
    Higgy's Henry
    Those things are tree trunks!!!
    loudbang and Hang'emHigh like this.
  28. Zak Hall
    Zak Hall
    Yeah they are huge! They're bigger than what's in my car!
  29. zeph4057k
    zeph4057k
    looks really cool. I cant wait to see more !!!!!!! that body looks really good.
    Zak Hall, Hang'emHigh and loudbang like this.
  30. JimmyD3234
    JimmyD3234
    from PA
    K@@L Going to BAD *** :cool: :cool:
