Customs Sealing a rusting body seam (59 Chevy wagon)
Discussion in 'The Hokey Ass Message Board' started by Vorhese, Nov 13, 2017.
  1. Vorhese
    Vorhese
    I've got this here rusty seam that's progressively getting worse. What is my best option for a)stopping the rust and b)sealing it without repaint?
  2. squirrel
    Park the car inside.
    LostBoy and Texas Webb like this.
  3. 19Fordy
    19Fordy
    Take a small artist's brush and 'paint" some OSPHO on the rust so it seeps down inside the seam.
    If you can remove the interior panel also spray the underside with OSPHO. OSPHO neutralizes rust.
    You will have to repaint the rusted area. Can you carefully pick out the old sealer and reseal it. Sadly, that's a rust area that only gets worse, but you can slow it down.
  4. oldolds
    oldolds
    Find an old lamp on the beach, rub it, ask the genie that comes out to repair it! That is about the only way to fix that without getting in there and fixing it.
  5. ceege
    ceege
    from NW MT
    Fix the rust. Seal it. Don't paint it.
  6. Vorhese
    Vorhese
    I wont be repainting, not now. I'll try the OSPHO to neutralize. I was thinking a very tastefully done, small run of white exterior caulk to seal it. That work?
  7. squirrel
    If you get the rust and old sealer out of it first, and use auto body seam sealer, and then paint the affected area, it might work. Otherwise, it will just get stained from the rust, probably trap more moisture, and cause more problems later on.
  8. Deuces
    Deuces
    How about some pictures of the wagon please...... Thanks!:)
  9. Bandit Billy
    Bandit Billy
    Maybe POR-15 or rustoleum pin striping?
  10. Vorhese
    Vorhese
  11. Bandit Billy
    Bandit Billy
    nice long roof, cool pipes! You'd only have to repaint the top. That's no so bad.
  12. BJR
    BJR
    Nice Wagon!! Dig the old caulk out sand the rust, treat it with something to kill the rust, hit it with epoxy primer, caulk it with seam sealer, and repaint the white. Then it's done right and will not come back to haunt you.
    nonipshere and tb33anda3rd like this.
  13. Very nice wagon! It deserves to be treated right.
    The seam sealer has failed.
    The failed seam sealer needs removed, the rust treated (ospho) and then primed
    resealed with automotive seam sealer and then painted.
    That's about 8 hrs work total over about 4 days for dry and cure times for anyone familiar with the process.
    Bathroom or house caulk will make the problem worse and 10 much more expensive to repair later. If you want to buy yourself time, you can put a nice coat and bead of Vaseline on it and reapply as needed to seal it
    tb33anda3rd likes this.
  14. Gman0046
    Gman0046
    If your not going to do the job right don't do it at all. Definitely don't use bathroom caulking.
  15. tb33anda3rd
    tb33anda3rd
    if you want to try a "better than leaving it" type of way to slow it down do this: take some 2" masking tape and run it on the edge of the seam. just about where it rolls over and then cover that piece of tape with a good duct tape. the masking tape will prevent the duck tape from pulling off the paint. then take a s****er and scratch out the rust and dried sealer that is in the seam. then take a piece of 80 grit paper and fold it so it the edge can be run up and down the seam. blow it out with air. if it looks like shiny metal and the edge of the paint looks fairly straight flow in some rust treatment primer using an artist brush. seam seal if you want. when that dries remove the tape. now run tape just wider than the primer line on both sides of the seam, a 1/16" is more than enough. flow in some gloss white paint with an artists brush. remove tape before it dries. this will slow the rust down. by keeping the repair small and close where the panel rolls over AND the fact it is white doing it like that will be hard to notice "at first glance" by most people. bright sun, nobody will notice.
  16. steinauge
    steinauge
    from 1960
    What he said but use POR 15 instead of "rust treatment primer".
  17. Deuces
    Deuces
    Beautiful wagon!!!!! :)
  18. Latigo
    Latigo
    Better get at it. I spent the afternoon cutting rust out of my current project. It will only get worse.
  19. southcross2631
    southcross2631
    Rust never sleeps. Stop it before you have holes.
  20. Use a hyperdurmic needle to push in ospho , epoxy primer , or por15 .the needle will get it in deeper than a brush or spray .
    Good luck .
    2manyseats likes this.
  21. Terrible80
    Terrible80
    If the OSPHO works, maybe you could make a "dam" outta tape and let it soak in overnight.
  22. Vorhese
    Vorhese
    ok thanks y'all
  23. bobss396
    bobss396
    Any caustic rust treatment and you run the risk of entrapment and it could rust worse from the inside.
  24. Any half way measure is going to be a gamble. An anti-rust treatment that you attempt to work into the seam has to penetrate top to bottom, the full height, width, length of the seam. If you miss a single inch of out of sight area, it will keep rusting out of sight for a while, but eventually in plain sight with more cancer than before. You may have developed a little flex and movement in the seam which can cause early failure of surface repairs. You may be able to remove and/or treat the rust from the backside with out pulling the quarter panels, but from the outside, not so much.
