Projects Roadster top: Black or tan Haartz cloth?
Discussion in 'Traditional Hot Rods' started by flynbrian48, Nov 11, 2017.
  1. Black
    25 vote(s)
    39.1%
  2. Tan
    32 vote(s)
    50.0%
  3. Keep going with Gorilla tape and call it good
    7 vote(s)
    10.9%
Multiple votes are allowed.
  1. flynbrian48
    flynbrian48
    The seat as is, then the pattern I was going to use in plaid, and finally the plaid and red d****d over the seat. I'm not feeling it. Looked good in my head...
    that's the truth. My '36 had cycle fenders, the black top was easy to clean mud and (bird poop) off.
    loudbang, kiwijeff and kidcampbell71 like this.
  2. Shamus
    Shamus
    from NC
    TAN!
  3. jimmy six
    jimmy six
    IMO..... If you need a top. Buy or build a coupe.
    jimmysweden likes this.
  4. flynbrian48
    flynbrian48
    Easy for you to say, from California...;-)
  5. Johnboy34
    Johnboy34
    from Seattle,Wa
    Since votes don't count anyway ;);) mine goes to a darker saddle color to match your brownish saddle color seat. Will go fine with firewall and just don't paint the grill bars. :D:D:D
    loudbang and flynbrian48 like this.
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    Fine. Since white is out, & car has a cream firewall, just go w/a Cream top then & be done w/the matching aspect of it. :D . Then the plaid (black/grey/white?) could work out. In the 60's, things did start getting a bit 'brighter'. :D .
  7. jimmysweden
    jimmysweden
    from sweden
    Brown..
  8. brady1929
    brady1929
  9. dana barlow
    dana barlow
    from Miami Fla.
    Myself,I like tan,as it's cooler in the sun. An really a folding top too me is tobe used for sun or lite rain,and any other time it's ether folded down or left at home=I don't like a top,but if it's got to be used,may as well look fairly good. But black seems to look cleaner longer,so that's some type of point?
    Here is my own I made frame an sewed my self,did a tech on it too HAMB. CrandonPark1.jpg
    loudbang and HOTFR8 like this.
  10. Light color body I like a dark top. Dark body I like a light top , so I voted for Tan. top5.jpg top6.jpg
    dana barlow likes this.
  11. flynbrian48
    flynbrian48
    IMG_3299.JPG IMG_3291.JPG I extended the top to the door post, keeping the canted forward line of the opening, which I like. Setting on the seat, there's a little blind spot but itsss not bad. I think that's the final shape, and I think I lol go with black, tan inside. Now to order material...
  12. For me personally it would either be black or white (cream?). For whatever reason I don't find the tan tops pleasing. But I am sure that it is a personal thing.
  13. Chris
    Chris
    I used 1950's GM white pin point vinyl top material on my car. Very easy to clean. My opinion, has to be white :)
  14. gearheadbill
    gearheadbill
    I've owned a couple of each color (black, tan and not-an-option-white). Black is the WORST choice if you want to keep it pristine clean and Hartz cloth is double trouble. While it washes up nicely, Hartz is almost magnetic to picking up dirt/dust/fibers etc. and then, when it's black, all the **** shows. Go black only if you don't use the car; use Hartz cloth only if you really enjoy scrubbing your top a lot.
    Follow Chris's advice...GM PinPoint vinyl...even tho it's not an option now, it's the best option for your car IMHO.
  15. flynbrian48
    flynbrian48
    You guys are killing me here. Just when I make a decision... actually, I had no trouble keeping the black Haartz top on the '36 clean.
  16. Kiwi 4d
    Kiwi 4d
    Tan appears to give it a more traditional vintage look, black on black perhaps could be viewed as more street rod. On the other hand your wire wheels are a little newer in style so black could work with them.
    flynbrian48 likes this.
  17. Bandit Billy
    Bandit Billy
    Dude, Chris's car look killer with the white top and big white walls. On your car the effect will not be the same. I have a Driftwood tan top on my 34 because I like it. Here is a pic of my car prior to body work still in the black e coat for a look see at tan top on black.
  18. flynbrian48
    flynbrian48
    Well, I never considered white, even in vinyl, from experience it's too hard keeping a white top pristine. And white has to be kept pristine. Your roadster looks great Bandit Billy in black and tan, and I do like a Black and Tan. ;-) I like black, I like tan, I think either one will look good with the look my car has going on. Yeah, black may be a little "street roddy", but the car isn't 40's traditional style, so I think I won't get too much derision if I go that way. I have a set of 15" steel Chevy wheels, with hub cap clips, probably '49 or '50 wheels, that I can also use (I need two more bias ply WW's), and the set of 14" Astro's with WW's on shown in my Avatar. So, I have wheel choices. ;-)
    biggeorge and loudbang like this.
  19. kidcampbell71
    kidcampbell71
    big_thumb_ca22080f3f9c71ce184e16b1e840eac4.jpg 4acac4b1caef00f7c7cdb77df929d3f0.jpg 58c26eb38477fac7c56c7953efdd023d--wire-wheels-roadster.jpg traditional-ford-hot-rod-roadster-1.2-800x800.jpg
    Probably found these, already. OP was black or tan. Maybe the last two are brown, but I think they're black. :) Get your crayons out to change picture #1. Good luck. Great quandry to choose, for such a great ride. Love to have your problem.
  20. GordonC
    GordonC
    Brian just a question. I saw the way you had the tan taped side of the top originally and where you extended it out to the door post. I was wondering if you considered bringing the upper area of the window back to your first top bow (first metal frame with wood - B pillar?) and then coming down to your door post while keeping the frame covered. It might take care of that small blind spot and still look good.
  21. flynbrian48
    flynbrian48
    The blind spot isn't bad with it pulled to the door post. I sat in the car last night with my wife, we can live with it. If like Chris's car the seat were pushed back to the back of the cab, it would be annoying, which is probably why he didn't extend the top's quarter to the door post. I think I've figured out how to make an attachment, would have been good to have pulled the lip forward before paint, hard to do now without it looking like an afterthought. As for Gordon's question, I'm not sure I'd be happy with the window opening having a more vertical line, my personal preference is the forward line as I mocked it up in tape. That's just personal preference thought, it'd work for some.
    I feel like I may be overthinking this, but it's a good problem to have. ;-)
  22. GordonC
    GordonC
    No problem. I get to go through this same thing when I am ready to finish up my top!
  23. junkman8888
    junkman8888
    1. Paint firewall body color. With the firewall one color the body another and the top something else, you've got way too many colors going on.
    2. The color of the top should always complement the color of the interior. Back to the number of colors used on the car.
    3. Change those God-forsaken wheels to either early Ford wires or solids. Or run fenders.
    WillyKJr likes this.
  24. Chris
    Chris
    My top ends where the stock top ended. I wanted it looking like a stock, but chopped top. I have stock bows and irons, all modified, but even the rear window is stock. My upholstery guy really "gets it" and absolutely nailed what I wanted. I have side curtains as well.
  25. A Boner
    A Boner
    image.jpeg This looks way better, just round off sharp corner.....I would do it in white.
    loudbang, biggeorge and Moriarity like this.
  26. A Boner
    A Boner
    image.jpeg White like this.
    Tan is sort of resto-rod......white is a little bit more hot rod.
    Kiwi 4d and biggeorge like this.
  27. Bandit Billy
    Bandit Billy
    Yes, yes he does.
  28. flynbrian48
    flynbrian48
    1. You're en***led to your opinion, but, it doesn't count.
    2. The firewall will remain cream, unless you want to buy it, pull the engine, and repaint it black. If the hood is open, the car is broken, and it won't matter what color the top is at that moment.
    3. I like the wheels, which is why they're on there. If you don't like them, see #1.
    4. I think top is going to be black, so, that's one color, body top, and, and tires.
    5. It won't have fenders. If you think it should, see #1.
    kidcampbell71, loudbang and da34guy like this.
  29. SS327
    SS327
    Go red so it matches the old grille. :oops: Actually I have no opinion it's not my car so I voted for Gorilla tape. I would have voted for Flex-Tape but it was not an option.
    Denny
    Bandit Billy and low down A like this.
  30. Spotweld
    Spotweld
    It’s a personal choice for you. My opinion - Black & Tan goes together well.
