Hot Rods Model A Coupster on '32 Rails Updated
Discussion in 'The Hokey Ass Message Board' started by Dyce, Feb 16, 2009.
  1. Dyce
    Dyce
    fordflambe, Stogy and RICH B like this.
  2. Dyce
    Dyce
    Has anyone put fenders on a model a on deuce rails?
    Stogy likes this.
  3. Dyce
    Dyce
    20171116_110639.jpg 20171116_194645.jpg 20171116_112026.jpg 20171116_112533.jpg 20171116_113918.jpg 20171116_113942.jpg
    I didn't like the top cap having a sharp bend and it was to wide. The top picture shows how I laid out the curve using the outer edge. I made dies to bend the edge, and was able to get the left side welded in.
  4. Dyce
    Dyce
    Welded the rear cap up today. I have some grinding and planishing to do now! 20171118_185312.jpg 20171118_185350.jpg
    I like it better now after slimming it down.
  5. clem
    clem
    With your skills, I’m sure it won’t be difficult !
    Dyce likes this.
  6. Six Ball
    Six Ball
    from Nevada
    Nice work, I'm enjoying this and learning as you go.
    Dyce likes this.
  7. gnichols
    gnichols
    from Tampa, FL
    Dang. That sure is nice work. Gary
    Dyce likes this.
  8. Dyce
    Dyce
    Well I think I'm done hammering on the body for a while. I think it's fender time. I picked up some decent 32 running boards and front fender braces. I have 32 front fenders that are very repairable but nothing for the rear. I shouldn't say nothing because I do have a pair of gl*** 32 coupe fenders to use as a pattern.
    The major work on the body is done and it feels great!!
    The doors still need some work but I really want to see it with fenders.
  9. Dyce
    Dyce
    fordflambe, brEad and Stogy like this.
  10. Dyce
    Dyce
    I got a good start welding the right side.
    Time to start on the left side now.
  11. Dyce
    Dyce
    I haven't updated for a while. I got both tails made and the left side is welded on. The reverse is a little tricky, stretch sides and shrink the corners.
    Then I turned the edge with the pullmax as far as I could and did the rest with hand tools. It required some torch shrinking in the corners.
    With the shape in the panel it was hard to use the pulmax to finish the bead so I made this fixture and added the bead with a chisel.
    This is how the left side looked. I have some fine tuning to do on the shape and welds to finish yet, but it was a great feeling having one fender together.
  12. Dyce
    Dyce
  13. Pete
    Pete
    This is the nicest coupster iv seen, looks just like a roadster but with larger doors.
  14. Dyce
    Dyce
    Thanks Pete!
  15. jackalope
    jackalope
    Very nice build!!!
    Dyce likes this.
  16. JOYFLEA
    JOYFLEA
    Been watching for a while . You are a true craftsman. Keep up the good work . Blue
    Stogy and Dyce like this.
  17. fiftyv8
    fiftyv8
    from CO & WA
    I've never been much of a fan of coupster's going by what I have seen built in the past, but this one has changed my mind totally.
    There is another in Australia that debuted in Japan earlier this year running a flathead V12 which is right up there also but that is a 28/29 version.
    I feel the 30/31 has the slightly better lines and works real well with the 32 frame.
    Your skills are a credit to you and keep posting please.
    loudbang and Dyce like this.
  18. Dyce
    Dyce
    Thanks guys for the compliments. It' been a lot of work.
    Stogy, loudbang and 6inarow like this.
  19. 6inarow
    6inarow
    Nice looking Jeff!!
  20. The37Kid
    The37Kid
    Wow! What a great project, great skills there. Sorry it took so long to find this. Bob
    Dyce likes this.
  21. fiftyv8
    fiftyv8
    from CO & WA
    What front fenders are you using???
    Dyce likes this.
  22. Dyce
    Dyce
    They are 32 front fenders. I have some gl*** 32 rear fenders I'm using as a pattern. It might have been easier to use model a coupe fenders on the rear. I would have been rebuilding where the front mounts to the frame and runnin board. Plus the bead would have to be replaced to match the 32 fronts. I'l have 3 weeks (about 60 hours) in the rear fenders by the time they are done.
    brEad, Stogy and loudbang like this.
  23. fiftyv8
    fiftyv8
    from CO & WA
    Well worth the effort with the fenders and it is a credit to you.
    I just keep hanging out for your next progress posts...
    Dyce and loudbang like this.
  24. Stogy
    Stogy
    @Dyce your a very talented man...interesting journey your taking us on here...you may have said but are you adding aprons between front to rear similar to a A or using the frame and fitting to suit? Looking back at it it looks pretty cool as you have it...I think I just answered my question with my eyes...:D Thanks, great job...
    brEad and Dyce like this.
  25. Dyce
    Dyce
    Well for the most part I'm done planishing the left fender and ran over it with a sander. I used my planishing hammer and set my "portable" ewheel up to do this. It does a good job ironing things out wheeling it sideways. It wasn't fitting in the big wheel.
    The tail could have been a little longer but I'm happy.
  26. rusty1
    rusty1
    Dyce,..I get the 40 Chevy influence, you and your dad had the coolest 40 Chevs
    on the fairgrounds at St Paul years back...always loved talkin with your dad,..good luck on yer project, very nice work...
  27. Dyce
    Dyce
    Thanks Rusty!
  28. sloppy jalopies
    sloppy jalopies
    great job, love the time you put into door and quarter caps [the usual trouble with coupesters]...
    any paint pix ?
  29. Dyce
    Dyce
    I got the rear fenders together and started on the front this weekend.
  30. brEad
    brEad
    Beautiful job on the fenders, you really are talented!
