  1. Mark Hinds
    Mark Hinds
    from pomona ca
  2. DDDenny
    Did somebody say "caption needed".
    "I can't believe what this guy just asked my mother to do".
  3. loudbang likes this.
  4. jimmy six
    jimmy six
    ^^^^ OK Bonnie, Where's Clyde?^^^^
  5. And further to that, it is not the only plane in the picture, there are several at the terminal.
  6. greybeard360
    greybeard360
    1969... rectangular marker lamps. 70 Grille was different.
  7. plym_46
    plym_46
    from central NY
    Based on the shape of the vertical tail, the single tire rear landing gear I think it might be a Boeing Stratocruiser double decker commercial airliner that was a post war development of the B29 Stratofortress. Some still flying as Super Guppy specialized freight haulers.
  8. stude54ht
    stude54ht
    from Spokane WA
    It is C-99, B-36 based cargo plane.
  9. Trojan Horse
    Trojan Horse
    That looks like the Guns of Navarone. :eek:
  10. NOT the Spruce Goose, YB-60 is close, it's the gigantic cargo version of the B-36 Peacemaker.Quite a sight, quite an airplane! Our family went to the Portland Airport regularly, as did thousands of people.It had a huge deck just for gawking.Flying was still amazing in those days.
    flypa38, bramdax, Mark Hinds and 4 others like this.
  11. seb fontana
    seb fontana
    from ct
    Need a larger pic to make a real good opinion....
  12. Vance Hunt's car at Famosa driven by Watus Simpson.
  13. Steel Wheel
    Steel Wheel
  14. Steel Wheel
    Steel Wheel
  15. plym_46
    plym_46
    from central NY
    All production versions of the B36 and variants had multiple wheel rear landing gear
    Pretty sure that's the Boing Factory on Everette bay Washington.
  16. Steel Wheel
    Steel Wheel
  17. Steel Wheel
    Steel Wheel
  18. loudbang
    Tried to help out but when you make it larger it gets all fuzzy :(
  19. plym_46
    plym_46
    from central NY
    14 lbs per cubic inch was the rule for E/ Gas compe***ors.
  20. Steel Wheel
    Steel Wheel
  21. Steel Wheel
    Steel Wheel
  22. DDDenny
    Thanks LB
    Was curious to read the text, the name Don Ringer came up often in the early 70's around the drag racers I hung with, never met him, thought it might be a good read.
