Projects '49 Styleline Deluxe - Project FrankenStyle
Discussion in 'Traditional Customs' started by FrankenRodz, Sep 27, 2017.
  1. Bullet Nose
    Bullet Nose
  2. FrankenRodz
    FrankenRodz
    Fired up the Car and the Exhaust sounds great! Not the typical "rappin' the pipes" sound you associate with a Straight 6, but a deep, throaty bark.
    I did end up installing the Mufflers with the exhaust flowing over the rounded end of the dimples inside instead of at the open end. There was a significant difference in sound depending upon which direction we had them oriented.
    New Billet Tips installed too!
    Bowtie Coupe likes this.
  3. FrankenRodz
    FrankenRodz
    Heater is in!
    The Deluxe Model came with a Harrison Fresh Air Heater. Which is basically a Box connected to the Fresh Air Duct in the engine bay, with the heater Core inside. Well this one leaked and there are no replacements. So I used a modern GM Truck Core and modified the Box.
    The original Core had the Supply and Return on opposite sides and ends. They are side by side on the new Core, so I drilled 2-new holes in the lower back of the Box. Laying a blanket of 1/4" Closed Cell Foam inside the Box for the Core to sit on, with X cuts in line with the Drilled Holes, the Supply and Return pushes through and creates a self seal and covers the remainder of the original offset Hole shown in the picture.
    The Core is thinner than the original, so I used foam bucks to keep it secure. A plug will go in the original lower front Hole. Sandblasted and painted with Satin Hammered Black rattle can, the assembly was reinstalled
  4. FrankenRodz
    FrankenRodz
    The Transmission Access Cover was sandblasted and painted with grey Hammered Finish rattle can, and reinstalled on top of the carpet for easier access in the future. Besides, I think the Interior needed some of the Industrial look that the Engine Bay has developed.
    Okie Pete, Bowtie Coupe and mbrede like this.
  5. FrankenRodz
    FrankenRodz
    10F3FA62-B274-4186-8B2F-E79D13B9D0E4.jpeg 67F1AD1B-814B-485C-8927-2956485B0125.jpeg 2BF5DDAF-9275-47A4-AAD2-806CFF809178.jpeg E47727C2-87CC-4734-B475-0B5EA9663D37.jpeg Lowered 3”, and finally down on the ground!
    This is a repost from what was lost during the Hamb Crash. Trying to remember what posts got lost.
    At the Turkey Run this week, will add new Posts when I return.
  6. FrankenRodz
    FrankenRodz
    Wood Grain Dash.
    Same technique as the other Trim pieces - base coat of rattle can Warm Caramel, with a Black wiped topcoat.
    Definitely easier with the windshield out of the car!
  7. FrankenRodz
    FrankenRodz
    A91856DD-2595-45F1-8DE4-1FE346C6682E.jpeg 297C72EF-FCB6-406C-8BC8-781142269549.jpeg 8EFB65CE-1233-4BA3-A36D-DE4F3104E514.jpeg While I’m down in Florida for Turkey Run, my Brother finished the Dash!
    Good Job! Merry Christmas to me!
    We’ll install the Windshield and Visor next week when I return. Then wrap up the faux patina paint blending I had to do where I rust protected under the roof moldings, and it encroached into the body color.
    Okie Pete, shedzed, Paul B and 3 others like this.
  8. gsnort
    gsnort
    Cheers for your creative work on the heater core. Plus that dash looks grrrrrrreat.
  9. FrankenRodz
    FrankenRodz
    For those who have asked, 215/75/15 Cokers on the Stock Rims.
  10. RMONTY
    RMONTY
    Whacha gonna do with the tail lights? I notice they are absent at the moment.
  11. FrankenRodz
    FrankenRodz
    Stock Repops for the Tail Lights. I'm hand-sanding the body, before Satin Clear Coat, so lights will not go in until the body gets done. I still have to remove the Side Front Fender and Door Moldings, and rust-protect under them, like all the other trim. That will all get masked before Clear Coat. Scored Repop Rocker Moldings for a little more $ than good used ones I was looking to buy, so those will also install once body is complete.
    Now the Shop is full for winter storage, so we'll see how much of the Body I can get done.
  12. verde742
    verde742
    could have flipped them from one side to the other, and upside down : called reversed the spindles. the Old Way, before all the 800 number stuff,
    Loved EVERYTHING YOU'VE DONE AND SHARED..
  13. FrankenRodz
    FrankenRodz
    Thanks! And Great Tip with the Spindles. I’ll remember that for the next Build.
  14. FrankenRodz
    FrankenRodz
    4538D774-7383-41E4-9885-8A450DAE4265.jpeg E62A5F91-25C7-489F-BB09-8AD0BDD78864.jpeg
    IMG_0817.JPG IMG_0818.JPG 72A14354-22F8-4EE0-9F7B-D2E1B5B6E862.jpeg IMG_0810.JPG
    52EFB191-4C46-49D1-8B32-87215C60BCAD.jpeg BEDA8B68-333F-4DD2-A743-B2D0E4F5831C.jpeg
    The Windshield is in, and the Visor is back on.
    The repop Glass fit great but the Center Bar Screws were an inch short, with the new Windshield Weatherstrip. Typically not a problem with newer models that had threaded studs on the exterior trim - simply use a longer screw to attach it.
    However, I couldn’t find long enough sex bolts, so I used these round threaded Tabs, flattened opposite sides so they wouldn’t spin in the channel of the trim, and used traditional screws from the inside.
  15. FrankenRodz
    FrankenRodz
    "The Heat is On". Well the balance of the Heater has been installed.
    Once the Windshield went in, the Wiper Escusions could be bolted down from under the dash, and the Glove Box installed. Then the Heater Blower Motor and Ductwork squeezes-in between the Glove Box and Firewall.
    Reinstall anything out of sequence, and you'll be starting all over! There's no access to the top/underside of the dash once the Glove Box installs, and there's no swing to install that, if the Heater Ductwork doesn't go in last.
  16. 48fordnut
    48fordnut
    simply amazing are your skills. Nothing major just attention to details.
    FrankenRodz and Bowtie Coupe like this.
  17. FrankenRodz
    FrankenRodz
    Happy Holidays!
    The Best Gift I've received is finding this Forum, and all the Great Folks who have lended their support.
    I couldn't have done my '49 Build, FrankenStyle, without all the generous assistance. As this Project nears completion, I'm reminded of how cool the Auto Enthusiast Community is, and no matter how taxing these Builds can be, I can't wait to begin the next one!
    Thank You again for all the kind words and assistance.
  18. Saxman
    Saxman
    Merry Christmas and all the best to you, my friend. I have really enjoyed following your build even though I don’t think I really commented on it. I am starting a ‘52 Chevy Sedan Delivery build, so your skills, ingenuity and imagination have been an inspiration to me and I hope to see more from you.
    48fordnut likes this.
  19. FrankenRodz
    FrankenRodz
    Engine Bay Pics. Thought I'd get a few Shots before the Hood goes back on.
  20. 32 Spitfire
    32 Spitfire
    Old School work here....I’ve been looking at the 50 Chevy models over a year for my next project and this helps a lot! Thanks for taking all the time to share.
    High Noon
    My Blog: https://ontheroadtonowhereville.wordpress.com/
    Bowtie Coupe and FrankenRodz like this.
  21. scrap_metal
    scrap_metal
    Is the next build that woody I believe I see in one of the photos. I think you would kill it with your style of building.
  22. FrankenRodz
    FrankenRodz
    Thanks. That's a '47 Pontiac Woody which was in pristine condition when put in a garage some years ago. The story goes, the garage roof failed and the weather took a toll on the wood. It's all there, but having done another Woody, it will entail disassembly of most of the wood. We actually had mocked-up 1-side with blue painter's tape to turn it in to a 2-door! But, nobody has the $ to fund the Build, so it's FOR SALE. 100% Rot-Free Sheetmetal, but still a lot of work.
  23. FrankenRodz
    FrankenRodz
    Thank You Very Much. Don't hesitate to ask if you have any questions. I particularly enjoy Hunting for Parts/Vendors, and have done over a Year of research, so I'm glad to help.
    Paul B and Bowtie Coupe like this.
  24. FrankenRodz
    FrankenRodz
    8987C562-6DEF-4673-B25F-C0DDE9C710FE.jpeg D5FFEFCB-36C8-4A58-8D77-D0A3DA98F9D0.jpeg 7DCA11FB-276E-4993-8619-A08E94E8D752.jpeg 546562BF-05EF-451E-ADB9-4B4828CB1F50.jpeg E46C1541-FBC2-4A1D-B8C2-9F5B88D43454.jpeg 094F5C58-DEB9-4D0E-9906-F4615CF990CD.jpeg Front Seat is ready to go in, but the Car is so crambed-in with vehicles for Winter storage I may not be able to get the door open wide enough... so here are some Pics in case it has to wait until Spring.
    Speaking of Spring. One Spring was broken so I cut/bent a length of copper line, slid it over each side of the break, and crimped it so it wouldn’t slide out.
    As for the Upholstery, I was able to save the brushed cotton Backs and Aprons. After a light cleaning, I sprayed them with Fabric Dye to even-out the faded color.
  25. Just read you entire build thread, really like your problem solving skills and use of unconventional materials. Looking forward to seeing the finished product.
  26. FrankenRodz
    FrankenRodz
    Thanks BBC. I really like using Unconventional Materials in every Build.
    I've got some really crazy ideas for the Trunk, so stay tuned! Space issues at the Shop have really slowed-down progress, but I'm pushing to get the car ready for March Boston World of Wheels.
    We did get the Front Seat installed yesterday, which was quite a chore, given that we couldn't open the car doors fully.
    All that's left for the Interior are the Door Panels, Window Trims, and Arm Rests, but those will have to wait for the body to be sanded and clear-coated. (I want to pull the Exterior Trim to do the body, and that bolts from inside).
  27. FrankenRodz
    FrankenRodz
    Final piece of the Headliner Puzzle. Just like the B Pillar Custom Pieces, the A Pillars get installed.
  28. Keith50
    Keith50
    I have read this entire thread..lots of great info, and great work. This is a awsome car.
    lothiandon1940 likes this.
  29. BadgeZ28
    BadgeZ28
    from Oregon
    Breath of fresh air style-wise. Thanks for posting it.
  30. FrankenRodz
    FrankenRodz
    Thank You Gentlemen! It's always fun when someone "Gets It".
    Hoping to wrap up the Trunk this week.
    lothiandon1940 and Bowtie Coupe like this.
