Hot Rods 1934 Plymouth Coupe
Discussion in 'The Hokey Ass Message Board' started by captainflight, Nov 18, 2017.
  1. captainflight
    captainflight
    I plan on building a frame or does anybody know what frame might be a good fit. Hard to find an original. My plan is to build a fender-less hot rod with a drop axle front suspension. Any info would be greatly appreciated
  2. paul55
    paul55
    from michigan
    put it on a deuce frame/ch***is.
  3. jseery
    jseery
    from Wichita KS
    I used a 34 Ford frame back in the 60s for a B/A.
  4. RMR&C
    RMR&C
    from NW Montana
    < My '31 Plymouth coupe is sitting on a '33 Chevy frame. Fit like it was made for it.
  5. stanlow69
    stanlow69
    Mopars are like Volkswagens, Corvairs, Studebakers, Ramblers and Corvettes. If a guy has more than two, then more than likely they has a shed full. But they never want to sell anything.
    scotts52, Clay Belt and Texas Webb like this.
  6. captainflight
    captainflight
    Thanks for your suggestions. I think I will be building my own frame, possible starting with a set of deuce rails. My vision is a fender-less drag style coupe. I have a few early Olds rocket engines that I will use to build up a a good strong runner. coupled to a muncie four speed transmission.Thanks again I will post my progress when I get started.
    RMR&C likes this.
  7. micky69
    micky69
    from Ohio
    They are great cars....this was on stock frame.
    kidcampbell71, RMR&C and exterminator like this.
  8. captainflight
    captainflight
    Beautiful! Thanks for the photo.
  9. Godspeed
    Godspeed
    “Hard to find an original” is a big understatement. I have been looking for a 1934 Plymouth PG rolling ch***is for over a decade. The PG was the base model without independent front suspension. I haven’t even found a picture of the ch***is/frame.
  10. captainflight
    captainflight
    There are a co
    Srpm makes frames for these cars but they are very expensive. They have lots of other stuff too.
    Hudson31 likes this.
  11. mr.chevrolet
    mr.chevrolet
    I have the independent front suspension if you want to upgrade when you find a frame.
  12. Godspeed
    Godspeed
    Sorry, I should’ve been more specific. I have a ch***is on my car now (hand built, Mustang II front, narrowed rear). I am looking for an original 1934 Plymouth PG ch***is / Frame without independent suspension..
  13. Godspeed
    Godspeed
    Sorry captainflight, I will stop hijacking your thread now.
  14. this is one of the ***iest fenderless mopars ever
  15. Fedcospeed
    Fedcospeed
    Stock or self fabricated including rails. Perimeter.
  16. stanlow69
    stanlow69
    Did all 34`s have independent front suspension or just certain models. You can also use a 33.
  17. Godspeed
    Godspeed
    The PE, PF, PF**, and PG were all built in 1934, but the PG is the only one that didn’t have independent front suspension. http://www.ply33.com/Models/PG/#highlights
    The PG was the low cost model. It also had no option for a glove box or ashtray (which is the telltale sign of a PG, because the dashboard is just one stamping with flat areas of steel where the glovebox and ashtray could have gone.)
    https://report.oldcarsweekly.com/vehicle/1934-plymouth-standard-pg-model-6-cyl-108-w
    The wheel base in 1934 was either 108” or 114” (for the PE). The PE long wheelbase cars had 2 doors that could be opened, behind the louvers, on the back sides of the hood. The PF, PF**, and PG short wheelbase cars have just louvers.
    https://www.allpar.com/history/plymouth/1934.html
    The wheelbase in 1933 was either 107” or 112”. http://www.ply33.com/Models/PC**/#compare
    Wheelbase between 1933 & 1934: Close, but no banana!
  18. abe lugo
    abe lugo
    If you find a short wheelbase 33 frame, can't you just kick out the front suspension to suit? I mean you will be running a ford style front end you have to change the front crossmember anyhow.
    On 33 the wheelbase length difference it within the cowl and the front suspension. That is why hoods and fenders are specific to the frame. But if you are running fender less. It doesn't matter.
  19. 29moonshine
    29moonshine
    i put mine on a 33 chevy frame with a ford front end
    kidcampbell71 and hot-rod 33 like this.
  20. hot-rod 33
    hot-rod 33
    33 Plymouth frame with c4 corvette front and rear suspension 440/727
