Projects Pounding out a T roadster
Discussion in 'The Hokey Ass Message Board' started by justabeater37, Nov 22, 2017.
  1. justabeater37
    justabeater37
    Well here it is to date. After mocking it up in the corner, creating a plan, and starting to collect parts to build a gl*** roadster, things took a turn. IMG_1279.JPG IMG_1282.JPG While figuring out how to put a floor , seats, and everything in a fibergl*** tub, I thought maybe it would be just as easy to build a steel body instead. Needed to get the frame length sorted out to figure where everything needs to fit in the big picture. IMG_1472.JPG IMG_1474.JPG
  2. justabeater37
    justabeater37
    So I ended up starting to build the basic structure using the gl*** body as the template. I am going to cheat and use a stock firewall, cowl top, and the center back panel just to speed up the process. I am going make the door openings a couple inches longer to aid in ingress/egress. C4D8E8A8-2932-48C2-9C9E-EC292424366E.jpeg 0945896C-0BC0-49B0-BA96-6F387BAD808D.jpeg 3EDB6192-E0E3-43E1-959C-75D762EDE6D9.jpeg E7D02574-6391-4E7A-850A-39D588790123.jpeg 09A0DF2F-EBCA-4CCA-9537-FD11B51CED41.jpeg 3A5AC6FB-03BA-477F-8524-0A8A62E2C5D2.jpeg 05888E3D-DCB0-4059-95AF-7CB058666CD9.jpeg
  3. justabeater37
    justabeater37
    Once the basic structure was established, it was time to start on the body. Spent a whole day shaping the first corner only to have so much tension in the panel I couldn’t get it to lay right. Instead of walking away, I cut it apart and made it 2 panels. I didn’t even attempt the other side in a single piece but I think I know how I could have fixed the first one in hindsight. The second panel only took a couple of nights after work to knock out. Clamped them to the frame to at least feel like I accomplished something. 31B8309F-41B2-4E00-AF5D-7BC634B4090B.jpeg 98CF1809-AD25-4FE9-933F-6E0685433A27.jpeg AE15B6D4-02B1-4329-8EEE-45036BF10F54.jpeg 0AA9AD9E-BFF8-40A0-A342-9D4D1AA7A90B.jpeg 3D5ACDCA-CE98-464E-B73A-9A00EFB91825.jpeg 2442F334-E5BE-4300-9F59-E54ECCACF030.jpeg 9CCEADC5-EF2F-42D0-BE6B-2A53447F5792.jpeg 054D33B8-28A9-444A-8311-D6B2E86178CC.jpeg
    Nailhead A-V8, Flipper, Tim and 22 others like this.
  4. justabeater37
    justabeater37
    As I am still waiting on the cowl top, I decided to rough out the turtle deck made the first side an inch off so need to grow it back yet got both sides roughed out but not perfect by any means 23730665-93E0-4A70-A8DA-B45C6D6BC94E.jpeg DB7A9497-6E67-4A94-85EF-25EEDF89DF0C.jpeg 34EBEAD3-E975-47A0-B41B-A5F7632B3A6B.jpeg 151C97DF-91A7-4929-9B7C-DF4779C6A1AF.jpeg 108E9580-CE27-408A-ABD5-17D8B908570E.jpeg
    Flipper, Tim, Ric Dean and 30 others like this.
  5. timwhit
    timwhit
    Fun watching this!! Go for it, full speed ahead.
  6. Dean Lowe
    Dean Lowe
    This will be fun to watch. Really like the rear frame kick up.
    verde742, mgtstumpy and loudbang like this.
  7. justabeater37
    justabeater37
    It’s was Monday night that I realized I had no way to roll the 3/4” wide beads and no one makes that size die for my Chinese bead roller. I asked a question, got an answer, and made my own adaptations accordingly. I now have a cheap die set to roll my beads. Came out close enough for this hack anyhow. 86DFE658-1333-4D9B-89F1-D603E760D86B.jpeg 974FCFFB-26CE-4035-95E0-B31B7CE0008D.jpeg CAF14C26-93C7-4238-9A1E-A7CF51C336EF.jpeg 12F0B022-7D18-45A9-9C11-40EC532803DC.jpeg
  8. justabeater37
    justabeater37
    And that is where I am at now. Feeling like I am getting sick so going to take it easy for a day or two until I am back at it. By then the cowl top will be here and I can start making the rest of it. I have the rest of the turtledeck laid out but too exhausted to go work on it tonight.
    chriseakin, loudbang and Squablow like this.
  9. justabeater37
    justabeater37
    Would you believe that an inch out of the top in the right spot brings the rear rails up to level? Worked out pretty good. I thought I was going to have to do major surgery to make it work. The rails will even fit inside the turtledeck without bobbing them.
  10. spurgeonforge
    spurgeonforge
    Love seeing sheet metal manipulated, looking good!
  11. bct
    bct
    Love the bead roller die. If you can pull that off you are unstoppable.
  12. flatford39
    flatford39
    Pretty nice work...I see you have that HF English wheel. Can you give a small review of what you think of it. Been considering buying one.
    Saxman and loudbang like this.
  13. justabeater37
    justabeater37
    Needs work. Bottom anvil holder wobbles I just need to weld it. I have had the good fortune of working working on the Baileigh series of wheels and even their off shore one seemed to be better than this one.
  14. AVater
    AVater
    Wow. What a wonderful piece of work, preseverence and creativity!
  15. justabeater37
    justabeater37
    Baileigh has 15% off on Friday. But it would still be 675.75 plus shipping. I would really like one of their EW-30 wheels but it’s $6000
  16. fourspd2quad
    fourspd2quad
    Hey Doug,
    I am going to love following your build! You are crazy talented and ambitious to say the least. Can't wait to see it come together!
    Dave
  17. justabeater37
    justabeater37
    And you should see the taillights I have for it
    brEad and loudbang like this.
  18. Nice job!
  19. Tim
    Tim
    from KCMO
    Awesome
  20. fiftyv8
    fiftyv8
    from CO & WA
    Great work, a breath of fresh air to see how you improvise.
  21. bobbytnm
    bobbytnm
    Thank you for starting a build thread. I saw your posting in the "Who's Building a Model T" thread.
    You are doing some amazing work. Its going to be fun to watch your progress.
    Bobby
  22. Pete
    Pete
    Pretty damn cool
  23. loudbang
    Man it's fun to watch a craftsman grab a bunch of sheet metal and turn it into a hot rod.
    kiwijeff, triman62, bct and 1 other person like this.
  24. 64 DODGE 440
    64 DODGE 440
    from so cal
    I'm following this from the beginning. Nice work.
  25. mgtstumpy
    mgtstumpy
    For every problem there is a solution! Great so far and look forward to seeing this come together. Love that kick up in the frame and side profile with that 32 pressing..
    verde742 and loudbang like this.
  26. evintho
    evintho
    Very nice! I'm following this one!
  27. Koz
    Koz
    Love the siderail profile on the deuce rails. Absolutely perfect! Following this one.
  28. Blue One
    Blue One
    from Alberta
    dana barlow and Okie Pete like this.
  29. 56 Dodge Pickup
    56 Dodge Pickup
    Hey can you post a link to the bead roller die it looks like washers ground to an angle? I will be making some 3/4 beads for the 37 Plymouth I am building. Thank you Hobo Jim
  30. DDDenny
    When I first started reading this thread I thought "this won't end well", boy was I wrong.
    Very impressive and creative use of available resources!
    tomschev2 likes this.
