Project 29 Tudor in Mass.
Discussion in 'Traditional Hot Rods' started by Mikel50, Apr 17, 2015.
  1. Mikel50
    Mikel50
    Sorry frustration was setting in. Did a search, looks like I can trim the grease shields a bit. So that’s what ima doing
  2. vtwhead
    vtwhead
    Mike, have you fit your doors yet? Mine were way off and they had been good at one time. Had to shim the front of the cowl before I tied in the header to the roof panels. Just saying, might want to check them again.
  3. Mikel50
    Mikel50
    I have not. Makes perfect sense too... I’ll make sure I get everything back on and lined up first.
    Thank you
  4. wheeldog57
    wheeldog57
    Yup, I had the same issue except the steering arm I used needed bolts. I gave the dust shield a tune up with a pointy body hammer. Still was a pain getting a wrench in there. (I was fortunate enough to do it twice!)
    Sent from my SM-G930V using The H.A.M.B. mobile app
    biggeorge and Mikel50 like this.
  5. Mikel50
    Mikel50
    I ended up cutting them and adding a 1/8” sliver of sheetmetal just below the rounded bends on the top corners. Mounted the wheel cyl to make sure nothing would interfere. Everything went together great.
  6. sloppy jalopies
    sloppy jalopies
    I have a pair of those inner [? spacers] but mine are round, would that give more room up top ?
    yours if it helps ... pix Tuesday if needed...
    Mikel50 likes this.
  7. Mikel50
    Mikel50
    I think I’m good. This went together fine after I modified the grease shield.
    Thank you !
  8. Mikel50
    Mikel50
    Fitted the steering box and started getting things figured out for my draglink.
    Have what I believe is a solution ... stay tuned [​IMG][​IMG]
    patmanta and biggeorge like this.
  9. tb33anda3rd
    tb33anda3rd
    that will be fun to drive.
  10. Mikel50
    Mikel50
    Not sure how to take that ... :)
    I have some heating and bending to do for sure.
  11. mike bowling
    mike bowling
    Re; steering hoop--PM or text Pete or Ronnie - surprised no words of wisdom? (To traditional for me)
  12. JOYFLEA
    JOYFLEA
    I can’t believe I haven’t seen this build before!
    Your A has come a long way , you too have come a long way . Do you fill like you need a bigger hat for all that knowledge you’ve picked up ? I’m doing an Tudor at this time also .
    I’ll be watching and keep up the good work .you did a great job on the dash . Guys just don’t know how much work goes into one . Did this one for my 42 COE . Plan is to build one for the Tudor. Have fun . Blue
    3BDA9748-5284-4326-A873-0F96170799E6.jpeg 4F0EBB6E-4988-420A-8448-6B99B5B4D01D.jpeg
  13. BenLeBlanc
    BenLeBlanc
    Idk if you took a look at what I have on my car, but I have a drag link end on the steering arm of the spindle and a tie rod end on the pitman arm side. TIG welded and drilled and pinned due to the forged nature of the piece.
    I had to buy a piece of dom tubing from speedway to do it, I believe it was 11/16. I mention this because I was told that the stock arm is nowhere near strong enough even in stock form, never mind if it has a bend. Supposedly bent drag links due to poor roads were common.
    I have no idea of what you were thinking, but just wanted to mention everything I learned for reference
    patmanta and Mikel50 like this.
  14. Mikel50
    Mikel50
    I remember you and Ronnie having to do some odd things. I’ll re read your thread and check it out. I have a stack of dom tubing from a few sets of 4 links a guy gave me. I was going to cut one down and bend that as needed to make things work. Hopping tomorrow I can get to air gas before the long weekend to get the tanks swapped out on the torch set I got.
  15. Mikel50
    Mikel50
    Thank you for the kind words, I very much appreciate that.
    I have to say I have certainly learned a lot being on here and tapping into the different outlets for pictures and knowledge.
    Not to mention the people I’ve met.
    So many people make this **** look so damn easy it kills me ... I just have to keep checking things off the list.
    It’s been an adventure to say the least.
    The dash on your Cab over looks beautiful !!
    I studied that dash and where to make my cuts and I feel like I nailed it first try.
    It was everything I had envisioned.
    Now if I can just do that with the rest of it I’ll be one happy guy.
    Onward and upward !
    brEad and JOYFLEA like this.
  16. JOYFLEA
    JOYFLEA
    For me it’s more like ONWARD THRU THE FOG !
    Mikel50 likes this.
  17. Mikel50
    Mikel50
    I didn't see this portion last night when I replied.
    The draglink in the pictures is an F1 link. It's quite a bit larger in diameter than the stock A. My plan is to use that with the tubing. Hopefully make some progress tomorrow with it.
    Fingers crossed.
    BenLeBlanc likes this.
  18. Mikel50
    Mikel50
    Got the new header in tonight.
    14ga 1x2 box tube cut to length then scribed on the ends and boxed in.
    Removed the old one and made some changes to allow me to run a taller windshield.
    II know I spent a ton of money this year on tools and equipment for the garage. However it is amazing how smooth things go with the proper tools.
    It’s just positioned there. I’ll tack it on in the am. (Have a few small pinholes to fill in)
    Before
    During
    Far as I got tonight
    [​IMG][​IMG]
    Hope everyone has a great turkey day !
    patmanta, JOYFLEA, 30tudor and 5 others like this.
  19. Dick Stevens
    Dick Stevens
    Amen, having tools makes things go so much quicker and easier! :D:cool:
  20. NashRodMan
    NashRodMan
    Looks great Mike!
    Mikel50 likes this.
  21. Mikel50
    Mikel50
    Incredible the difference.
  22. Mikel50
    Mikel50
    Pre Turkey
    Used a piece of 11/16 Dom rube and had 4-1/2“ of real estate to get 8 holes drilled for plug welds plus the end weld at the taper.
    [​IMG][​IMG]
  23. wheeldog57
    wheeldog57
    See, Mike, I didn't even have to chime in. . . You are a smart guy.
    I knew you would figure the steering out. The arm off the box is facing up on your car correct?
    Most I have seen are facing down (including mine) I suggest you turn the steering wheel to verify which way the arm moves before connecting drag link.
    tb33anda3rd likes this.
  24. Mikel50
    Mikel50
    Already done.
    Turned the wheel and it moved the way I need it as it sits.
    Looked at several images of cars online specifically the Mazza Roadster ( love that car)
    Same set up as I have or so it seems.
    I’ll get it sorted out. If I have to flip it I will.
    Hairpins should be far enough out I can get it tucked inside toward the rail.
  25. adam401
    adam401
    How the hell have I missed this thread???? I LOVE builds that are local to me. Car looks ****in sick Ill be following from here on out. If you need any ****ty early parts pm me
    Mikel50 likes this.
  26. Mikel50
    Mikel50
    Haha I’m the knuckle head who bought the banjo wheel off you in 16 at the gathering and told you I was making a clock out of it ...
    or at least I think that was you.
    brEad likes this.
  27. Mikel50
    Mikel50
    Thank you btw.
  28. Mikel50
    Mikel50
    Welp you nailed it ... I spun the wheel with out the link. (In my brain+beer) it looked good.
    Not so much.
    It’s gotta go down ... so it shall.
  29. wheeldog57
    wheeldog57
    biggeorge likes this.
  30. tb33anda3rd
    tb33anda3rd
    i thought you were joking when i saw it facing up, that is why i said it would be fun to drive.
    i installed a new steering cable in a boat i had as a kid, but i installed it with the rack up side down. i tried driving it that way thinking i could get used to it. turning left to go right etc.............i hit a beach at speed..........
    Mikel50 likes this.
