Projects Pounding out a T roadster
Discussion in 'The Hokey Ass Message Board' started by justabeater37, Nov 22, 2017.
  1. justabeater37
    justabeater37
    The bead roller die. Ha. It has some 7/8,3/4 and 5/8 washers. All I did was reamed the smaller washers out to the larger diameter to fit the shaft. Then I jerryrigged it up onto the drillpress. Ground to perfection with angle grinder while spinning in the drillpress. Not exactly OSHA approved, but functional
    barrnone50, Clark, Dannerr and 8 others like this.
  2. justabeater37
    justabeater37
    My shop is pretty low budget. An 8’ brake I paid a hundred bucks for, a throatless shear, a HF bead roller, a HF English wheel, a stump, hammers, a grinder, welders, and the drill press. I have less than a grand into all of it minus the welders.
  3. 56 Dodge Pickup
    56 Dodge Pickup
    Thanks for the info sounds a lot like my shop check out my build thread if you have some time. I think we build about the same way. I will be making some bead roller dies! Hobo Jim
    loudbang and justabeater37 like this.
  4. justabeater37
    justabeater37
    A little turkey day progress 97F5B130-9E8A-4C0F-B03E-D4533F0F1B2D.jpeg 08DF08DC-7892-4D1A-A418-EB8F67CA1CA1.jpeg 3AC0FC04-88CF-4263-88AA-5EE1DA526213.jpeg 1F664D57-C31E-44D9-BBF8-4165C3D845FF.jpeg B6F5843F-35E9-4F1F-A5DE-C72505256AC6.jpeg 28802081-33CC-423B-B13C-9134A376882A.jpeg
  5. AHotRod
    AHotRod
    I love what your building !
  6. Beau
    Beau
    Good stuff.
  7. leadfootloon
    leadfootloon
    But you have Joe's sweet shaping hammer. I have a few nice hammers and if you have or ever do meet Joe he is a really good guy. Nice work by the way.
  8. Corn Fed
    Corn Fed
    Nice start! Cant wait to see it all together.
  9. Asphalt Demon
    Asphalt Demon
    from Australia
    Could you shed a bit more light on your ch***is rail mods? They look perfect to me for a t I'm collecting parts for. Johnny
  10. AndersF
    AndersF
    If you want a english wheel why dont you just build one?
    To make the lower curved wheels you could use same metod as making your die for your beadroller.
    I builded myself a small one just to test a few years ago.
    Frankie47, kiwijeff, mkebaird and 4 others like this.
  11. justabeater37
    justabeater37
    The frame is 22 1/4” out of the middle, 1” v notch marked 3-4”ahead of the rear body mount hole in the kick up. Rear horns pulled in with relief cut at front of turtle deck, rails laid out to 27 1/4” at the firewall which puts about 20 1/2” between them at the front crossmember.
    Flipper, Tim, kiwijeff and 1 other person like this.
  12. justabeater37
    justabeater37
    Leadfootloon, perhaps you recall meeting earlier this year. If not me you may recall my son. And yep, Joes a pretty nice fella 28E3CBBD-4F04-4D27-A54E-2C0D051D5641.jpeg E61B9DC3-3442-45AD-8470-138E74BF0C49.jpeg
  13. leadfootloon
    leadfootloon
    Yep sure do. We were looking talking about Shane's model A. Didn't recognize the new project. And I'm no good with names. Well looks like your well on your way. I'm still trying to get all my stuff set up. Have my stumps mostly done a English wheel and sher still in the crate. 4 kids and 2 still in dippes really keeps a guy running. But small steps have been made over the year. And I alway get more done in winter. I will keep checking in, love shaping it's changed my world.
  14. flatheadpete
    flatheadpete
    from Burton, MI
    Great start! Love me some T roadster hot rods!
    A Boner and loudbang like this.
  15. ss34coupe
    ss34coupe
    Nice work!
  16. butch27
    butch27
    WOW: some awesome work there.
  17. swade41
    swade41
    from Buffalo,NY
    Nice stuff man
  18. manyolcars
    manyolcars
    You are doing an awesome job and your information helps with my T build. Will you please draw us a picture of what you did to make the kickup behind the body?
  19. tubman
    tubman
    I never cease to be amazed at some of the stuff that I see on here. I am still trying to figure out how I am going to make a steel rear top rail reinforcement for my gl*** "T" touring body, and here it looks like the first, simplest thing you made. I think I see my problem; I tried using the same square tubing I used to reinforce the rest of the body. I see now that I should have used round. Unless you have a problem, I'm stealing your method.
    loudbang and ZBoyz3 like this.
  20. justabeater37
    justabeater37
    108E6D9A-333B-431D-AFD4-59C92E93C24F.jpeg Steal away. 3/4 x .065wall is what I used. It can be bent with a conduit bender or over your knee. And the rear kick up in the frame is just a V notch 1" on the top rail measured from 3-4" in front of the rear body hole on the kick up of the 32 rails.
  21. justabeater37
    justabeater37
    Cowl top showed up. Guess I need to move the door posts. Must be a subtle difference from original to fibergl***. 190BAEDE-DFBA-4331-B170-97E35AD75EB3.jpeg A344AB40-04CB-479E-8A79-5CCB0283EC14.jpeg
    Tim, sko_ford, tb33anda3rd and 13 others like this.
  22. justabeater37
    justabeater37
    So after moving the door posts, a little head scratching, rolling a few beads, and some welding, here is where today ended 544522EB-5E4D-4F98-A68C-B9DA7A33DA0F.jpeg 173C16D8-0FF0-436D-AF28-F9EAD9ED2EB3.jpeg E9FD2725-9B39-45C0-9E01-29B616A232E5.jpeg
    Flipper, Tim, ChuckleHead_Al and 17 others like this.
  23. Davkin
    Davkin
    from SLC, Utah
    Your metal working is very interesting to me, it seems you are able to do a lot with very little. Unfortunately I don't have the space for a hot rod project but I was thinking maybe I could set up a small metal working shop in the ba*****t to develop my metal working skills to prepare for the day I have a shop, if I ever do. You build is inspiring.
  24. justabeater37
    justabeater37
    Ok I lied. A little more work to the turtle deck. 781F75C3-30C0-44F1-9410-47EB60C08B8B.jpeg 67C9DAA6-1AC3-4499-BD50-C13ECFB4465E.jpeg 8B6F617D-AB6E-4D19-928D-1818177A8B48.jpeg
  25. Okie Pete
    Okie Pete
    Amazing build. You have proven that if there is a will there is a way. Keep on pounding .
  26. CURSED GEARS
    CURSED GEARS
    Man, it looks like you really have something there! Cool idea, using a fibergl*** body as a template.
  27. brEad
    brEad
    Everything slowly coming into focus. Looking good! I’m subscribed!
  28. justabeater37
    justabeater37
    Thanks for all of the kind words. Its been a long week at work and HS wrestling meets start tomorrow. I haven't gotten much done this week as I just haven't had the time in the shop. Hopefully an update soon.
  29. justabeater37
    justabeater37
    D72578EB-0300-42E4-A5B6-4B11276D30F4.jpeg FE24BD25-9AA5-43C1-918B-5D7467AE56F1.jpeg Kind of embarr***ing that this is all that I got done this weekend. Too much running around chasing parts fixing daily drivers and farm trucks to give much time in the shop. Got to make another parts run tomorrow but I have the next couple of days off of work. This part is turning out to be harder than I thought it would be.
  30. justabeater37
    justabeater37
    But on the parts run note, when was the last time you bought any 6D7284E4-6E32-4539-B377-2F2603AEFC88.jpeg 32 Ford parts that have never been installed? Still has the tag from the Rouge on it.
