Hot Rods Old Bessy build
Discussion in 'The Hokey Ass Message Board' started by chop job, Nov 21, 2017.
  1. chop job
    chop job
    from Wisconsin
    Found this on the Ford Barn a couple of years ago. Plan is to chop,channel and add a 49 flathead. Rt side Frt A.jpg Eng A.jpg
  2. Great find.
    Joe Lemay and chop job like this.
  3. flatford39
    flatford39
    That one is really complete. Have you thought of trying to get it to run prior to taking apart?? You don't see them that complete very often.
    chop job and 50fish like this.
  4. Looks like a hell of a good start.
    chryslerfan55 and chop job like this.
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Great start. Restorers on Ford Barn reading this will be pissed they didn't buy it. They had the chance.
    chop job likes this.
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. spurgeonforge
    spurgeonforge
    image.jpg Looking forward to this. Doing a similar build.
    hfh, kiwijeff, Joe Lemay and 6 others like this.
  8. chop job
    chop job
    from Wisconsin
    Found this 49 ford motor also on the Ford Barn it came a Weiand manifold and two Stromberg 97 carbs. DSC00247.jpg
  9. chop job
    chop job
    from Wisconsin
    Been cleaning up the motor and it looks real good so far. Motor is now at Flatjack in Oshkosh,Wi for total rebuild. A 72 ford mustang 3 speed bolts right up to the stock bellhousing . 20170206_125923.jpg
    Tim, Stogy, kiwijeff and 3 others like this.
  10. chop job
    chop job
    from Wisconsin
    swade41, Boden, Stogy and 5 others like this.
  11. warhorseracing
    warhorseracing
    from cameron wv
  12. chop job
    chop job
    from Wisconsin
    Got myself a Midwest Fabrication bare frame and My brother and I set it up for the flathead and a 9 inch rear end with coil overs. Sorry all the pictures are in a camera and if I can figure how to get them out I will post. Frame has a 4 inch sweep and 10 inch z.
    Tim and chryslerfan55 like this.
  13. chop job
    chop job
    from Wisconsin
    I inch sq. Tube floor frame is in and starting to figure out the floor panels. Lots of cardboard and tape. 20160328_153557.jpg 20160324_113537.jpg 20160324_115243.jpg
    Tim, Stogy, kiwijeff and 8 others like this.
  14. Clay Belt
    Clay Belt
    Sweet ride once it's done I bet.
  15. chop job
    chop job
    from Wisconsin
    Started working on the floor. Most of the floor will be bolted in for easy ***embly. 20160715_163635.jpg 20160715_163604.jpg [ATTACH 20160818_134253.jpg
    Stogy, kiwijeff, Tim and 4 others like this.
  16. chop job
    chop job
    from Wisconsin
    20161012_121238.jpg More paper paper patterns for the firewall portion of the floor.
    chryslerfan55, chriseakin and Stogy like this.
  17. chop job
    chop job
    from Wisconsin
  18. chop job
    chop job
    from Wisconsin
    Lots of cutting sanding and fitting the floor 20161117_151738.jpg 20161122_151406.jpg 20161125_133117.jpg 20161126_122104.jpg 20161126_154100.jpg is all coming together pretty nice.
    Lil'Alb, Stogy, kiwijeff and 8 others like this.
  19. chop job
    chop job
    from Wisconsin
    Finished the brake and clutch set up with lots of help from my brother. 20170825_161706.jpg 20170825_134327.jpg 20170811_121610(1).jpg master cylinder brkt. 20170811_121650.jpg
  20. 40FORDPU
    40FORDPU
    Nice fabrication, your project is coming right along.
  21. chop job
    chop job
    from Wisconsin
    Thank you very much all ways nice to hear good things.
    Stogy and chryslerfan55 like this.
  22. brady1929
    brady1929
    Great job, looks great.
  23. chop job
    chop job
    from Wisconsin
    Made some support tubes out of 1x1 x 1/16 Tube and mounted the gas tank. 20160616_130353.jpg 20160618_114509.jpg
  24. chop job
    chop job
    from Wisconsin
    Started to cover up everything with sheet metal. Want all sheets to be removable so will be drill8ng lots of holes and adding stainless ****on heads. 20160824_150537.jpg 20160821_104803.jpg 20160824_150729.jpg 20160823_145002.jpg 20160825_122254.jpg
  25. spurgeonforge
    spurgeonforge
  26. Stogy
    Stogy
    Its always interested and refreshing observing the build take shape with ones trade or profession wrapped into it all. That has an aviation look happening...great info and visual on your build...thanks @chop job
  27. barrnone50
    barrnone50
    from texas
    Very Quality Work you are doing.. Those fasteners are they rivets? Thanks For posting.
    chryslerfan55, chop job and Stogy like this.
  28. chop job
    chop job
    from Wisconsin
    Those in the picture are Cleco fasteners which will be replaced with ****on head bolts.
  29. chop job
    chop job
    from Wisconsin
    Thank you guys your comments mean a lot to me.
    kiwijeff, chryslerfan55 and Stogy like this.
  30. chop job
    chop job
    from Wisconsin
    Been working on more of the floor. Lots of rivets. 20161205_140923.jpg 20161205_123552.jpg 20161205_141034.jpg 20161212_110539.jpg More to come.
    brEad, chryslerfan55 and Stogy like this.
