Technical Thoughts on rebuilding my 28 Roadster pick up
Discussion in 'Traditional Hot Rods' started by i420, Nov 28, 2017.
  1. i420
    i420
    Been working on this for about ten months. 28 with a model B engine. Miller/Cragar head.
    Looking for educated thoughts on the best way to rebuild.
    Old school complete rebuild with babbit or with new inserts. The engine was rebuilt around 35 years ago and never run. It has all new internals but one of the slingers has been removed.
    It runs like a champ but leaks like the Valdez.
    [​IMG][​IMG]
    Any input would be much appreciated.
    Jet96 and dwollam like this.
  2. alchemy
    alchemy
    So what would you do differently to keep it from leaking? Can't you just do that now? Why rebuild when it runs fine and is fresh?
    Tim likes this.
  3. i420
    i420
    It’s ******* oil. Hate to sound blunt but I’m talking a steady stream after running for just a few minutes.
    That’s what I’m asking. It’s the real main bearing.
  4. denis4x4
    denis4x4
    from Colorado
    Have exactly the set up you have and after a new pan gasket, rope/cork seals and side plate gasket, leaks disappeared. Used black permatex on everything. Also new lock washers on pan and side plate.
    i420 likes this.
  5. Probably the missing slinger but by any chance did you leave out the gasket that goes between the block and the flywheel housing?
    Charlie Stephens
  6. i420
    i420
    It is missing one slinger. It had the wrong pan. Changed the pan, gasket and I’m not sure about the one between. It’s gushing out the hole at the base of the flywheel housing.
  7. RussTee
    RussTee
    there are several different kits to help that now I use the one with the chev oilseal in it also it does not hurt to machine a small amount off the camshaft and fit a frost plug behind the cam at the back of the engine check that the sump flange is true as many have been over tightened on a too thick gasket there are new kits for the front of the crank too
  8. i420
    i420
    I’ve heard that the Chevy seal works for awhile but eventually fails. I’ve also been told that it can new inserts machined into the rear. I obviously am not educated about these problems. I do know that I want to be able to drive this while working on another project.
    That’s my dilemma right there. Which way do I go?
  9. PAracer
    PAracer
    In your picture I see a gap between the shims and crank. When ***embling I’ve been taught the shims must be squared up and be pushed in and touching the crank. Also put a dab of sealant in the corner where the shim meets the rope seal.
    i420 likes this.
  10. Model A Gomez
    Model A Gomez
    I would plastigauge the mains, your leak is the rear main. Also make sure the drain tube is open and not screwed in too far or it will be blocked. There shouldn't be any sealer on the shims, that will change the clearance.
    i420 likes this.
  11. rusty valley
    rusty valley
    what is the end play in the crankshaft?
