Projects The bucket of ugly! A de-uglifying thread...
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Aug 14, 2013.
  1. Blue One
    Blue One
    from Alberta
    After all this time waiting Fred it better be worth the wait :D
    loudbang and 26 T Ford RPU like this.
  2. tfeverfred
    tfeverfred
    Today was a short day at work. Got home at 10:30am. The delivery truck pulled up 5 minutes later! The body comes in a nice HUGE heavy cardboard box and is bolted to some 2"x4"s to keep it secure. A good looking over and all looked good. My last concern was damage and it was fine.
    The brace that secures the door ***embly is secured using nut and bolts. They protrude through the floor of the body about 3/4". When the body is finally ready to be bolted down, these bolts are removed and replaced with self tapping bolts that go into the frame. So in the pics, the body is actually 3/4" higher than final ***embly.
    Here we go!
    In this pic, the "cool" guy is sitting 3.5" off the floor. Which is my target height for the seat.
    The cross brace is 4.5" high and it's 16.5" to the kick up.
    VA-ROOOOM!
    t-rod, swade41, 26 T Ford RPU and 5 others like this.
  3. tfeverfred
    tfeverfred
    Now..... as if the delivery truck wasn't cool enough, Fedex dropped off Rotten Leonards seat braces! Might get a lotto ticket tonight;)
    Here they are.
    This is a quick mock up for my bench seat. The cross brace has 2 tabs with a hole in each. These holes will secure the bench seat in the front. I plan to have the bench extend about an inch in front of the brace. I'm doing this for 2 reasons. 1. I plan to have the rear of the bench 3" high, so combined with the angle of the seat, this will set the back of the seat about 1.5" from the rear of the body. 2. With the seat back being away from the rear body wall and at an angle, removal of the seat will be a simple "lift up and out" movement. Here are a couple pics with the rear of the brace 3.5" high or 1" below the front brace.
    My seat bottom foam is going to be 3" high, but with webbing installed, I should sit about 1.5" lower than than that. I'll take my final measurements tomorrow and head to Lowes to get the rest of my seat supplies.
    Who tha hell is this guy!?
  4. tfeverfred
    tfeverfred
    Dang....... can't believe I didn't take any pics with the door open. DOH! Anyway.... when it closes, there isn't a rattle. Just a nice, sold "thud".;) Maybe I'll do a video, instead.
    Blue One likes this.
  5. Dick Stevens
    Dick Stevens
    Fred, I'm happy for you.....now get to work! :D
    tfeverfred likes this.
  6. tfeverfred
    tfeverfred
    Bro... I've been saving for the body since the build started. Almost 2 years. Tomorrow, I'm going to get the rest of my seat supplies and do some final measuring in prep for the bench seat. The foam arrives tomorrow and has to lay flat a couple days. But tonight, there's a one pound rib eye with my name on it and I'll probably jam the AG sound track, while I sit back and look things over. Sleeping in it is also an option.;)
  7. Blue One
    Blue One
    from Alberta
    Right on Fred.
    Looking good. I’m thinking that it was worth the wait. :cool:
  8. GASSERBOB
    GASSERBOB
    from USA
    That's cool Fred. I'm glad it was not damaged in any way. It sure looks nice. Does the door fit nice and tight ? So they hung the door and everything for you? Keep us updated buddy. Bob.................
  9. tfeverfred
    tfeverfred
    Tighter than teenage.....! Better not.:rolleyes: Yes, it fits tight. There's a rubber piece built into the catch for the door. When you close the door, it presses the rubber piece as it catches. Makes for a really snug fit. And when it catches, that solid, secure "thud", let's you know it's securely latched. I'm glad they hung the door. That's something I probably would have screwed up.
    AndersF and Tim_with_a_T like this.
  10. RodStRace
    RodStRace
    congrats Fred!
    the seat frames look like a great fit... paint 'em black?
  11. tfeverfred
    tfeverfred
    No, I'll smooth the edges and that's it. When the seat is done, only a little of the frames will show. And the side rivets won't be visible, unless the seat is out. Which kinda ****s, because they do look really nice.
  12. steel rebel
    steel rebel
    Like the look Fred.
    Rebel
  13. tfeverfred
    tfeverfred
    It's getting there and I'm REALLY happy with this accomplishment. The body looks high, but it's not fully mounted to the frame and the shocks are at the highest setting on the mounts. I honestly thought the body would be too wide for the rear end and I'd get tire rub, so I raised the shocks and frame up. But it's not even close. I'll still hold off doing any ch***is adjustments, until I get the engine and trans installed. That alone will drop it a little.
    patman likes this.
  14. 26 T Ford RPU
    26 T Ford RPU
    So happy for you Fred, all looking really good. Now looking forward to the Chevy filling the gap. :cool::cool::D JW
  15. Tim_with_a_T
    Tim_with_a_T
    Looks awesome Fred. Your homework and previous build experience is really paying off. I like the seat brackets and stance of the car a lot. Looks just right to me.
    loudbang, Blue One and tfeverfred like this.
  16. swade41
    swade41
    from Buffalo,NY
    Just when you thought you had seen all the ways to F'up a T-bucket then this pops up on your Facebook feed....... FB_IMG_1511994878834.jpg FB_IMG_1511994887915.jpg FB_IMG_1511994896700.jpg
  17. shivasdad
    shivasdad
    from Texas
    I know this is a thread about ugly buckets, but daaaaammmmn! Avert thine eyes!
  18. Blue One
    Blue One
    from Alberta
    That’s just cruel. You should be banned for posting that.
    DaPeach and loudbang like this.
  19. SR100
    SR100
    Another reason to avoid Facebook...
    loudbang and swade41 like this.
  20. swade41
    swade41
    from Buffalo,NY
  21. Dick Stevens
    Dick Stevens
    Now there is a ton of ugly in that bucket!!!:eek::eek::eek:
    drylakespeedshop and loudbang like this.
  22. tfeverfred
    tfeverfred
  23. steel rebel
    steel rebel
    Come on guys if you can't say something nice.
    I kinda like the seats.
    Rebel
    Dick Stevens likes this.
  24. Dick Stevens
    Dick Stevens
    Touche' :p
  25. Blue One
    Blue One
    from Alberta
    :rolleyes: Of course you would Gary :D:D
  26. DDDenny
    Do they make bandaids for your eyes?
    Speechless!
  27. 26 T Ford RPU
    26 T Ford RPU
    I like the tail lights, I would like them more on anything else!:confused::rolleyes: JW
  28. loudbang
  29. Crazybillybob
    Crazybillybob
    from Ohio
    I think the windscreen would look nice on my garden shed!
  30. DaPeach
    DaPeach
    from NE OH
    looks like it should be hooked to the sled at the truck pulls.
    oh, and ugh.
    RICH B and loudbang like this.
