Technical Okay guys, what’s your secret for removing these? Pins on the back of trim emblems...
Discussion in 'Traditional Customs' started by Dad Was A Racer, Nov 28, 2017.
  1. Dad Was A Racer
    Dad Was A Racer
  2. 31Dodger
    31Dodger
    I usually use a pair of channel locks or wide vise grips and VERY delicately grip as much of the keeper sides as possible and sort of wiggle it clockwise and counterclockwise unscrew it from the pin. All the time making certain no tilting of the channel locks and pin damage/snapping off. Is that an emblem that can easily be replaced?
    squirrel likes this.
  3. 56don
    56don
    I use pliers and try to unscrew them counter clockwise while gently pulling up on them trying to make it make its own thread.
  4. Dad Was A Racer
    Dad Was A Racer
    ‘56 Olds “88” badges. Rare, but not impossible to replace I suppose.
  5. Just Gary
    Just Gary
    Use two putty knives- one on either side of the post- to gently pry the clip up and off the post.
    scrap metal 48 likes this.
  6. green53ford
    green53ford
    from Wisconsin
    Pry off gently with a dental pick.
    partsdawg likes this.
  7. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Dremel tool with the little cut off wheel, cut the retainer in half , it will fall right off.
    Just be careful!
    KK
  8. 2manycars2littletime
  9. bobbytnm
    bobbytnm
    I typically use a dental pick to slip under it and push out on the tangs. You have to be patient and work back and forth several times.
    Bobby
    Just Gary likes this.
  10. Rocky
    Rocky
    Classified Editor
    Dremel for me...don't forget safety gl***es then run a die over it to tread a nut on the stud for installation.
  11. Dad Was A Racer
    Dad Was A Racer
    I was wondering if the chromed cast metal would take a thread. That would make re***embly a lot cleaner.
  12. Kerrynzl
    Kerrynzl
    jam an electrical screwdriver into it and open it up.
  13. pgj
    pgj
    from aurora co.
    Yep, small screwdriver into the slot to open them up, then you can flatten them back out and reuse them if you are putting the emblem s back on.
    biggeorge and scrap metal 48 like this.
  14. HOTRODPRIMER
    HOTRODPRIMER
    A small screwdriver is what I always use. HRP
