Projects CONVERTING A 1933 FORD FOUR DOOR SEDAN INTO A 5 WINDOW
Discussion in 'Traditional Hot Rods' started by H-O-O-V-E-R, Aug 10, 2017.
  1. milkweed
    milkweed
    from SLC UT
    Seen it today..it looks good...
    H-O-O-V-E-R likes this.
  2. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Doing some rust repair before trying to fit the back on. IMG_7699.JPG IMG_7700.JPG IMG_7701.JPG IMG_7702.JPG IMG_7722.JPG IMG_7724.JPG IMG_7729.JPG IMG_7730.JPG IMG_7731.JPG
    The top of the trunk does not fit correctly yet, I will be cutting out the flange above the trunk and putting a new one in to get the gaps perfect.
  3. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Put in cross bracing for the quarter panels to keep the gaps right.
    Got some new parts in, wide fives and some 36 rear ends. Would love to get my hands on some 18 inch wide fives. I have a pair of open wide five drums, the star pattern style, need two more.
    Found that the cross bracing wasn't sturdy enough, with all the fitting of the 5 widow top it kept want to pull the quarters in. I put a bar across the top of the trunk to keep them from separating. Seemed to do the trick!
  4. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Cross brace on top of panels
    Making sure to keep the lines and gaps to exact 5 window specs.
    Needed a little help from a tie down to keep it positioned right.
    Getting the quarters trimmed down to get ready for final placement.
    Tacked in place
    Final weld. It took me two weeks and a lot of hours just to get the top positioned right to where it can be welded in place. The top was taken on and off multiple times. The trunk is also just sitting inside not positioned correctly so it looks a little off and goofy. Just need to find 33/34 hinges to get it right.
  5. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    IMG_7925.JPG IMG_7926.JPG IMG_7928.JPG IMG_7929.JPG IMG_7930.JPG IMG_7931.JPG IMG_7932.JPG IMG_7933.JPG IMG_7934.JPG IMG_7937.JPG
    Had to take a section out of the old sedan c pillar to graft into the b pillar of the damaged 5 widow
    Mocking up the graft.
    Was able to get my mitts on an original 5 widow door to get exact specs so I can weld the window tops back on.
    Still need to planish the welds to get get metal perfectly smooth.
  6. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    This is where I think a lot of guys who do conversions come up short. Nailing the lines while grafting the two roofs together is critical. It's gonna take a lot of clamps to get it right. This part has also taken a couple of week of tinkering and manipulating pieces to get them to look perfect and fit.
    The lines above the door are coming together.
  7. Squablow
    Squablow
    $150 for that door! Holy ****, that was a score.
    My '33 still had issues at the B pillar with alignment when I sold it. It wasn't done and I'm sure those things are all fixable, but I agree, that's a really tricky spot to get right.
  8. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    The door still has the price on it from many many years ago, wish they were still that cheap! It was borrowed from a friend.
    Outback and kidcampbell71 like this.
  9. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    I do still have have one side all the way intact and don't think I will have a use for it. Message me!
    kidcampbell71 and Outback like this.
  10. dwollam
    dwollam
    Simply Amazing! Good job.
    Dave
    oliver westlund and H-O-O-V-E-R like this.
  11. He had me on that one also!
    At least he could borrow one for mock-up
    I must say, you have done a great job with this and thanks for the photos.
    H-O-O-V-E-R and weps like this.
  12. AULIZ
    AULIZ
    Great job !
  13. HOTRODPRIMER
    HOTRODPRIMER
    Amazing work. HRP
    catdad49, Outback and H-O-O-V-E-R like this.
  14. jackalope
    jackalope
    Great job! Following this build.
  15. The37Kid
    The37Kid
    Looks great, thanks for the update.
    Bob
  16. spurgeonforge
    spurgeonforge
    One of my favorite builds.
  17. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    I appreciate all of the support and kind words!
    patman likes this.
  18. edwardlloyd
    edwardlloyd
    from Germany
    If anything this thread puts me off attempting such a conversion. Hats off to you though.
    Sent from my SM-G935F using The H.A.M.B. mobile app
    chiro, Outback, IowaMercMan and 2 others like this.
  19. 48fordnut
    48fordnut
    Your metal work skills and photos are amazing. Like what you are doing.
  20. Great job, good save.
  21. WP38
    WP38
    Great job what type of welder are you using?
  22. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Grafting the roofs together. Trying to get the crown and lines perfect.
    This angle is looking straight down on the "sunroof" the five window doesn't want to match up exactly with the sedan roof. I will end up cutting out the corner to match it.
    The big contraption on top of the car has the original crown of a five window, I am using it to help match my roof while it gets tacked.
  23. brEad
    brEad
    Looking good! Thanks for sharing the details on how you are making the roof line match up.
    Atwater Mike and H-O-O-V-E-R like this.
  24. 56 Dodge Pickup
    56 Dodge Pickup
    That is looking really good and that is one cool angle finder, this is quality build Hobo Jim
    kidcampbell71 and H-O-O-V-E-R like this.
  25. Outback
    Outback
    from NE Vic
    Wow. loving your work, a belated welcome to the HAMB & thanks for taking us on the ride! :D
  26. el Roach
    el Roach
    WOW ! Great work!
  27. catdad49
    catdad49
    Love the adjustable template thingie( sorry for the technical term)! How about a little how-to with a materials list? Thanks for sharing this with all the great pictures.
    H-O-O-V-E-R and 48fordnut like this.
  28. spurgeonforge
    spurgeonforge
    Wow! Awesome work!
  29. Babyboomerboy
    Babyboomerboy
    Wow, this is really a great build by some really skilled metal workers. Can't wait to see the next set of pictures.
  30. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    This is what's going on up top, looking down on the roof. Lots of cutting an splicing. Do you see the factory lead spot? Had to melt it out obveosly to weld. Gonna have to re apply when the body work is closer. Had to make a relief cut in the corner, that section will take a little bit of stretching as well.
    LOOK WHAT MADE ITS WAY INTO THE SHOP! Freshly rebuilt flathead motor. So excited for this bad boy. Gonna paint the block a light gold.
    Decided to lay the unflanged roof insert in to see if the crown matched up with the roof. Sits very nicely.
    Gonna take a little more work to get all the lines to flow but off to a good start. You can see where I had to cut the corner out and slide it an inch or so to match. Almost ready to weld.
