Features Who's Building a T?
Discussion in 'The Hokey Ass Message Board' started by Slimegreeeeeen, Nov 19, 2011.
  1. james reynolds
    james reynolds
    very helpfull, could i ***ume then 23-25 doors will also be the same for all tudors in that year range
    also would coupe doors be the same across the same 23to 25 year models
    im trying to understand the changes henry made because im looking for sheet metal to buy and need to know what i can mix and still get a bolt together car
  2. james reynolds
    james reynolds
    the reason i was looking at building a 26-27 was because i read they were a little wider and i thought that might open up the engine compartment for wider motors and still get a full hood is that a reasonable ***umption?
  3. AndersF
    AndersF
    Yes you did.
    It in my saved links archive for future needs.
    https://www.jalopyjournal.com/forum/threads/official-model-a-t-hinge-info-thread.605123/
  4. fiftyv8
    fiftyv8
    from CO & WA
    Great work Anders.
    Other year doors I don't know well enough to advise you on.
    I can say be careful of 4 door stuff because I believe that can be different.
    Good 26/27 & 28/29 doors can cost decent money if you plan to find some.
    Then again owning a good pair of doors will make life easier and speed you progress up.
  5. james reynolds
    james reynolds
    cool thx for the info
  6. james reynolds
    james reynolds
  7. fiftyv8
    fiftyv8
    from CO & WA
  8. james reynolds
    james reynolds
    thx i have read it already and saved it and i am looking for a good starter body it will be the first of the year before i can expend much money i have grand kids and its christmas they take priority.
    however i will be moving and shaking come january
  9. james reynolds
    james reynolds
    is it my imagination or are there more model a s available to buy than t s
  10. james reynolds
    james reynolds
    does anyone know what year car this is i was thinking 26-27 but the cowl looks odd to me but im a rookie
  11. fiftyv8
    fiftyv8
    from CO & WA
  12. james reynolds
    james reynolds
    i will read that um i dont know how to start a build thread
  13. james reynolds
    james reynolds
    would that just be starting a new thread and keeping it all in there
  14. fiftyv8
    fiftyv8
    from CO & WA
    Yes, that is correct.
    Give it a nice ***le that helps folks find you if they are into T's etc.
  15. Squablow
    Squablow
    That Tudor above is a 26-27, you can tell by the firewall. Keep in mind that roadster cowls and closed car cowls look nothing alike (beyond the firewall) so that might be what's throwing you off.
  16. james reynolds
    james reynolds
    should i put it in the traditional hot rods forum or somewhere else?
  17. james reynolds
    james reynolds
    cool trying to lear the differences i thought it looked tall and the tudors i thought didnt get the tall hood
  18. Blue One
    Blue One
    from Alberta
    Starting to come together.:cool:
  19. james reynolds
    james reynolds
    that is a beautifull frame i love the color hey what do you call that suspension setup i like that its 4 link but the top is v so no side motion and no panard bar right?
  20. Blue One
    Blue One
    from Alberta
    Yes, triangulated 4 link, no panhard bar needed.
  21. james reynolds
    james reynolds
    i have seen them before in various arrangements just couldnt recall what they were called , yours is very clean and in a small space good job
  22. Bigcheese327
    Bigcheese327
  23. goldmountain
    goldmountain
    James: You can recognize the 26-27 cars by the gentle curve on the bottom of the windshield. Older ones are flat. Chances are, when you find a body it will be the 26-27 variety because that's all I ever seem to find. Also, the earlier ones have a more square shape to the trunk.
  24. I'll toss my hat in the ring. 27 roadster on a rails, 59ab, 36 rear and bones. And I'm going full length 35/36 driveline for my exhaust. 35 wires
    Jet96, Squablow, AndersF and 3 others like this.
  25. bondojunkie
    bondojunkie
    Bigcheese- enjoyed the article. Going back to check out parts 1 and 2. is there a build thread for this on here?
  26. Bought an acreage last year here in Eastern South Dakota and found 2 model T frames in our wood line with an ***ortment of other antique farm tools and implements. (Wood line=metal s**** yard/dump for old time farmers) 1 frame was used as a wagon but has all original Ford running gear. Going to build a RPU out of the frame.
    bondojunkie, loudbang and AndersF like this.
  27. tfeverfred
    tfeverfred
    After 2 years of saving, I finally have a body. Made a seat for it.
  28. jim32
    jim32
    Nice work more power to you, let the HANB know what you need next, something good might come your way.
  29. Rand Man
    Rand Man
    I guess I haven’t posted on this thread. I have this old RPU in parts to rebuild. [​IMG]
  30. Rand Man
    Rand Man
