Technical The Allure of the Quick-Change Rear End.
Discussion in 'Traditional Hot Rods' started by Jive-Bomber, Dec 6, 2016.
  1. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Rodist,
    At $.25/hr. You're right on target!
    RODIST likes this.
  2. RODIST
    RODIST
    [emoji851][emoji106],... the adaptor step down the trick,. Get busy Mr Gearhead!!
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    FF,
    You know I can't condone this, but you did do a fine job on that FAKE!
    Outback and duncan like this.
  4. Stan Back
    Stan Back
    I'm still trying to figure out the path of the intake from those carbonators up and down and thru the DOHC head.
    It doesn't look like the rear spring needs shocks, either.
  5. sdluck
    sdluck
    How do I post pictures Please
  6. Motmo
    Motmo
    If you go to the main page, all the way to the bottom under the "To The Editors" section, there is a "tutorials" link that should have the info your looking for.
  7. I just want to say - I love this damn thread! Just pure hotrod **** . . .
  8. Blue One
    Blue One
    from Alberta
    Did someone say quickchange ? :D
    It’s now painted and in the ch***is.:cool:
    DC2EF673-5A30-4C51-8933-26A6015DF2D5.jpeg C3F9BA2F-D54A-441F-BA98-C0B67A86CCDB.jpeg ECF636E2-E1FA-4A95-B849-F5A555D716B4.jpeg 7689A391-9F62-44EC-A437-15D2EF23A881.jpeg 173A4EB8-89A6-4052-AAD5-822B71FB0F00.jpeg 18127F13-DC76-40EF-BB0D-59B61C979216.jpeg
  9. dana barlow
    dana barlow
    from Miami Fla.
    I raced stock cars early 1960s,so had QC's around an used in racecar,but never thought it was a good idea on the street,tooo much sound of too many turning gears. Never have seen the point on the street. Makes great gearing on the track though.
    hotcoupe and cactus1 like this.
  10. Paul
    Paul
    Editor
    For me the point of having it on the street is so that around town where I do most of my driving I can have gears like the 4.11's in it now,
    then when I want to get out of town, in about five minutes I can have highway gears in, like 3.05's, and keep up with traffic without over revving the old motor.
    The noise from the Rodsville Halibrand V8 style is not loud at all
    and I think it adds to the overall "hot rod" look
    Outback, J.Ukrop, neverdun and 4 others like this.
  11. Bandit Billy
    Bandit Billy
    I have a call into Winters Performance but ill ask here as well (this is where all the smart kids hang out). While I was painting my axle tubes the other night I noticed I don't have a vent. That can't be right.
    I see on Blueone's post above this thingymajig
    Is that a vent? I have a threaded plug up there.
  12. Stan Back
    Stan Back
    We had something that looked like that on our 9-inch at Bonneville. I'd guess that it was a factory vent. After every run, the rear of our roadster was coated with grease. We ran a rubber tube up into the top of the rear deck and affixed a small K&N filter to it. Problem solved. I guess the grease would get all up to the filter and not go thru it and eventually run back down. Never made a mess.
    Bandit Billy likes this.
  13. Blue One
    Blue One
    from Alberta
    That's a Mopar rear axle vent adapted to a reducing bushing that I made to replace the fill plug.
    I'm hoping that it will vent without leaking oil. I think it should work fine.
    Outback and Bandit Billy like this.
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Ideally, the vent would be on the side bell to avoid having the ring gear throw axle grease at it.
    I have seen them vented just about everywhere, including the main case, change gear cavity, and axle tubes. Occasionally more than one. It doesn't take much, but as Stan Back said, a long tube with a filter at the end seems to always work.
    On race cars we use the tube with a funnel at the end. This makes refilling after a gear change easy peasey. A filter cloth (rag) in the funnel keeps the skutz and fugs out! :D
  15. DDDenny
    K&N makes these neat little filters, this is my fuel tank vent filter.
  16. I've got a Champ with helical gears out back and a DPI black gold differential, it's real quiet for a Q/C
  17. Splitbudaba
    Splitbudaba
    IMG_2561.JPG IMG_2427.JPG Summit had the right length, complete rear, and on sale too! Even my wife agreed!!! Note: that's a Summit trans mount spliced in on the shock mount stubs, on sale too !!
    Tim_with_a_T and Bandit Billy like this.
  18. Casual 6
    Casual 6
    from Great NW
    Anyone use one of these? Completely closed, so no fluid loss, but still allows pressure to vary in the rear end.
    Splitbudaba likes this.
  19. Splitbudaba
    Splitbudaba
    Great idea, you could mount it inside the trunk and run a flex line to it. Could be a clean install!!
    Outback likes this.
  20. DDDenny
    Of course you took her right to dinner, didn't you!
    You better keep her around.
    That's looks good.
    Outback likes this.
  21. DDDenny
    I knew a guy once that took his M-22 out because it was too noisy:confused:
  22. Splitbudaba
    Splitbudaba
    Oh hell yeah! She's the best!!!
  23. sdluck
    sdluck
    Outback likes this.
  24. woodbutcher
    woodbutcher
    :D Hi Jive-bomber.Great thread.Thanks for posting.
    Good luck.Have fun.Be safe.
    Leo
  25. Blue One
    Blue One
    from Alberta
    Yes I did.
  26. sdluck
    sdluck
    very nice.
    Blue One likes this.
  27. Bandit Billy
    Bandit Billy
    Quick change, slowly mounted in place
    cretin likes this.
  28. Max Gearhead
    Max Gearhead
    from Wisconsin
    I had to put my shades on to get a good look at all that cool stuff. :cool::D
    Outback likes this.
  29. IronTrap
    IronTrap
    My little haul from yesterday. Been wanting a 201 for my roadster project since day one and glad to have gotten an affordable start on one. I got a big box of gears and parts with these, but was curious if the QC gears are interchangeable (or what parts in general are) between the 301 and 201's? I plan to keep at the least the 201 and might save one of the 301's and sell one on, but don't want to shoot myself in the foot by selling something I may need.
    Outback and rod1 like this.
  30. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Virtually nothing from the 301 will fit a 201.
    I'd like to see the axle tube adapter on that 301 a little closer. I knew that these existed but have never had one.
    Looks like good stuff.
    Outback likes this.
