Technical ***December 2017 Banger Meet - Little Saint Nick Banger Powered?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 30, 2017.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Dannerr likes this.
  2. Here, patienly awaiting parts being shipped... :confused:
  3. bobo1
    bobo1
    from France
  4. jim1932
    jim1932
    Anyone know a source for this spring. It is on a winfield choke. I have a second ****erfly missing the spring IMG_4043.JPG
  5. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Santa dropped things off early to me. Oldsmobile 3 port.
    The37Kid, Old Dawg, waxhead and 3 others like this.
  6. Bluto
    Bluto
    NOT MANY SHOPPING DAYS LEFT GUYS......
    Crazydaddyo and Dannerr like this.
  7. winduptoy
    winduptoy
    I bought everything for this year at last years after Christmas sale
    by the way, I'm getting you the same thing I got you last year if that works
  8. denis4x4
    denis4x4
    from Colorado
    Checking in.....even though my A powered hot rod has a fake QC, fibergl*** replica E&J headlights and a number on the door!
  9. hardtimesainit
    hardtimesainit
    Hey bobol,
    Nice improvement !
    Is that a new alum Tod head ? Looks to be 7:1, eh ?
  10. bobo1
    bobo1
    from France
  11. waxhead
    waxhead
    from West Oz
    Checking in.
  12. Crazydaddyo
    Crazydaddyo
    Wow, December already?
    Dannerr, winduptoy, Jet96 and 2 others like this.
  13. 62pan
    62pan
    I hope I can ask this so you understand. I am using a Model B distributor and as you know the base mounts in the head with a pin and set screw. The distributor cam is adjustable to locate number 1 cylinder.
    I am changing to a Mallory Ya 11A. The problem is there is a set screw indent on the housing and if I line this up in the head the rotor is between 1 and 2. I ***ume that since the Mallory distributor cam is fixed I could rotate the distributor to fire on number 1. My question is can the oil pump/ distributor drive gear be lifted and turned one or two teeth to relocate the rotor or is it in a fixed location? If I can do this I know I need to turn the oil pump so that it all lines up. Can this be done without dropping the pan? Thanks.
  14. Crazydaddyo
    Crazydaddyo
    Yes, the oil pump is driven off of a tang on the bottom of the distributor drive. I've used a long flat blade screwdriver to turn the oil pump drive shaft. There is a lead on the tang and on the mouth of the slot to help line them up if you are close.
  15. hardtimesainit
    hardtimesainit
    Answer: An optimist would say...anything is possible.
    In this case , I say no, as I've tried such maneuver.
    That said, I've used Mallory distributors (not your model) where Mallory provided a SCREW on the lower plate that is accessible thru a hole in the upper plate. Maybe your model has similar arrangement ?? Loosening this screw lets goal be accomplished, but then have to reset points/timing, etc....Let us know if there IS a different answer than mine.
  16. hardtimesainit
    hardtimesainit
    Hey Dan,
    So, you saying that you use the screw driver to align the pump slot, with the pump drive(tang) gear (helical) with cam installed ?
  17. Crazydaddyo
    Crazydaddyo
    Dannerr likes this.
  18. 62pan
    62pan
    Thanks, I now know what needs done.
    Dannerr likes this.
  19. Crazydaddyo
    Crazydaddyo
    Dannerr likes this.
  20. Crazydaddyo
    Crazydaddyo
    It is a little tricky, and it takes some fineness. Be patient and think it through. You are a smart guy, you'll get it. ;)
    Sent from my SM-J320P using The H.A.M.B. mobile app
    Dannerr likes this.
  21. 62pan
    62pan
    Took another look at the distributor, Hardtimes is correct in that there are two screws beside the cam that if loosen let you rotate the rotor to any position. So simple but it had me stumped. Thanks to both of you, learned something today.
    Dannerr likes this.
  22. hardtimesainit
    hardtimesainit
    Your welcome and...Thanks to you and your question also ! I learned , via Dan, that what I thought should work, but could not geterdone...will work. Guess that I was a bit impatient. However, I was trying to realign Magneto instead of a distributor. Same/same I guess. Thanks Dan for confirmation !
    BTW...those Mallory distributors....are the best !!
    Dannerr and Crazydaddyo like this.
  23. Bluto
    Bluto
    IT depends on what magneto you have. Most don't care which position #1. NOT VERTEX #1 ON THE CAP SHOULD ALWAYS BE #1! I trusted my mags to this guy for over 35 years.
    I have also though the thread updates were now fixed..... NOPE Sorry to say.
    Dannerr likes this.
  24. V4F
    V4F
    from middle ca.
    jimski , you still not getting updates ?
  25. Bluto
    Bluto
    I thought I was till this month ... hey I got this one..... maybe it will take :)
    A very Merry Christmas to you all.
  26. V4F
    V4F
    from middle ca.
    I hope so as very frustrating
  27. hardtimesainit
    hardtimesainit
    Yup, true words, as it's a Scintilla/Vertex. I use the Vertex Company back east. Great guys to deal with and reasonable $.
  28. Binger
    Binger
    from wyoming
    Checking in for the month! I just purchased a 30' Ford 2 Door Sedan. got it for a great price. Barn fresh. I will post a few pictures when I get it home.
    Dannerr, winduptoy and Jet96 like this.
  29. winduptoy
    winduptoy
    waiting for pictures and story
    Dannerr likes this.
