This is a reproduction header panel for a 28 - 29 Ford Model A. This is for a Tudor sedan but I believe I will fit other models.This was made in the 80's and never used. I took some pics with an original for comparison.The differences that I noticed right away are the 3 inside brackets are not the same as orig , there are holes that need to be drilled, and the groove for the windshield hinge is not quite as wide.It is constructed from 18 gauge steel and is primed.It has been in my barn for over 30 years .Look at the pics and ask questions.Don't ask about the original as it is gone.
