History 1934 Chevy hot rod time capsule
Discussion in 'Traditional Hot Rods' started by Keepat, Nov 1, 2017.
  1. Keepat
    Keepat
    That is the plan!
    Thanks
    Pat
  2. Donald Insley
    Donald Insley
    kidcampbell71, Keepat and loudbang like this.
  3. rtomss
    rtomss
    Here's the full picture if you don't have it......cool car!
  4. 48fordnut
    48fordnut
    Growing up in B'ham Al, a local hot rodder , now deceased, Dwight Schultz had one of these with a tri power 371 and hydro .He said it sounded like a vacuum cleaner when he got into it. This was late 50s.
  5. Keepat
    Keepat
    Thank you for the picture. This photo and the second one appear to be at some sort of car show. The second picture based on the tag date is sometime in 1968 or early 69? The first picture is sometime between 1966 in early 68? Note the firewall is either white or gray in the first pic. There appears to be a sign in the background on both pictures that I believe says George’s? Was this possibly a display for George’s Corvette shop the people that I believe painted this car sometime in the early to mid 60s?
    Pat
  6. Keepat
    Keepat
    I guess it depends what kind of vacuum cleaner you have if that sounds good or bad ;-)
    Pat
    48fordnut and loudbang like this.
  7. lothiandon1940
    lothiandon1940
    The sign if I'm not mistaken said Prince Georges Kustoms and was likely at the D.C. National Guard Armory where the Ram Rods Club out of Silver Spring held their annual show for many years. It was pretty common for clubs to have a few cars positioned together with such signage on a wall nearby. If you look at the bottom picture above you can see the MS of Kustoms and the ES of Georges.
  8. lothiandon1940
    lothiandon1940
    I still have the programs from the 1964 and 1965 Ram Rods shows. Your car may very well have been in one or both of these shows, but my memory isn't good enough to say yes or no.:( 11302017.jpg 11302017_0001.jpg
  9. Keepat
    Keepat
    Awesome! That makes a lot more sense! I never was any good at Wheel of fortune;-) Little by little putting together the history of this car is so much fun!
    Thank you
    Pat
  10. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Lucky you. I had a 35 Standard 2 dr sedan which is pretty much the same car. Take some none to get it road worthy but it will be worth it. Good luck.
  11. Keepat
    Keepat
    24A1C622-3CBC-4663-8A00-2579AACB6467.jpeg 69B69878-349B-40FC-8CFD-A4A9D36EBE6E.jpeg I received the rebuild original Airheart brake calipers from White Post Restorations today.
    They did an awesome job, wasn’t cheap but they look great. I understand these brake calibers don’t have a very good reputation. I’m hoping that the new steel sleeves instead of the aluminum housing will fix this problem.
    Thanks
    Pat
    catdad49, 4ever18, nunattax and 10 others like this.
  12. lothiandon1940
    lothiandon1940
    They turned out very nice.
    lothianwilly71 likes this.
  13. Keepat
    Keepat
    I hope they work as good as they look! To keep the original look I'm just going to coat the calipers with Sharkhide (link below)
    Thank You!
    Pat
    http://www.sharkhide.com/mpinfo.html
  14. lothiandon1940
    lothiandon1940
    I have no experience with the Sharkhide product, I see that Eastwood is a dealer, but I may have to get some and give it a try. I've been looking for something to protect fuel and brake steel lines from rust and corrosion. Was thinking of brushing POR-15 onto parts that are already showing surface rust. This product may work to give them a coating of protection before the surface rust appears. Thanks, Don.
  15. lothiandon1940
    lothiandon1940
  16. lothiandon1940
    lothiandon1940
  17. TFoch
    TFoch
    Awesome vintage pics of the Chevy!
    Keepat and lothiandon1940 like this.
  18. 29bowtie
    29bowtie
    That is one wonderful old car, that has found the right home. Good luck with the build. Here's a source for grill material. https://www.fillingstation.com/
  19. sproadster30
    sproadster30
    from Natick, Ma
    Looks like a very cool project! Love to see history being preserved as it was. Look forward to seeing the progress, and hopefully a video of that olds motor! Check it out @gonzo
  20. Keepat
    Keepat
    Thanks for the link
    Pat
    29bowtie, loudbang and lothiandon1940 like this.
  21. gonzo
    gonzo
    Man now that is a collector!
  22. Keepat
    Keepat
    They are very cool and I’m planning on having them ceramic coated inside and out to preserve them
    Thanks
    Pat
  23. gonzo
    gonzo
    That's a great plan. I love little details like this, it's especially topical for me as I'm building my Olds 324 headers now and the collectors are pretty tricky. What they did there is a really functional elegant solution.
    lothiandon1940 and loudbang like this.
  24. greyone
    greyone
    Man that is a great car, the guy who built that one loved that car! The nose up stance was popular back in the early sixties and I still love it today. Have fun!!!
    Keepat, lothiandon1940 and loudbang like this.
  25. Dave Downs
    Dave Downs
    from S.E. Penna
    I don't think I've ever seen soldered copper tubing used for fuel lines before. Great car, as mentioned, a neat time capsule, something I would have seen 'back in the day'.
    loudbang, Keepat and lothiandon1940 like this.
  26. Hank37
    Hank37
    You got a great lookin piece of rodding history , do the former owner proud !
  27. Chuck Craig
    Chuck Craig
    from Ocala FL
    Love the old 33/34/35 Chevrolet standards/masters. They are such great cars.
  28.
    Keepat likes this.
  29. Keepat
    Keepat
    Here is a short video the family of the original owner gave me the day we towed his car out of the shed that it had been stored in for over 35 years.
    Pat
    Jet96, 4ever18, texkbc and 11 others like this.
  30. lothiandon1940
    lothiandon1940
