Projects My '54 210 section and chop
Discussion in 'Traditional Customs' started by royalflushcustoms, Apr 21, 2016.
  1. royalflushcustoms
    royalflushcustoms
    Thank you.
  2. royalflushcustoms
    royalflushcustoms
    Been pretty busy. I've decided to take the car to vlv20 this year. So time to at least get the suspension done. Got a lot done in the last week. Upper a arms made upper arm brackets and cross shafts. Will be getting the rack mounted tonight.
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Looks to me like the lower a arm wont have much travel in the spindle? Potential for a lot of flex in those upper a am supports. Staying tuned to see what comes of this. Not much time till viva
  4. royalflushcustoms
    royalflushcustoms
    Yea I'm feeling the crunch. There's about 10 in of total travel in the arms. The car will come down anot her 1 1/4" and it'll still have 1" of upward travel so I'll have enough for speedbumps and gutters. The upper arm mounts are 3/8 plate so there's no give in them. There is flex in the frame from a lack of crossmember. I'll also add gussets from the bag mount to the upper mounts once it's in to help stiffen it up.
    RockinRivi and timmy2times like this.
  5. Go-Man-Go!!!!! A heavy chop and a section, wow, a ton of work! I love sectioned cars and you don't see 'em much. Thanks for all the photos too!
    RockinRivi likes this.
  6. royalflushcustoms
    royalflushcustoms
    Thank you. Yea I love the look. Of course being determine to make everything I can is making it a big project but the finish will be that much more rewarding.
  7. royalflushcustoms
    royalflushcustoms
    Got the steering rack in its final position.
    20170129_215758.jpg 20170129_215806.jpg 20170129_215833.jpg 20170129_215901.jpg
    RockinRivi and johnnyknuckles79 like this.
  8. royalflushcustoms
    royalflushcustoms
    Made progress on the driver side body mount and floor board tonight. 20170130_182455.jpg 20170130_182524.jpg 20170130_224658.jpg
  9. brEad
    brEad
    Just found this thread. I really like your willingness to fab everything & share the process/results. Subscribed.
  10. Okie Pete
    Okie Pete
    Amazing work and vision .
  11. royalflushcustoms
    royalflushcustoms
    Thank you. As I was growing up i was in the gap between magazines and early Internet so I always got intrigued when I found a builder that posted lots of work in progress.
    RockinRivi and Tim like this.
  12. royalflushcustoms
    royalflushcustoms
    Thank you.
  13. royalflushcustoms
    royalflushcustoms
    Overdue update.
    Well we made it to viva!!
    Not running as I hoped for but very close. Need to replenish some funds to get it there but here's some pictures until then.
    20170412_183918.jpg 20170414_214200.jpg FB_IMG_1492387292384.jpg FB_IMG_1492387158132.jpg 20170412_183914.jpg 20170409_232414.jpg 20170414_211847.jpg 20170405_224016.jpg 20170401_213217.jpg 20170505_181007.jpg 20170505_181127.jpg 20170331_231843.jpg 20170405_223919.jpg
  14. royalflushcustoms
    royalflushcustoms
    I ended up bringing down the rear wheel well. Didn't like the smaller well on the front compared to the rear. The car had multiple body damage to both rear quarters. Even a poor half quarter replacement on the driver side. I came up on a parts car so I'll likely be redoing both quarters.
    Im thinking about redoing the rear window using a original frame and stretching the roof over how i have stretched the catwalk now.
  15. royalflushcustoms
    royalflushcustoms
    Started fitting my gas tank. Decided to go with a poly tank with in tank pump. I've seen a few cars with stainless tanks but with in tank pumps they seemed to to be much noisier than poly tanks. 20171215_224535.jpg
  16. Cragrat
    Cragrat
    woah...loving this
    Subscried
  17. brEad
    brEad
    Looks good. Rear fender mod sounds like a good idea, too.
    royalflushcustoms likes this.
  18. Król
    Król
    Incredible fabrication!
    royalflushcustoms and bako48 like this.
  19. Black Clover Custom
    Black Clover Custom
    Maybe try a smaller rear window from another car if that original is too much work to get it to fit right. Like a chopped model a rear window. Easy. Just my opinion. Your car is sick btw. So much good work done to it.
  20. royalflushcustoms
    royalflushcustoms
    Thank you
  21. royalflushcustoms
    royalflushcustoms
    I've considered using a couple style window but I like the curved rear gl*** too much.
  22. royalflushcustoms
    royalflushcustoms
    Made a fan shroud out of 16 ga stainless
    Remote mounted coils
    Had alot of rust under the trunk latch so I replaced it with one off a donor car. 20180130_000929.jpg ran my brake line down the link bar. All stainless lines. 20180404_215506.jpg started fitting the new window frame.
    Everything fitted and new valve covers
  23. royalflushcustoms
    royalflushcustoms
    Clip of her first time running.
  24. royalflushcustoms
    royalflushcustoms
    Short walk around at a local show.
  25. jdownunder
    jdownunder
  26. joee
    joee
    gotta tell ya ur one fine craftsman.......just outstanding work and talent
  27. spurgeonforge
    spurgeonforge
    Wow! Just awesome! You are one talented guy. Can’t even imagine how many hours you are into it so far.
  28. royalflushcustoms likes this.
  29. royalflushcustoms
    royalflushcustoms
  30. royalflushcustoms
    royalflushcustoms
    Thank you
    Sent from my SM-G925V using The H.A.M.B. mobile app
    spurgeonforge likes this.
