Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. DDDenny
  2. rudestude
    rudestude
  3. Fordors
    Fordors
    Holman-Moody cast those cases for off shore boat racing, probably used them on 427 FE’s. I bet that C’6HM 9100 MU1 number is a Holman-Moody p/n.
    Check out the top, it was originally machined for two 4160 Holleys mounted right on it and later somebody drilled and tapped it for a Weiand (most likely) 2-4 adapter
    chryslerfan55 and mad mikey like this.
  4. rudestude
    rudestude
  5. loudbang
  6. loudbang
  7. loudbang
  8. loudbang
  9. rudestude
    rudestude
  10. saltflats
    saltflats
    from Missouri
    What's going on with this blower?
    Looks like a 871 with the rotors moved to the front.
    And is that a belt idler pivot on the front drive cover?
    chryslerfan55, mad mikey and loudbang like this.
  11. Dean Lowe
    Dean Lowe
    That's Ohio George's Willys before the Ford SOHC. George always ran a pruned 6-71 to save weight. Yes, that is the idler arm pivot. George eventually got with Pete Robinson, another weight conscious guy, and they made magnesium pruned blowers.
  12. loudbang
  13. loudbang
  14. Fordors
    Fordors
    The Bones, Dubach & Pisano ‘33 Willys with it’s distinctive injector scoop. Looks just like the scoop first seen on the Speed Sport Roadster and later also used by the Greek. Karamesines had ties to the Speed Sport gang through Don Maynard and Joe Bush.
    BTW, I always considered Maynard the Austin Coil or Dale Armstrong of his era.
  15. loudbang
  16. paul55
    paul55
    from michigan
    Pontiac crossram on an engine I did a few yrs. ago. pontiac engine 005.JPG pontiac engine 007.JPG
    Stebo27, 1947knuck, enloe and 8 others like this.
  17. Dean Lowe
    Dean Lowe
    Gary Dubach's 33 was my favorite g***er. Gary was a fan of the Greek, hence the Speed Sport scoop by Red Greth, and the Chizler too lettering on the front. I think the Scoop Red designed and made in 1957 is the best scoop ever done. A few years ago I was fortunate enough to have Red lay one up for me in the original mold. My RPU wears it with pride!
  18. loudbang
  19. loudbang
  20. loudbang
    A bunch for the weekend crowd. :)
    1947knuck, Stebo27, enloe and 6 others like this.
  21. fol
    fol
  22. rudestude
    rudestude
  23. mad mikey
    mad mikey
  24. mad mikey
    mad mikey
  25. mad mikey
    mad mikey
  26. mad mikey
    mad mikey
  27. mad mikey
    mad mikey
  28. mad mikey
    mad mikey
  29. loudbang
  30. mad mikey
    mad mikey
