Technical This is how I cut windshields down for top chop vehicles
Discussion in 'The Hokey Ass Message Board' started by ChrisBlattie, Dec 4, 2017.
  1. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    loudbang and czuch like this.
  2. old man hal
    old man hal
    The reason you don’t score both sides first is because once you score the gl*** you only have a few minutes to run the score. If you wait to long the run won’t follow the score line and run off in another direction.
    loudbang, Hnstray and belair like this.
  3. blowby
    blowby
    from Nicasio Ca
    Interesting, thanks. Good to know that even after scoring the first side it's no time to take a break (pun intended).
  4. Wrench666
    Wrench666
    Do you mean the “safety squint” doesn’t work
    Gavin Tittle and loudbang like this.
  5. catdad49
    catdad49
    If you have a stained gl*** store in your area they will carry the oil filled cutter and also the pliers.
    49ratfink and loudbang like this.
  6. s55mercury66
    s55mercury66
    from SW Wyoming
    Thanks for taking the time to post this, Chris. Way cool.
  7. thunderbirdesq
    thunderbirdesq
    Awesome! Thank you for sharing this knowledge!
  8. The37Kid
    The37Kid
    Thanks! I'm going to try this, looks a hell of a lot easier than wiring a car. ;)Bob
  9. Mr48chev
    That is one interesting video. Thanks for sharing.
  10. The37Kid
    The37Kid
    Oil filled cutters are on eBay and very reasonable. Bob
  11. ChrisBlattie
    ChrisBlattie
    from Montana
    This is the pieces that I cut off and then the windshield before sanding.
    catdad49 and loudbang like this.
  12. 19Fordy
    19Fordy
    Chris, Thanks so much for posting that thread. It takes the
    mystery out of it. Hope you post more that include the sanding and shaping.
    What do you use to seal the edge of the gl***?
    slack and loudbang like this.
  13. henryj1951
    henryj1951
    from USA
    Best i've seen *lately* watched the old guys do this back in the late 50's
    GOOD stuff there maynard (ah Chris).
  14. Wrench666
    Wrench666
    Could a propane torch be used instead of the alcohol
    Great video. Gonna try on a square body windshield for practice.
    Thanks Andrew
  15. lewk
    lewk
    from Mt
    That was awesome, thanks for sharing. Every tap made me nervous.
  16. 19Fordy
    19Fordy
    Propane torch won't work as it heats unevenly and is too hot.
    Wrench666 likes this.
  17. nutbush
    nutbush
    from Texas
    Great post and demo. Concise, well spoken, too the point. After watching DIY videos on YouTube and enduring um, uh, and 90% useless information, this video was very good. Thanks for posting!!
  18. The 39 guy
    The 39 guy
    Thanks for posting this excellent video. Audio was very weak until I plugged in my headphones to my laptop. Came in loud and clear after that.
  19. Chris, very good video, thank you JW.
  20. desotot
    desotot
    I'm wondering what the success rate is and how much you charge to cut a curved ws.
  21. ChrisBlattie
    ChrisBlattie
    from Montana
    I get about 9 outta 10 cut without breaking, and I charge about 250 to cut one down
    flynbrian48 likes this.
  22. BJR
    BJR
    Who pays if you break it? Just wondering how that part of it works.
  23. ChrisBlattie
    ChrisBlattie
    from Montana
    It's the customers gamble. I don't guarantee I can cut them, but I'll sure try my best! I usually have the customer buy the windshield and just have it sent to me. Then i cut it & put it back in the box and send it to you!
  24. buffaloracer
    buffaloracer
    from kansas
    Thanks Chris. I'm going to give it a try.
    Pete
  25. 5window
    5window
    Very nice video, thanks. I find it interesting that the gl*** is scored moving away from you. Many of the gl*** cutters I have seen use a "pull" rather than a "push" stroke. I'd suggest to the uninitiated to use a specific gl*** cutting oil, although I have used a mix of kerosene and 3:1 oil. Pliers are available from stained gl*** suppliers- Warner Gl*** in Allentown,PA, Whittemore-Durguin in MA, and Delphi in Ohio are a couple of places. Pliers can be purchased with parallel steel jaws (grozing pliers) or slightly curved jaws with plastic coverings (running pliers). I like the latter for stained gl*** work.
    Chris, how are you finishing/sealing the edges after sanding?
