Technical Street/Strip Cam for a Hot 390
Discussion in 'The Hokey Ass Message Board' started by FullsizedFordFeller, Dec 6, 2017.
  1. FullsizedFordFeller
    FullsizedFordFeller
    Hello everyone! I'm currently putting a 390 in my '64 Galaxie that I picked up recently off the List; and I was wanting to put a beefier cam than stock in while the motor is out. I'm wanting a cam that's going to be street-able while having a of idle-lope. Really I'd like to go about as radical as a can before the thing becomes undrivable, but mainly I want something that's going to give this engine a fair amount of low-end *** and sound pretty mean. The details on the engine/ car are
    C3AE 8015-H 390 block bored .03 over
    '64 thunderbird intake (I forget the casting code for it)
    Holley 650
    C3AE-C 64CC heads
    Upgrades valve springs (dual spring setup, not single spring like stock)
    Stock rockers
    4 speed
    3.55 gears
    29inch tall tires.
    This is just my toy so I'm not really worried about fuel economy or it being remotely practical. So let know what you guys think, Thanks!
  2. deucemac
    deucemac
    I've used Schneider Cams "little - big" cam with good results a couple times.
    Or, just call Jerry Cantrell at Schneider and get his view. 1 (619) 297-0227. I had one in my 64 galaxie 390/4 speed and loved it.
    loudbang and olscrounger like this.
  3. FullsizedFordFeller
    FullsizedFordFeller
    I'll give him a call, Thanks!
  4. FrozenMerc
    FrozenMerc
    I built the 390 in my '76 F-250 for use as a work / pulling truck. That said, it has pretty similar specs to your Galaxie motor.
    Ford iron 4 bbl intake and heads. 9.5:1 Compression, 0.30" over bore, Long tube headers, Holley 600, etc.
    I am running a Howard Cams Dual pattern cam (Part Number: CL252461-12). The idle is a little loppy, but still has decent vacuum for the brakes and such. All things considered, I am not trying to impress anyone with the idle. People do tend to notice however, when I p*** them on the highway, that 390 in full song, and 10,000 lbs of trailer hanging off the back.
  5. RmK57
    RmK57
    If you want a cam with a a lot of chop to it look at Comp Cams Thumpr series. Iv'e never used one but from the info out their they seem to work pretty good.
    sunbeam likes this.
  6. steinauge
    steinauge
    from 1960
    I am using a comp cams 280 H in my 390 4 speed galaxie and it seems to work well. My engine has cleaned up Ford iron heads,edelbrock performer rpm, ****** headers,750 cfm carb and 10.6-1 cr.I am using points ignition with a modified ford distributor.
  7. sunbeam
    sunbeam
    The comp thumper 33-600-5 will talk to you but for the money Summits sum-1793 is a good cam.
  8. Jalopy Joker
    Jalopy Joker
  9. FullsizedFordFeller
    FullsizedFordFeller
    Wide ratio T10, out of a '65 mustang I believe.
  10. FullsizedFordFeller
    FullsizedFordFeller
    It seems like a lot of people like this cam, I'll definitely have to look into it.
