Hot Rods '35 Pickup Build Thread - Alaska in August '18!
Discussion in 'The Hokey Ass Message Board' started by Boryca, Oct 9, 2017.
  1. Boryca
    Boryca
    from Detroit
    Alright folks, it's time. I've had this truck about 6 years now, and have done precious little in the way of improving it. I did dis***emble it though... mostly.
    Here's the thing - I entered a road rally to Alaska in August of 2018 with a recent build, a '69 Torino, that I just sold. So, no rally car. But I have this truck sitting around, and I've been meaning to start/finish it, so what better time than now? It does run, and lot drive, but it has very little going for it otherwise. Follow along as I attempt to get this done!
  2. Deuces
    Deuces
    Looks like a great project for a g***er build....
  3. Budget36
    Budget36
    What's all that clear stuff coming up through the doors and in front of the driver?
    Ya, had a few of them;)
    Boryca likes this.
  4. Texas Webb
    Texas Webb
    Be sure and take some extra ratchet straps.
  5. Boryca
    Boryca
    from Detroit
    And we have updates! I got the truck in the garage, after hanging some lights, building a workbench, and putting up some shelves. Now I can finally get to work.
    Got the cab off the other day with some help, now to get this rolling ch***is driving!
    [​IMG][​IMG][​IMG][​IMG]
    mgtstumpy and kidcampbell71 like this.
  6. Boryca
    Boryca
    from Detroit
    Oh hey! Can anyone tell me where this frame comes from? I know it's been fabbed, but I have no idea who might have done it. Real good quality though.
  7. Boryca
    Boryca
    from Detroit
    Today I got the rear end out along with ***ociated parts. Now to clean them up a bit and get them to the powder-coat guys. I'm also planning on using the '35 radius rods with the late Columbia 2-speed, so I'll have to fab some brackets for that.
    mgtstumpy likes this.
  8. Boryca
    Boryca
    from Detroit
    Update! I've been busy, despite my lack of showing it here... got the rear radius rods all cleaned up and shiny, same with the torque tube. I'm currently working on adapting the '35 rods to the '46 ish Columbia with its larger axle diameter.
    [​IMG][​IMG][​IMG]
  9. 37Pickup
    37Pickup
    Love the truck, keep up the good work!
    Boryca likes this.
  10. Boryca
    Boryca
    from Detroit
  11. Boryca
    Boryca
    from Detroit
    Got some more things done! Rear driveline pieces are ready for powder coat. Columbia internals look real good aside from one gear that's a bit pitted, and front end is mostly apart.
    I'm going to need some new shock mounts though. I had to mangle mine to get them out, so if anyone has a line on a good set, let me know!
    [​IMG][​IMG][​IMG]
    mgtstumpy, kidcampbell71 and 37Pickup like this.
  12. Boryca
    Boryca
    from Detroit
  13. Boryca
    Boryca
    from Detroit
    Tires are off and wheels are ready for blasting and painting. Took the front end off too, and boy are those axle perch bolts stuck! did a lot of heating and hammering to no avail, so my buddy Tom took the whole thing up to his dad's shop and got it dis***embled.
  14. Boryca
    Boryca
    from Detroit
    I got some things done this weekend in the cold. Engine and trans are out, and some small parts are at the powder coater. Since I have a manufactured frame, I measured all the holes and such, and found that I'm missing a couple, so I'll have to add those in.
    Also, I found that the front crossmember (and thus my motor mounting position) is flush with the frame - correct for '39 and later I believe - and I need it 1" under the frame rails, so I cut that out and will be modifying and reinstalling this week.
    [​IMG][​IMG]
  15. Boryca
    Boryca
    from Detroit
    mgtstumpy, kidcampbell71 and slv63 like this.
  16. RMR&C
    RMR&C
    from NW Montana
    Looking good!
    I'm following your build as I'm just starting on a '35 PU project.
    Boryca likes this.
  17. Boryca
    Boryca
    from Detroit
    Glad to hear it! I started to think I was talking to myself. [emoji16]
  18. 1946caddy
    1946caddy
    from washington
    No need to worry until you start to answer yourself. :D
    Jet96 and slv63 like this.
  19. Boryca
    Boryca
    from Detroit
    Then color me worried!
    bct likes this.
  20. King ford
    King ford
    from 08302
    Keep sharing bro, we are watching!
    Boryca likes this.
  21. Boryca
    Boryca
    from Detroit
    I did some work this weekend fabricating trans mounts and welding them in. Planning on using a rubber spacer to mount, not unlike the front engine mounts. I've got the rest of the frame pretty much sorted, so I think it may be time to clean and paint!
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    mgtstumpy and RMR&C like this.
  22. Boryca
    Boryca
    from Detroit
    Trans mounts are in and welded and such, and the wishbone and front axle are off to get prettied up with some powder coating. I drilled some holes and test fit the tank yesterday.
    [​IMG][​IMG][​IMG]
  23. Boryca
    Boryca
    from Detroit
    Oh! And some parts showed up. My garage is getting smaller...
    Frankie47, mgtstumpy and bct like this.
  24. Boryca
    Boryca
    from Detroit
    Well gents, I’ve been getting a little work done over here, namely finishing the frame mounting points and getting the axle housing tubes machined and repaired.
    mgtstumpy, chop job and RMR&C like this.
  25. patterg2003
    patterg2003
    I am a fan of the 35-37 trucks. Really enjoying your build & your goal of the Alaska rally. Thanks for sharing your good work.
  26. Boryca
    Boryca
    from Detroit
    Thanks Patterg, good to hear you’re enjoying! They’re my favorite year too, just something about ‘em.
  27. Boryca
    Boryca
    from Detroit
    Took the frame in this week for blasting and powder coating, along with some small parts. While I’m waiting to get it back, I finished mounting tires. The traditional way... [emoji23]
  28. Boryca
    Boryca
    from Detroit
    Got a special delivery from North Dakota by way of Illinois this weekend. Now the real fun begins!
    Also, shop dog. She mostly just gets in the way and dirty. Hard to keep from petting her with greasy hands...
    mgtstumpy, bct and kidcampbell71 like this.
  29. bantam
    bantam
    Hi - Enjoying your build. I also have a frame to get powder coated in the near future. Do you mind sharing the cost of blasting and powder coating your frame so I, and the rest of the HAMB, can have a budgetary price against which to compare the pricing we get locally?
    Thanks
    Bantam
  30. here is my shop "pal" and my 36...you're moving along really well...****s trying to build a hot rod through Detroit's nasty winters but it does give us something to do each crummy day...looking forward to Autorama in a couple weeks
    Boryca likes this.
