Hot Rods Flathead or Hemi
Discussion in 'The Hokey Ass Message Board' started by cabriolethiboy, Apr 29, 2017.
Hemi or Flathead
Poll closed May 6, 2017.
  1. Hemi
    65.9%
  2. Flathead
    34.1%
  1. 40Standard
    40Standard
    from Indy
    I'd go with the Hemi
    Aussie Steve likes this.
  2. phat rat
    phat rat
  3. Jimmy2car
    Jimmy2car
    from No. Cal
    I voted Hemi, but I have a 32 with a 290 inch Flathead that will go anywhere.
    I have a 4 speed Toploader & behind that a Gear Vendors OD.
    I just love the look of the Hemi.
    If it were me, I'd want a larger Hemi (Desoto 345") maybe?
    JMO
  4. Bandit Billy
    Bandit Billy
    I sure wouldn't go with the flathead for the reasons a few already stated;
    They're slower than a hemi,
    They're no as good looking as a hemi,
    They're not even cooler than a OHV
    They're not built well
    And it makes my car that much cooler when we meet.
    55styleliner likes this.
  5. Kiwi 4d
    Kiwi 4d
    To cut a long story short there is absolutely no issue with long road trips with either choice . Just use care in ***embly and parts choice and you will have miles of smiles. We have done thousands of miles in all our flatheads and never had a problem or breakdown. A decent size motor with appropriate gearing and cooling will go forever as they say.
    Throw it together with unknown or used parts is a recipe for drama on the road.
    Hemiman 426 and pitman like this.
  6. Lucky Burton
    Lucky Burton
    I'm a flathead guy alway have been but I too just recently decided to put a dodge 270 in my 32 for drive ability. I want to be able to drive to different states with out worrying bout over heating to much..
  7. 38 mopar_fan
    38 mopar_fan
    392
  9. Bearing Burner
    Bearing Burner
    from W. MA
    IF YOUR GOING TO BE DRIVING ON LONG HAULS FINE SOMER
    I f you going to be doing a lot of long hauls finde a modern rengine you can readily get parts for in West Overshoe.
    I
  10. Blaise the Barbarian
    from Colgate UK
  11. Blaise the Barbarian
    from Colgate UK
    Built this for my Anglia but sadly ran out of steam and sold it in bits !! Flatheads look the biz but the hemi !!
  12. gimpyshotrods
    gimpyshotrods
  13. das858
    das858
  14. chop job
    chop job
    from Wisconsin
    FLATHEAD
    car doctor likes this.
  15. 392
    392
    HEMI
    Hnstray likes this.
  16. spanglishkings
    spanglishkings
    from Napa, CA
    I like your style, Bruce!
  17. car doctor
    car doctor
    Do you have a cabriolet highboy? Have to add I have put over 9200 miles on my flathead the last two summers and I still love it!
  18. sunbeam
    sunbeam
    Takes a pretty good street flathead to make 200 hp even a 241 hemi can make those numbers with pistons, cam, and a good carb easy.
    Hemihead_NHRA, Hnstray and zzford like this.
  19. hammerd 31
    hammerd 31
    Well it makes the cart look fast:D
  20. 49clubcoupe
    49clubcoupe
    from idaho
    Flathead all the way. Flatheads forever!
    Sent from my VS835 using Tapatalk
    Bandit Billy and car doctor like this.
  21. I am really torn on this, but I am going with Hemi.
    Bob
  22. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Hemi! [​IMG]dodges fit great without modifying the firewall. Desoto are tight. My brother has a 276 in his pickup.
  23. 55styleliner
    55styleliner
    After 2300 miles of trouble free cruising in my Flathead powered AV8 I would say that reliability would not concern me, Only power. The big inch flattie should be over 180hp and 230ft/lbs. not sure what the Hemi will make but probably more right?
  24. Mr cheater
    Mr cheater
  25. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    HEMI! But why put a small one if that's the case? If your gonna go for the big valve cover, go BIG, like the 392, or a 354........Even us HEMI guys aren't big on the little engines...... Wear the badge, wear it to the extreme! Wear it proud!
    gimpyshotrods likes this.
  26. 73RR
    73RR
    Both engines are expensive to rebuild but with similar equipment the DeSoto will make alot more HP/TQ.
    Both engines will require an adapter of some sort for a 5-spd but an AX15 behind the 291 might be a less expensive package when everything is on the garage floor.
    The DeSoto will be limited on intake choices unless you get lucky or have lots-o-cash to toss around.
    My last flathead was in a 53 Merc back around 1966 but I haven't forgotten about it being a bit sluggish...
    Hnstray likes this.
  27. I vote flux capacitor
  28. dan31
    dan31
    I'm glad that I don't have to decide but wish it was a decision I needed to make.
    Bandit Billy likes this.
  29. cabriolethiboy
    cabriolethiboy
    OK, the plan is for the Hemi. The ch***is is about done. I haven't started on the motor yet but will probably do so soon.
    Good news is my cancer is in remission and I feel good. My 15 year old grandson is interested in hot rods so we have started on a 27 roadster pickup hiboy. It is on a deuce frame, and the body is ready to pick up from Redi-Strip. The frame is still in the jig. He is learning a lot and has been doing some MIG welding, heating and bending, and sawing on the band saw. I am elated that one of the grandkids has an interest. He lives about 40 minutes away so with basketball practice he only has Sunday to work on it. But we have been getting a lot done. Hope to show some pics soon. I am probably as excited as he is.
    zzford, 40FORDPU, dan31 and 3 others like this.
  30. pprather
    pprather
    Glad to hear you are back in the shop. Both builds sound great.
    I suspect most posters on the power plant question don't know what you mean when you say you want to be able to 'drive it'.
    Looking forward to pic's of both builds.
    zzford likes this.
