Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. tarcoleo
    tarcoleo
    The Flying Feather. About 200 were made in Japan in early '50's from motorcycle components.
    banjeaux bob likes this.
  2. banjeaux bob
    banjeaux bob
    from alaska
    Cool stuff! Thanks!
  3. fredvv44
    fredvv44
    1914 Grand Canyon. anyone know the car?
    motoklas likes this.
  4. Looks like early Hupmobile- maybe 1910-ish?
  5. Kume
    Kume
    maybe a Spacke?
    He looks depressed!
  6. banjeaux bob
    banjeaux bob
    from alaska
    1914 Metz on the rim of the Grand Canyon near El Tovar.
  7. noboD
    noboD
    And a nutcase sitting on the ledge!
  8. banjeaux bob
    banjeaux bob
    from alaska
    one thing for sure...he's no elf on a shelf.
    daren w and 64 DODGE 440 like this.
  9. Airhead Roadster
    Airhead Roadster
    364B768F-BDB0-427F-90A6-E8A9EEF556B2.jpeg 0B4757D5-3D8F-4504-87E4-8DE9399F59A5.jpeg 57D45911-86C8-4951-8113-B1CC7EF5543E.jpeg
    Aloha Zoran. Sorry to report I haven’t done much of anything on the Airhead Roadster. I felt guilty about that, so today I pushed it out of the garage so I could sweep under it and took the opportunity to remove the lowering blocks and long U-bolts I had installed and returned the car to its original ride height since I’ve decided to go more traditional with the stance rather than sporty. I also remounted the front beam to spring-over to bring it back up as well.
    I’ll be ordering a set of dies for my roll bender soon to allow bending of smaller diameter tubing as I plan to make the body support structure of it. I have a pretty good idea of the direction I want to go in now and will start shaping cardboard soon in preparation of building a wooden buck. Then I’ll use the cardboard as a guide for roll bending the supports.
    I took a few photos while it was out of the garage getting a sun tan today. It still rolls!
  10. Erik B
    Erik B
    Working on some exhaust tips in 316 stainless. Very hard to form but welds and polishes beautifully.
  11. motoklas
    motoklas
    from Bern, CH
    I took a few photos while it was out of the garage getting a sun tan today. It still rolls![/QUOTE]
    Aloha, AHR!
    I am now at holiday in my Belgrade, so just a few words!
    I am sorry that you didn't finish your magnificent cyclecar, but I am happy that you are still working on it! It would be good to have it in running conditiin, so you could have a few rounds around, just for feel and inspiration for futher work!
    Regards,
    Zoran
  12. fredvv44
    fredvv44
    Erik, now a cabin on a catamaran is something you don't see every day. LOL
  13. motoklas
    motoklas
    from Bern, CH
    ... cabin katamaran (with engine?), Porsche 326, classic JEEP... what else?
    Maybe ultralight airplane?
    Zoran
  14. Rolfzoller
    Rolfzoller
  15. Airhead Roadster
    Airhead Roadster
    No need for an ultralight when your boat doubles as a hovercraft! Kidding of course, but I do joke with people about that when they look at it with the motors in the vertical trailering/launching position. That boat (whiched I’ve named SolGato) is one of the reasons I haven’t gotten much done on the AR project. It’s the second one I’ve built. It’s solar electric powered using two 55lbs thrust motors controlled by wired remotes. My last boat only had one motor, but on this one I decided to try something different by eliminating the tiller and using the independent forward and reverse thrust of each motor to propel and steer the boat. It works awesome and is kinda like driving a tank on water or more so operating a space shuttle in space, and the remotes allow for operating the boat from any position as you can see from photo. Anyway I just added the camper shell to it the other day as I always thought a removable shell would be a great addition/neat adaptation to a small catamaran.
    Alright, enough about boats.
    So I got the steering box remounted on the Airhead Roadster. It’s been a challenge trying to find the best spot for it. Originally it sat on top of the frame but with the boxer motor the right cylinder wants to live in the same space. So I decided to mount it further back and in inside the frame so that the box sits lower. The shaft now comes through a hole in the frame channel and accepts the pitman arm. Looks like all I will need to do is extend the straight portion of drag link to maintain proper geometry and travel without interference from wheel when turned full lock. Will also need to fabricate a heat shield and run extra HD oil as the box sits very close to the cylinder, but think it should be okay.
    And so one more major piece of the puzzle has fallen into place!
  16. banjeaux bob
    banjeaux bob
    from alaska
  17. banjeaux bob
    banjeaux bob
    from alaska
    This cyclecar thread is now 10 years old.
    tarcoleo, Rolfzoller, Kume and 3 others like this.
  18. banjeaux bob
    banjeaux bob
    from alaska
  19. fredvv44
    fredvv44
    It has been an amazing few years that I've been following it. Thanks to everyone that has contributed.
    tarcoleo and Rolfzoller like this.
  20. Kiwi Tinbender
    Kiwi Tinbender
    I`m not on here anywhere near as much as I used to be, but this thread is one I always update myself with. Fred V is right. Thanks to all, especially to you, Bob, for guiding it along.
    Rolfzoller likes this.
  21. Rolfzoller
    Rolfzoller
    loko, chrisp, Herb Kephart and 6 others like this.
  22. Rolfzoller
    Rolfzoller
  23. banjeaux bob
    banjeaux bob
    from alaska
  24. Rolfzoller
    Rolfzoller
  25. banjeaux bob
    banjeaux bob
    from alaska
    24993393_10214639040957751_1495613314571746363_n.jpg Amilcars in OZ from Doug G. .
  26. Rolfzoller
    Rolfzoller
  27. motoklas
    motoklas
    from Bern, CH
    Rolf, thank you on wonderful photos!
    Great cars, great adventure in nice countryside. Brave men in fast open automobiles at quite low temepratures.
    At 3rd photo is your old Salmson?
    What are two smaller cute autos at last photo?
    Ciao,
    Zoran
  28. Rolfzoller
    Rolfzoller
    Hello Zoran,
    Yes that was my Salmson,I forgot the brand of the two cars on the last photo.
    Regards Rolf
  29. Rolfzoller
    Rolfzoller
    Herb Kephart and banjeaux bob like this.
  30. banjeaux bob
    banjeaux bob
    from alaska
