Projects Almost Funny - AWB Barracuda Funny Car Build
Discussion in 'The Hokey Ass Message Board' started by squirrel, Nov 27, 2017.
  1. Uh.Kind of a large chute housing!
    brigrat likes this.
  2. Looks like it has safety straps (seat belts) holding the back gl***
    Later body style had hood pins thru the back gl***- that's after the wreck with Jay Leno
    And the clamp strip with screws
    saltflats, loudbang and henryj1951 like this.
  3. Where's the radiator going? are you buying a gas tank or making one?
  4. DDDenny
    Yeh, I doubt that the Drag Week types give that much thought, more of a HAMB scheme.
    loudbang and Gary Reynolds like this.
  5. Very true! I doubt they even KNOW what the HAMB is!
    But I am a HAMBER and I think and act like one!
    My Avatar pic is from 1966! Later I owned a 66 Cuda!
    The Spirit of the 60's!!! 1966 was a good year! A peak for drag racing AND street cars!
    We really were GREAT back then!
    hendelec, henryj1951 and squirrel like this.
  6. squirrel
    I'm gonna have enough challenges with this car, don't worry!
    for one, I'm signing up for a Heliarc welding cl*** (no, they don't call it that) at the community college, so I can remember how to TIG weld, and then I will have to buy a welder, then I can build the cage out of chrome moly tube, to save 25 lbs. And I'm going to get a rear end jig so I can shorten the rear end. I've never actually run a 4 link before, so that will be fun and exciting. The list goes on and on.
    But...on the good news front, I scored a couple axles today. An A-100 front axle with steering and brakes, and a Dana 60 from the 1960s (no, it's not from a Dodge, nor a 3/4 truck...keep guessing!)
    Pics soon. After I unload them.
    kiwijeff, APACHE FS, brad2v and 6 others like this.
  7. Oh yes sir, we are going to the moon!
    Kennedy said new metal alloys, some of which are not yet invented.
    Stanley Cubric figured all that stuff out for them.
    loudbang, henryj1951 and Clay Belt like this.
  8. DDDenny
    They did in 65.
  9. Clay Belt
    Clay Belt
    Sounds like this ****er will be awesome
    chadhollem and Gary Reynolds like this.
  10. DDDenny
    Corn binder, oh, you said not a 3/4 ton, must be a 1 ton then.
  11. COOL!!
    Good scores!
    I DO think of this as a "going to the moon" project.
    Just Gary likes this.
  12. You can weld 4130 with a torch with no problem. You can also use standard steel rod, or you can buy 4130 rod. That is how the majority of aircraft tubes were, and homebuilts still are, built.
    There are some really fantastic tutorials on youtube, one of the better guys is, welding tips and tricks. Have a look, and you will be impressed.
    For TIG welding, I use a Miller Syncrowave 250, and I love it.
    You may get addicted.
    Bob
  13. henryj1951
    henryj1951
    from USA
    6k it would be an addiction alright ...
    joel likes this.
  14. ididntdoit1960
    ididntdoit1960
    from Western MA
    Pics soon. After I unload them.[/QUOTE]
    i once found one in a jeep 1/2 ton pickup with flanged (non floating) 5x5.5 axles.....it wasnt even that wide.....used in in an OT project....
    Willy_P, APACHE FS and loudbang like this.
  15. Jim, do this with viggah!
    Just stay away from Mafia girlfriends and Dallas!
    Old folks will get this.By the way, you need a chute, just for effect if nothing else!
    dan31 likes this.
  16. squirrel
    The rule book says something about needing a chute for 150 mph.
    And it says something about welding 4130 with an approved TIG process (not a torch).
    So....
    And I need to do a bit more research on the rear, it might have something screwy with the pinion offset or something.
  17. chevy57dude
    chevy57dude
    Hangin' laundry as it were!
    A good problem to have, needing a 'chute. Very glad for you, Jim that you are able to put this together. Bucket list dream stuff for many, and you are living it.
    mad mikey and loudbang like this.
  18. 97
    97
    :eek:Jeez 20 pages and not a cut has been made.:p:p Hambers get excited when proper projects emerge.
  19. DDDenny
    Van?
  20. DDDenny
    Jim, you've been telling us for a long time how cheap you are (your words) so I wouldn't think its out of a factory Plymouth hipo car cuz.......they aint cheap.
  21. I can understand the requirement for using TIG. An inexperienced welder using a torch might not cool the weld correctly, or could crystalize the weld.
    Bob
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've also noticed this isn't the usual course of action. Maybe this is the "last stand" and then Jim will go away quietly on top.
  23. squirrel
    Oh, I'm still cheap. I haven't spent any big money on anything yet for the car...aside from buying it for way more than I normally spend on a project.
    One of these days, soon, I'll spend some money on this thing.
    brad2v, Gary Reynolds and saltflats like this.
  24. 97
    97
    yeah maybe NOT too... A full blown 70s Nitro funny car is the next step up that ladder, but that's not in the HAMB era, so maybe this forum will never know. :rolleyes::cool:
  25. squirrel
    heh...how'd you guess? although someone else is supposed to be working on that one!
  26. squirrel
    A few pictures. The rear axle is a 1966 Ford half ton pickup Dana 60. It originally had 30 spline 5 lug axles, and was not a full floater. Pretty much the same rear as in my 59 Chevy pickup, that rear is from a mid 60s GMC half ton...just different axles, 5 lug vs 6 lug. 3.54 posi (or whatever Ford called it). There is an issue with some of the Ford trucks with Dana rears--they use a model 61 instead of a 60, and there are some differences with the pinion location, so you can't use a 60 differential in a 61 housing, unless you use a ring gear spacer. But that's not a problem with the rear that I got, which is a 60, it says so on the housing. The gears are normal ****er 60 gears, the carrier offset is as it should be in a normal 60 rear end. I'm planning to use the 3.54 gears if they look ok after I get them out and cleaned and inspected. I also plan to use a spool. The differential weighs 40 lbs...that's kind of heavy.
    I have not checked out the front axle yet, that's coming up.
    a100 axle assembly.jpg 60 axle assembly.jpg 60 build tag.jpg 60 gears numbers.jpg 60 posi weight.jpg
  27. Jim; Have you done much round tube cage type work?
  28. squirrel
    Nope. Not much.
  29. Are you up for some input on how myself and maybe some others have done things?
    The Wizzard
  30. squirrel
    Yes, I am. I always welcome ideas and tips. And especially, the voice of experience.
    But don't be surprised if I want do do things a bit differently.
