Hot Rods Ryan's Falcon - Young Gun's Straight Axle Build
Discussion in 'The Hokey Ass Message Board' started by Saxxon, Oct 28, 2017.
  1. choppednslammed
    choppednslammed
    Subscribed !!! Your making my job easy .. I’m putting a 460 in a ‘64 Comet
    chryslerfan55, Rye-guy and loudbang like this.
  2. Rye-guy
    Rye-guy
    IMG_0655.JPG IMG_0656.JPG IMG_0657.JPG IMG_0658.JPG IMG_0659.JPG IMG_0660.JPG IMG_0661.JPG IMG_0662.JPG IMG_0663.JPG Probably one of the biggest hurdles has now been p***ed, the motor is finally in! May only come out once more to finish painting and cleaning up the engine bay.
    The transmission is also mocked up in place so now it just needs to be put back together.
    To mount everything we used a mid plate from I believe Baer or maybe compe***ion engineering, I can't remember, and used side mounts from speedway motors.
    Now we need to figure out how to make an air filter fit because it does not fit on top of the carb with the set back we put in.
    enloe, Hank37, mad mikey and 5 others like this.
  3. edcodesign
    edcodesign
    Good to see a young gun get the bug ! Nice work !
  4. saltflats
    saltflats
    from Missouri
    Big engine check.....small car check.
    What's not to like. ;)
  5. loudbang
    AND FORD Power :)
  6. choppednslammed
    choppednslammed
    Quick question ... for the motor setback which cylinder is above the straight axle ? I’m getting ready to start my build and that’s one thing I wasn’t sure about ..thanks
    mad mikey, chryslerfan55 and loudbang like this.
  7. Rye-guy
    Rye-guy
    Honestly I'm not sure, I'd have to look again, but we didn't measure from there, all we did was just 4 inches from the original firewall but it's really all personal preference, the 4 inches gives us enough room in front to go with almost any size of radiator as well as electric fans
  8. Rye-guy
    Rye-guy
    Oh and also just make sure you don't go so far back that the headers won't have somewhere to go
    enloe, mad mikey and chryslerfan55 like this.
  9. choppednslammed
    choppednslammed
    Ok cool ... Thanks !
  10. RmK57
    RmK57
    Looks good! Now you can really appreciate having the distributor up front with that kind of engine set back.
    mad mikey, loudbang and chryslerfan55 like this.
  11. Saxxon
    Saxxon
    I can sooo relate to that. My sbc is shoved into the firewall and it's a serious pain in the **** to adjust and even service. Looked at a front drive more than once or twice
    loudbang and mad mikey like this.
  12. Ghost28
    Ghost28
    1. Gotta follow this build. Thanks
  13. Rye-guy
    Rye-guy
    I also forgot to mention we lowered the engine as much as we could, and the oil pan will be changed out for a rear sump oil pan or else the steering will hit it as well as possibly the axle when the springs compress, jegs sells a kit to put these motors in mustangs and it's the rear sump pan, dipstick and oil pump I believe, all you need to buy extra is a rear sump oil pickup
    chryslerfan55, loudbang and Saxxon like this.
  14. Tickety Boo
    Tickety Boo
    from Wisconsin
    Speedy agrees he wants more FOMOCO powered cars, a more target rich environment. :D speedy.jpg
  15. rawcjw19
    rawcjw19
    Nice job guys. Your falcon is coming along a little faster than ours
  16. Rye-guy
    Rye-guy
    IMG_0705.JPG IMG_0706.JPG IMG_0707.JPG IMG_0708.JPG IMG_0709.JPG IMG_0710.JPG IMG_0711.JPG IMG_0712.JPG Got the steering box put in but may need to adjust it's position, also had to flip the parts that connected the tie rod to the spindles because when we had them up, they caused clearance issues.
    Also got the drivers side header mocked up, these things are going to be loud, used a hedmen headers big block Chevy header kit with ford flanges, it's 2 1/8 pipe.
    cktasto, 6sally6, enloe and 7 others like this.
  17. Saxxon
    Saxxon
    That's looking great. You guys got a lot done this weekend. I'm pretty sure that back pipe took you guys 2 or 3 hours alone
  18. saltflats
    saltflats
    from Missouri
  19. sc5080
    sc5080
    Headers look great. Its coming along well.
  20. Rye-guy
    Rye-guy
    We haven't gotten much done in the last few weeks because we ran out of pipe for the other side of the headers and then got the wrong size...
    But we got a tunnel made, custom driveshaft hoop that also acts as the back ****** mount that connects to the subframe connectors.
    Mocked up the electric water pump as well, went with one from CVF racing, as well as got their electric water pump and alternator bracket kit, makes everything fit well and easy to install.
    Also got a rear sump oil pan put on (it's a whole kit from jegs, it's actually made to fit a 429/460 into a mustang) and got the fuel cell in.
    It's a 12 gallon fuel cell and what we did is took the stock tank and cut the top off and set the fuel cell in that, makes it look factory from the outside, even considering using the stock filler for it so I don't even have to open the trunk
  21. saltflats
    saltflats
    from Missouri
    Looks like good progress.
    Any reason you didn't go with a pan with more oil control?
    I do know cost always has a lot to with a build. ;)
  22. seb fontana
    seb fontana
    from ct
    Engine Set Back: 10% max of wheelbase measured from center of mounted front axle back to #1 spark plug center line..So a 105" wheelbase would be a 10.5" measurement from axle to spark plug max..
    loudbang, chryslerfan55 and Gammz like this.
  23. southcross2631
    southcross2631
    I was wondering same thing myself as far as oil control if you plan on racing the car . Fine for street cruising. Could use more capacity for racing at least.
    Nice job on the headers and the rest of the car. I really like Falcon's.
  24. Rye-guy
    Rye-guy
    For the oil pan, the reason I went with this one is one because it came as a whole kit, pan, pickup, dipstick. And secondly was definitely cost, but also the motor is a pretty stock with very mild upgrades done to it. It was originally supposed to be put in a street car before I picked it up. So really it's a street motor, I don't need the big expensive race oil pans right now.
    In the future I plan to do a stroker kit and at that point I will most likely upgrade the pan.
    But for right now this will do just fine
  25. saltflats
    saltflats
    from Missouri
    I think you will be surprised how hard it will launch.
    powrshftr, chryslerfan55 and loudbang like this.
  26. loudbang
    Nice thinking hiding the fuel cell.
    chryslerfan55 and Rye-guy like this.
  27. Rye-guy
    Rye-guy
    We're actually going to be putting 3.50 gears in the rear end but with a lower 1st and 2nd gear in the transmission so that it'll launch more like 3.73 or 4.10, just because we don't know yet what mph it will run and don't want to over rev the engine
  28. saltflats
    saltflats
    from Missouri
    I have one of the C6 s setting on the bench now waiting on the low drag gear set now.
    Its going behind a 467 inch FE in a 67 Galaxie and hope to gear it so it goes through the traps around 6200 to 6500 rpm.
  29. Rye-guy
    Rye-guy
    IMG_0746.JPG IMG_0747.JPG IMG_0748.JPG IMG_0749.JPG IMG_0750.JPG Big news! It runs! Got the headers finished and fired it up quickly, getting closer and closer everyday
    Also tried to get the new alternator to fit, trying to get a Chevy alternator onto a ford motor with brackets made for a ford is not easy.
    First I had to make the bolt holes a lot bigger and next grind down the back of one of the holes on the back of the alternator because it hits the block.
    P.s. I tried to upload a video of the engine running but it would not upload
  30. Saxxon
    Saxxon
    Outstanding !!
    Headers look awesome. First fire is always a milestone you look forward to.
    enloe, chryslerfan55 and loudbang like this.
