Technical Headlight bar center to center question
Discussion in 'Traditional Hot Rods' started by BLACKPRIMERFAN, Dec 10, 2017.
  1. BLACKPRIMERFAN
    BLACKPRIMERFAN
    from OH/MI LINE
    quick question:
    What’s the center to center of the headlight cups on a ‘32 Ford headlight bar vs Model A ‘28-29 & ‘30-31? I’ve a ch***is setup with Pete &Jakes weld on shock/ headlight combo and the headlights look spread a little too far on my Model A ch***si.
  2. BLACKPRIMERFAN
    BLACKPRIMERFAN
    from OH/MI LINE
    My current ch***is is 34” cup to cup
  3. Fordors
    Fordors
    The c - c on a stock ‘32 bar is 28 5/16”, with the Taiwan bars the same, and the Bob Drake dropped bar is 28 11/16”.
  4. BLACKPRIMERFAN
    BLACKPRIMERFAN
    from OH/MI LINE
    Wow! No wonder why I thought it looked funky! Anyone have the spread on a Model A bar?
  5. sloppy jalopies
    sloppy jalopies
    I think one is a '30 = 29 5/8" c to c ...shallow arch light to fender bolts...
    and the other is a '29 = 30 3/8" c to c ... sharper arch light to fender bolts...
    HIH...
  6. Fordors
    Fordors
    The headlights on my coupe are mounted on a cut, heated and bent Model A bar, they happen to be 28 1/4" apart, but it wasn't really planned that way they just ended up there. scan0016.jpg
  7. akoutlaw
    akoutlaw
    My 30 measures 29 1/2" center to center on the headlight mounting bolts.
